Pete's November LM Signal Challenge
pietervn · 189 · 12061
au Offline pietervn
Re: Pete's November LM Signal Challenge
Reply #180 on: December 01, 2016, 10:47:16 PM
Excellent last thoughts. How you explained your month out is the vibe I got from you about the Signal the whole month. It isn't a kitchen sink type model but had enough on it that you have no trouble EDCing it
Thanks Poncho.
We definitely get a good feel for any Multi after 30 days. I will most likely keep using it on a very regular basis.
us Offline Monrogue
  • Wooooo!
Reply #181 on: December 02, 2016, 01:36:34 AM
It was interesting to follow this Pete, and I look forward to seeing your modded version :cheers:
Thanks
A question for the Signal modders: I went ahead and swapped that blades out last night. The OEM blade is quite a bit thicker that the Wave blade. It also touches the Awl when closed and that is probably why the blade has the strange bevel to it. Do you need to add an extra washer or two? For now the swap was reversed as I don't want to damage the edge on the PE blade. I will see if I have the correct size washers in the garage before attempting to swap the blades out again.
Cheers,
Pete
I'm not sure on this as I didn't change my blade, but I would guess a washer may be necessary as you said.
K-Tibbs
Reply #182 on: December 02, 2016, 03:30:29 AM
Thanks Poncho.
Glad to hear that you are going to continue EDCing it some :cheers: The 30 day challenges can either make or break a carry :D You can definitely get a feel for that particular tool in that length of time and usually know all the pros and cons :tu:
au Offline pietervn
Reply #183 on: December 02, 2016, 06:11:47 AM
G'Day,
Well I played again with the two blades today. I found an additional bronze washer from a MUT and added it to the Signal. The play issues I had disappeared, but the edge still rubs against the awl. I also have another 1mm washer (difference between the Signal blade and the Wave blade) but it is to big and the locking mechanism cannot clear it. Tomorrow I might go see the nuts and bolts man to see if he can help with a thicker bronze washer. The blade also rubs agains a small metal tab on the awl side, circled in the last pic, not to clear though...
So back to the OEM blade it is...
Cheers
Pete
Reply #184 on: December 02, 2016, 03:56:12 PM
I hope you find a thicker washer and that does the trick :tu:
au Offline pietervn
Reply #185 on: December 03, 2016, 04:45:44 AM
Me too, the fact that LM is in imperial makes it difficult in a metric country. I do have a Plan B, but will keep looking for now.
Pete
au Offline Gohard
  • Leatherman fanatic!!
Reply #186 on: December 03, 2016, 08:19:19 AM
Pete
Awesome writeup Pete. Didn't follow the whole thread daily. Been very busy at work. Will read it once I get a long break.
Cheers.
au Offline pietervn
Reply #187 on: December 03, 2016, 09:04:35 AM
Awesome write-up Pete. Didn't follow the whole thread daily. Been very busy at work. Will read it once I get a long break.
Cheers.
Thank you.
Pour a good beverage first, "stukkie boerewors" and have a read!
The sheath is now well bedded in, I love it.
Pete
Reply #188 on: December 04, 2016, 04:13:43 AM
Cheers.
Thank you.
Pete
Sheath carry is for me but I do love a good clip when I just want to grab a MT and go :cheers:
Total Receipts: $66.45
PayPal Fees: $3.99
Net Balance: $62.46
Below Goal: $237.54
21%
