MP600 saw mod
SteveC · 34 · 4450
MP600 saw mod
on: July 27, 2016, 06:31:41 PM
I used a SOG saw blade that Poncho sent me and reprofiled it to fit my MP600. I removed the lanyard holder to make room. Fits great and locks perfectly.Finished it off by coating it with with dry spray graphite to match the BO coating.
« Last Edit: July 27, 2016, 06:40:10 PM by SteveC »
us Offline sLaughterMed
Re: MP600 saw mod
Reply #1 on: July 27, 2016, 09:45:35 PM
No tool wobble? I tried this once, and ended up with a a huge amount of up and down play.
Nice job :cheers:
Laughter is the best Medicine
tr Offline ddogu
Re: MP600 saw mod
Reply #2 on: July 27, 2016, 09:59:47 PM
Looks good  :tu:
Re: MP600 saw mod
Reply #3 on: July 27, 2016, 10:13:08 PM
Had me confused for a minute that my posts hadn't went through ??? then I saw that this one was in the Gerber forum :rofl:
Glad it worked for ya Steve :cheers:
Re: MP600 saw mod
Reply #4 on: July 27, 2016, 10:21:13 PM
Thanks guys !
Nice job :cheers:
No play or wobble, it's just as solid as the factory tools.   :tu:
Re: MP600 saw mod
Reply #5 on: July 27, 2016, 10:21:51 PM
Just keeping you on your toes   :pok:
Re: MP600 saw mod
Reply #6 on: July 27, 2016, 10:34:59 PM
Well you are doing a good job of it :D
Re: MP600 saw mod
Reply #7 on: July 27, 2016, 10:35:59 PM
Thanks guys !
Nice job :cheers:
Wonder if it makes a difference that it was one of the Harley Davidson branded saws :think:
Re: MP600 saw mod
Reply #8 on: July 27, 2016, 10:41:02 PM
Thanks guys !
Nice job :cheers:
I don't think so as it looks identical to the unbranded one . There is plenty of metal on the SOG blade to make a perfect match to the Gerber profile.
Re: MP600 saw mod
Reply #9 on: July 28, 2016, 12:14:54 PM
Good work Steve.   :tu:   :tu:
Re: MP600 saw mod
Reply #10 on: July 28, 2016, 04:59:10 PM
Thank you Zman   :cheers:
id Offline jaya_man
Re: MP600 saw mod
Reply #11 on: May 05, 2017, 07:02:18 PM
As I've shared in other threads, I recently got a Multi-Lock Scout. Here's a recent picture of it.
Am thinking of replacing the lanyard ring tool with a wood saw. As my knowledge on Gerber is very minimal, I only know of one MT that has the wood saw (the Diesel). Will it be a perfect fit (does it have the same thickness as the lanyard ring)?
Any other Gerber MTs that have the wood saw?
Re: MP600 saw mod
Reply #12 on: May 05, 2017, 07:13:42 PM
I am afraid I am no help on this matter jaya :facepalm:
I had to modify a SOG saw for mine and still it isn't perfect but works like it should :tu:
Re: MP600 saw mod
Reply #13 on: May 05, 2017, 11:58:18 PM
I can tell you that the lanyard ring from my MP600 was about the same thickness as the SOG saw I used.
 I'll bet that the Gerber saw is similar in thickness.
« Last Edit: May 06, 2017, 12:05:10 AM by SteveC »
Re: MP600 saw mod
Reply #14 on: May 06, 2017, 12:22:37 AM
The only other Gerber that I can think of with a saw is the Strata. From memory, and I may be wrong here, I believe the Diesel saw (and SOG saw) are longer.
Note also that you'll need to change the location for the saw, probably replacing the can opener at a guess (unless you go bladeless, and carry a separate knife).
Re: MP600 saw mod
Reply #15 on: May 06, 2017, 12:55:06 AM
Thickness shouldn't be an issue thanks to the pass through fastener.
Length I'm not sure about. I put Diesel scissors (approx half cm longer than that diamond file) into a 600 recently and they fitted in.
Outside pivot will need a quick reshape. Here are a few pics showing the difference from when I fitted the Diesel scissors.
id Offline jaya_man
MP600 saw mod
Reply #16 on: May 06, 2017, 05:42:33 AM
Thanks for the tips everyone :cheers:
Re: MP600 saw mod
Reply #17 on: June 23, 2017, 05:07:07 PM
Not to dig up an old thread, but I was considering doing a mod like this on my Center Drive.  With a saw in place of the serrated blade, it would pretty much cover the uses I have here in the country.
What's the tool used to disassemble a Gerber?
id Offline jaya_man
MP600 saw mod
Reply #18 on: June 23, 2017, 05:12:31 PM
I read somewhere in this post or another, pliers can be used to loosen pivot screws...
This video also shows a special tool:
Adjustable spanners...
« Last Edit: June 23, 2017, 05:17:52 PM by jaya_man »
Re: MP600 saw mod
Reply #19 on: June 23, 2017, 05:15:44 PM
Thanks J Man!!
id Offline jaya_man
MP600 saw mod
Reply #20 on: June 23, 2017, 05:19:56 PM
Thanks J Man!!
Glad I could be of help... still haven't done my mod yet though... still looking for that donor... worst comes to worst, might just buy a cheap mt with saw and take it from there :facepalm:
us Offline MusicMen
  • 21 Badges for Eagle
Re: MP600 saw mod
Reply #21 on: June 23, 2017, 09:33:03 PM
loki-mobile sells the tools to dis-assemble MTs
https://forum.multitool.org/index.php/topic,61708.msg1440122.html#msg1440122
I got the Leatherman and Gerber wrenches. They work great and make dis-assembling a breeze.
BUCK: X-Tract, 360
*=mod
Re: MP600 saw mod
Reply #22 on: June 24, 2017, 03:39:29 AM
 :cheers: Thank you sir!
Re: MP600 saw mod
Reply #23 on: June 24, 2017, 12:43:38 PM
We love to bring old threads back Barry :ahhh I think a lot of info is back in our archives and every now and again it is great when it is brought back to the forefront :salute: :like:
Re: MP600 saw mod
Reply #24 on: June 24, 2017, 12:44:01 PM
Also good luck with the mod :tu:
Re: MP600 saw mod
Reply #25 on: June 24, 2017, 03:02:40 PM
 :cheers: Thanks Poncho!
gb Offline kingofswords
Re: MP600 saw mod
Reply #26 on: June 24, 2017, 03:16:07 PM
I don't know why ppl make a big ordeal about removing pivots from mp's,  pair of carpenters pincers from pound land /dollar store are perfect for the job.
« Last Edit: June 24, 2017, 03:18:17 PM by kingofswords »
Re: MP600 saw mod
Reply #27 on: June 24, 2017, 03:22:20 PM
 :rofl: True indeed!!
us Offline MusicMen
Re: MP600 saw mod
Reply #28 on: June 24, 2017, 06:34:54 PM
Very true, but the difference between using something that works and something made for the task is night and day. Like using a knife to remove a branch from a tree. It can be done, but a saw works better.
 I have used many different tools to adjust my Gerbers. The best I have used are the tools loki-mobile sells. They are made to take apart the specific tools and work much better than any thing else 'that works.'
YMMV
BUCK: X-Tract, 360
*=mod
Re: MP600 saw mod
Reply #29 on: June 24, 2017, 08:45:33 PM
Total Receipts: $168.99
PayPal Fees: $9.87
Net Balance: $159.12
Below Goal: $140.88
53%
