Idea for a new Leatherman Multi Tool. Super Sized Skeletool
mcb · 9 · 1019
us Offline mcb
Just throw this idea out there.   I would love to see Leatherman make a scaled up Skeletool.  Scale it up to fit the pliers (with replaceable cutters) that are used in the Surge or MUT.  Scale the blade to match the new larger handles.  The only change I would make would be with the longer handles to expand the bit storage some if possible.  Otherwise leave the Skeletool as close to the original configuration as possible just scaling it up to the larger size.
What do you guys think?
Re: Idea for a new Leatherman Multi Tool. Super Sized Skeletool
Reply #1 on: November 10, 2016, 11:36:56 PM
Sounds good to me :cheers: Unfortunately I think LM sees the MUT and Signal as an upscaled Skeletool  :-\ I do  :like: the idea though  :cheers:
« Last Edit: November 10, 2016, 11:38:24 PM by Poncho65 »
us Offline Kampfer
  • Tactical Desk Jockey
Reply #2 on: November 11, 2016, 01:05:04 AM
You are correct. But I don't think MUT or Signal capture the true spirit of Skeletool, not the carabiner but the cure lines & holes along the entire tool, and Skeletool is a knife base MT, pocket knife with other features hid inside.
us Offline chrono
  • Find me if you can...
Reply #3 on: November 11, 2016, 03:10:02 AM
Well, if you increase the handle size, you should increase the pliers and knife sizes as well, right? Kind of defeating the light weight purpose of the skeletool design.
us Offline Kampfer
Reply #4 on: November 11, 2016, 03:34:33 AM
That is correct
us Offline mcb
Reply #5 on: November 11, 2016, 04:32:15 AM
It would get a bit bigger and heavier but if you kept the configuration the same as Skeletool it would not get significantly thicker than it Skeletool.  It would be roughly 2/3's as thick as a Surge since it only has a blade on one side of one handle  The other handle without the blade would be relatively thin/light since it only has the spare bit storage and carabiner/bottle-opener.
Using the distance from the handle pivots to the tip of the pliers as a characteristic length.  A Skeletool based on a Surge's pliers head would be ~36% larger than the original.  A Skeletool weights 5oz and a Surge 12.5oz.  If they could keep the super sized Skeletool in the 8-9oz range I think it could be a good product.
I like the configuration and feature set of the Skeletool but I find myself wishing the pliers were a bit bigger and more robust for some jobs I get myself into.  Also the hard-wire replaceable cutters of a Surge style pliers head would make the tool more capable and more maintainable.
Just an idea...
wales Offline Simplon
Reply #6 on: November 11, 2016, 02:04:03 PM
And to my mind it is a great idea. :like:
Simplon.
Now where did I leave my knife?
mc Offline Gerhard Gerber
Reply #7 on: November 11, 2016, 02:55:46 PM
I like that idea......  :tu:
Fitted with a beefy blade and something stronger than a liner lock........maybe an awl slipped in somewhere......I would buy that.
ie Offline jonon9
Reply #8 on: November 11, 2016, 04:04:02 PM
Id love to seem them fit a spring pliers to them  8)
