New Theme bugs
Whoey · 149 · 7558
wales Offline Smashie
  • Smurf it!
Re: New Theme bugs
Reply #30 on: July 14, 2016, 09:10:24 PM
Selectable search is a mod, it's on my todo list as it does not install cleanly on this theme due to it's custom nature therefore requires me to dig a little deeper to get it working.
Is there a reason that when you select 'Replies' it does this?
its at 2560 x 1440
no idea, please send me your setup so I can further test it.  >:D I do not have this problem on 1920x1080
How much do you need?  >:D
System Information
      Time of this report: 7/14/2016, 20:03:28
             Machine name: BESPIN
         Operating System: Windows 10 Home 64-bit (10.0, Build 10586) (10586.th2_release_sec.160527-1834)
                 Language: English (Regional Setting: English)
      System Manufacturer: ASUS
             System Model: All Series
                     BIOS: BIOS Date: 12/20/13 15:29:50 Ver: 13.01
                Processor: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz
                   Memory: 32768MB RAM
      Available OS Memory: 32706MB RAM
                Page File: 12319MB used, 55203MB available
              Windows Dir: C:\WINDOWS
          DirectX Version: 12
      DX Setup Parameters: Not found
         User DPI Setting: 96 DPI (100 percent)
       System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
           DxDiag Version: 10.00.10586.0000 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
      Display Tab 2: No problems found.
        Sound Tab 1: The file t3.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL).  You may be able to get a WHQL logo'd driver from the hardware manufacturer.
        Sound Tab 2: The file t3.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL).  You may be able to get a WHQL logo'd driver from the hardware manufacturer.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: NVIDIA GeForce GTX 980 Ti
       Manufacturer: NVIDIA
          Chip type: GeForce GTX 980 Ti
           DAC type: Integrated RAMDAC
        Device Type: Full Device
         Device Key: Enum\PCI\VEN_10DE&DEV_17C8&SUBSYS_49953842&REV_A1
     Display Memory: 22401 MB
   Dedicated Memory: 6047 MB
      Shared Memory: 16353 MB
       Current Mode: 2560 x 1440 (32 bit) (59Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: XB270HU
         Monitor Id: ACR0408
        Native Mode: 2560 x 1440(p) (59.951Hz)
        Output Type: Displayport External
        Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um,nvwgf2um
Driver File Version: 10.18.0013.6839 (English)
     Driver Version: 10.18.13.6839
        DDI Version: 12
     Feature Levels: 12.1,12.0,11.1,11.0,10.1,10.0,9.3,9.2,9.1
       Driver Model: WDDM 2.0
Graphics Preemption: DMA
 Compute Preemption: DMA
           Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
     Power P-states: Not Supported
  Driver Attributes: Final Retail
   Driver Date/Size: 02/06/2016 00:00:00, 17432544 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp:
  Device Identifier: {D7B71E3E-5488-11CF-4541-98691CC2C735}
          Vendor ID: 0x10DE
          Device ID: 0x17C8
          SubSys ID: 0x49953842
        Revision ID: 0x00A1
 Driver Strong Name: oem89.inf:0f066de3672d1ed2:Section045:10.18.13.6839:pci\ven_10de&dev_17c8
     Rank Of Driver: 00D12001
        Video Accel:
        DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeVC1_D2010  DXVA2_ModeVC1_VLD  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeHEVC_VLD_Main  DXVA2_ModeMPEG4pt2_VLD_Simple  DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC
   Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
       D3D9 Overlay: Supported
            DXVA-HD: Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
           MPO Caps: Not Supported
        MPO Stretch: Not Supported
    MPO Media Hints: Not Supported
        MPO Formats: Not Supported
         Monitor Id: ACR0408
        DDI Version: 12
        WHQL Logo'd: Yes
    WHQL Date Stamp:
          Vendor ID: 0x10DE
          Device ID: 0x17C8
        Revision ID: 0x00A1
        Video Accel:
            DXVA-HD: Supported
         D3D Status: Enabled
         AGP Status: Enabled
Si vis pacem, para bellum
fi Offline temo
Re: New Theme bugs
Reply #31 on: July 14, 2016, 09:12:30 PM
Is there simply timeline? I don't like unread as then I loose new posts if read once already. Maybe I am just slow that I go back to threads already read.
  • Bored
Re: New Theme bugs
Reply #32 on: July 14, 2016, 09:15:30 PM
I see the problem, in line 34, 4th word, it should be changed to d, and all will be sorted.
Re: New Theme bugs
Reply #33 on: July 14, 2016, 09:38:52 PM
http://forum.multitool.org/index.php?action=recent
Or you can go to the main window, scroll to the bottom and click the most recent posts link
us Offline sLaughterMed
Re: New Theme bugs
Reply #34 on: July 14, 2016, 10:41:04 PM
Avatar spacing issue has been fixed, for my phone at least. Once I removed Signatures, the forum is readable again. Still a bit more white space than I like, but still good. Thanks Whooey!
Laughter is the best Medicine
us Offline kaput
Re: New Theme bugs
Reply #35 on: July 14, 2016, 10:46:24 PM
Is there a way to "request desktop version" please?
Re: New Theme bugs
Reply #36 on: July 14, 2016, 10:52:54 PM
This is the desktop site.  And the mobile site.  There is no longer a distinction in the site format, it just provides all of the info and your browser organizes it the most optimal way it can.
Many of the problems we are encountering is due to the vast array of devices, browsers and sizes, and how they all interpret the new info.  It takes time to optimize it for each size, device and browser, which is exactly what Micah is trying to sort out now.
gr Offline firiki
Re: New Theme bugs
Reply #37 on: July 14, 2016, 11:00:18 PM
I'm not complaining, to be honest though, I liked the previous format just fine in its simplicity. I know there's tweaking still going on and I trust Whoey and the rest of you cyber-gurus will get things fine-tuned eventually  :salute:
No quick reply, again.
Too much white, harsh on the eyes indeed. Maybe make a couple of colour schemes available to choose from?
Avatars are kind of big but generally pleasant. I think the online/offline indicator should be moved before the username. Multiple quotes look better now  :tu:
I liked the two different colour tones separating the posts. Sig area attracts attention from post and personal text gets lost in there somewhere. Also, personal text beneath the avatar is gone?
Post count is nice, at least keep the ranking?
I was beginning to like the Like function but I can live without it.
« Last Edit: July 14, 2016, 11:05:50 PM by firiki »
fi Offline temo
Re: New Theme bugs
Reply #38 on: July 14, 2016, 11:07:39 PM
Tx. I was looking more like thread list at time oder. Like unread and replies shortcuts at the top but simply threads listed without filters if I replied or have read messages.
gr Offline firiki
Re: New Theme bugs
Reply #39 on: July 14, 2016, 11:11:57 PM
Oh, one other thing. I think the little button you click to read to the last post in a thread could do with a bigger size or something to make it stand out. I am inclined to click on the username but that's just me :facepalm:
Re: New Theme bugs
Reply #40 on: July 14, 2016, 11:33:07 PM
Not just you
us Offline metasyntax
Re: New Theme bugs
Reply #41 on: July 15, 2016, 01:35:12 AM
its at 2560 x 1440
Comparing the "Unread" link with the "Replies" link, the latter is missing the width = 100% on the table. To be perfectly clear, there's the div#unreadreplies with a table.table_grid immediately underneath it. I think that table needs width = 100%, adding it makes things look better.. (Here's a screenshot showing what it looks like with the width added.)
I think the new theme is cool. Sure, there's some problems here and there, but I don't want to pile on. I'm sure redoing this whole site was a gargantuan effort. Hopefully this helps.
* mto.jpg (Filesize: 223.17 KB)
May it be as the Pattern has chosen.
us Offline gustophersmob
Re: New Theme bugs
Reply #42 on: July 15, 2016, 05:38:28 AM
I can't figure out how to see signatures anymore. I don't have the option to hide them selected, but I don't se any  :think:
I do really like the new layout. Much better than the old mobile site, IMO. and much faster than forcing to the desktop site on my phone.
nl Offline glenfiddich1983
Re: New Theme bugs
Reply #43 on: July 15, 2016, 08:41:14 AM
I changed back to the old theme for the time being, it was much clearer (for me), especially on my mobile phone :salute:
Although I do appreciate the effort, my mantra with things like this is: if it ain't broke, don't fix it  :cheers:
OK, now I feel like one of those elderly people who hates change  :facepalm:
« Last Edit: July 15, 2016, 08:51:00 AM by glenfiddich1983 »
[--- arms length ---] (-.-)
                                ^-- where the cat sits
fr Offline Whoey
  • I am geek, hear me code
Re: New Theme bugs
Reply #44 on: July 15, 2016, 10:36:47 AM
:o I find the old theme terrible to navigate on my phone, less so on my tablet, but it's crazy high resolution... The new one is much easier and loads much faster for everything I've tried it with so far...
fi Offline temo
Re: New Theme bugs
Reply #45 on: July 15, 2016, 11:07:08 AM
Sure it is a good effort to create new. Just often takes some time and use to get all in place.
wales Offline hiraethus
  • I brake for cake
Re: New Theme bugs
Reply #46 on: July 15, 2016, 11:12:05 AM
You should be able to see everyone else's nuts.  ;)
  • Bored
Re: New Theme bugs
Reply #47 on: July 15, 2016, 11:13:14 AM
Admin, Mods, charter members are nutless
gb Offline shibafu
Re: New Theme bugs
Reply #48 on: July 15, 2016, 11:13:34 AM
Another design suggestion when looking at the threads.
The signature/badge area is gray. Because of that, it has a good bit of contrast with the background of the page, and thus more emphasis than the actual post. So it draws the eye a lot. Typically it would be better to have the post have more emphasis, or at least, not have the badge/signature area stand out so much.
That's a good point. I'm finding my eyes hunt around more for the actual post content amongst the post headers, footers, quotes etc. than with the old layout.
gr Offline firiki
Re: New Theme bugs
Reply #49 on: July 15, 2016, 11:32:24 AM
Apart from certain people being nutless, though, :D it's not really the same.
Not many people know what the little nuts stand for, I suppose, or how many of them for which "rank". Maybe the nuts would be more visible if they were placed under the avatar.
I always liked the self-sarcastic titles such as No Life Club etc. (Abandon all hope ye who enter here  :rofl: ).
Oh, well. If I had to pick just one thing bugging me, that would be hunting around for the actual post in all the visual info.  :)
gr Offline firiki
Re: New Theme bugs
Reply #50 on: July 15, 2016, 11:44:37 AM
Why does the green box indicating there are new posts in a thread keep taking me somewhere in the middle of a page when I click on it?
us Offline twiliter
Re: New Theme bugs
Reply #51 on: July 15, 2016, 11:58:59 AM
Being nuts is overrated.  :P
us Offline twiliter
Re: New Theme bugs
Reply #52 on: July 15, 2016, 12:06:07 PM
The profile age thingy doesn't seem to stay put, I'm either 100 or n/a, and while both might be true, I do have an actual chronological age, and an expiration date that hasn't lapsed quite yet.  :D
us Offline twiliter
Re: New Theme bugs
Reply #53 on: July 15, 2016, 12:11:25 PM
Also IMO, the merit badges should just be there without the gigantic MERIT BADGES label overpowering the whole area. Maybe just a style thing, but Captain Obvious pointed it out to me.  :D
us Offline twiliter
Re: New Theme bugs
Reply #54 on: July 15, 2016, 12:14:49 PM
OK, I'm risking a spam badge now, but wanted to add that the site renders nicely on iOS 9.3.2  :cheers:
Re: New Theme bugs
Reply #55 on: July 15, 2016, 02:48:43 PM
Liking the less white background colors :cheers: Easier on the old eyes :D
Re: New Theme bugs
Reply #56 on: July 15, 2016, 05:55:58 PM
I agree, looks nice. Good job on the quick fix on that one Whooey.
Whooey, maybe it would be more useful to display the post count, rather than the nuts by default? :think:
fr Offline Whoey
Re: New Theme bugs
Reply #57 on: July 15, 2016, 05:59:10 PM
it's in the queue... as you can imagine I'm getting hit from all sides on this...
ca Offline Syph007
  • SAK Surgeon
Re: New Theme bugs
Reply #58 on: July 15, 2016, 06:09:45 PM
That makes it much more readable.  Major improvement!  The too white look was really hard on the eyes.   Now I can read it at least.  The only other thing Id comment on is that is it necessary to have the forum icons so large.  It feels like how windows 8 felt wrong because it was designed for tablets and standard PC but used the same feel on both.  It feels touch screen centric vs standard mouse.
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
Re: New Theme bugs
Reply #59 on: July 15, 2016, 06:10:32 PM
Looking better and better to me :cheers: just do what you can and try not to be stressed :tu:
