This question is a little noobish...
About to do my first Wenger based mod...Have the final bits on the way (thanks S.P.)
I was planning on using the flat-style outer liners (not the kind with the 3 little snappy slot thingies) and then purpleheart wood scales with exposed brass pins, sanded down smooth and flat with the scales.
Do I epoxy the wood scales to the outer liners? The pins will hold the wood on, but I'm wondering for assembly ease/strength if the wood should be bonded to the metal outer liners first.
Any tips on how much I should countersink the holes in the wood to leave room for the pins to expand?
if anyone is interested, it's gonna be:
Locking blade/nail file
phillips/wrench
scissors (thinking of trying dual spring for less movement if my local machine shop can thin down a couple of scissor layer spings)
pliers
wood saw
metal file
openers
Corkscrew/awl on back
Final question: Will a Vic corkscrew work with the wenger spring? I want to put a mini driver in there and I see it won't fit in my Wenger corkscrew.
