Multitool.org Bag Overview
on: February 28, 2017, 02:21:31 PM
Some time ago I started doing some research into trying to find out what kinds of bags Multitool.org members liked so that I could consider producing some Multitool.org branded (or even designed!) bags for member use.  Some of you will remember that I started a thread to see what kinds of bags members liked.  As was recently pointed out, I have been testing some options.
I started off with a sling bag, largely because the pricing was better and because I have recently become somewhat enamoured with sling bags thanks to my MEC sling bag and the Maxpedition Sitka.  I ordered this black and silver version which features a silk screened MTO Tenth Anniversary logo, a rubber hole to run your headphone wire through and a mesh water bottle holder on the side.
I thought it was a pretty sharp looking bag, and at a similar price to the MEC Sling Bag, I thought it could be pretty darned good.  In fact, I was so impressed with the MEC Sling Bag that I bought one each for my nephews for Christmas this year.
When the bag arrived I was quite pleased with the way the logo turned out- they did an excellent job on that.  Unfortunately, the MTO Logo was the only good thing about the bag.
Where to begin....?  The strap is not padded at all, by itself the bag is shapeless, with no interior pockets to speak of except a saggy little baggie pocket that I wouldn't trust to hold a cheap MP3 player.
The stitching, zippers and pulls aren't bad at all, but the material between them is the same stuff you find in the super cheap reusable shopping bags.  It's probably ok for a few uses, but anything with corners is going to start to poke through in short order.  The "tougher" exterior of the pack is what should have been used for the softer interior, and the exterior should have been made of something much more robust.
Due to the poor design and overall shapelessness of the bag, it won't even see the couple times worth of carry that it could have seen, as I really don't have any faith that it will hold anything at all.  For example:
The water bottle pocket won't even hold this small half litre water bottle securely.  What happens when I try to put my 1.18L Kleen Kanteen in it?  Easy- I go buy a new 1.18L Kleen Kanteen to replace the one I lost....   :facepalm:
So that one was a complete waste IMHO.  But, I was certainly not going to give up on the concept after one fail, so I ordered another sample, this time a backpack.  It was quite a bit more expensive than the sling bag, but then the sling bag was also a hunk of garbage, so I figured I'd see what a few extra dollars got me.
All in all it looked like a pretty good bag, with dual water bottle pockets on the outside, MOLLE attachment points for extra gear (but not looking overly tactical), padded laptop compartment, hood cover that was actually a rather sizeable pocket and actual pockets inside!
Like the sling bag, the company did a great job with the logo, although this time it was embroidered on, and, since it was a larger area, I was also able to add the web address and the years, just in case you were wondering which ten years we were counting!  :D
Inside there are quite a few organisational pockets for pens, ID's various cards and other things, so I was pleased to see that someone actually put some time and effort into this bag.
And the top pocket is quite large as well- in fact, on our recent Sugarbush Hike I managed to put my SVEA Optima stove in there, along with the Mountain House meal that we had intended to eat.
There was even more space, but as we weren't going far I didn't feel the need to try and maximise space and pack it that densely.
Overall this one suffers from some of the same problems as the sling bag- the construction is just not as heavy as I'd like.  It is however, much better than the sling bag, as this one is actually functional.  The stitching is good, the zippers and buckles are good, and the outer shell of this one is tougher than the sling bag.  It is well worth carrying and using for a while, and I have faith that everything I put into it will probably be there when it's time to take the stuff back out of it.  It holds my 1.18L Kleen Kanteen quite well and it also holds a 1L Primus fuel bottle just as securely.
The straps on this one are only slightly padded though, and have a large brass ring connecting them to the bag itself.  I am not sure how comfortable with that I really am, but it seems to have held so far.
It is overall a useful bag, although I would like to see it sturdier.  Maybe I am spoiled by Maxpedition and similar type bags that are built to withstand minor to moderately sized nuclear detonations, but this one just doesn't cut it as an actual Mutltitool.org issue bag for me.  And, the pricing is a bit steep on it- we would have to offer them to members at around $60 just to cover the costs of having them made, and this does not strike me as a $60 bag.  I would consider it a $30-40 bag at most.  By way of comparison, I got Megan a nice Columbia backpack for Christmas that was regularly $60, marked down to $40 and it is far superior, with better materials and construction.
Still, while it may not go into production, I am sure this is not the last you will see of this particular Multitool.org backpack, nor of the Multitool.org Bag Program, as I fully intend to keep searching for a bag worthy the Multitool.org name.
As always, suggestions, comments, questions and observations are always welcome!
« Last Edit: July 27, 2017, 03:09:11 AM by Grant Lamontagne »
Re: Multitool.org Bag Overview
Reply #1 on: February 28, 2017, 02:39:10 PM
Good write-up boss. :cheers:  Shame the sling bag is such a piece of crap, but at least the rucksack does the job.  Let the hunt for a MTO bag begin. :tu:
Reply #2 on: February 28, 2017, 03:05:32 PM
+1
Just an idea, if the cost are to high, how about a small organizer. Like the ones Maxpedition made. Not sure if that was done before or not. Would be cool to find a nice sling bag with the MTO logo on it.
Reply #3 on: February 28, 2017, 03:39:07 PM
It isn't ready yet, but there is very likely going to be a way for you to express the MTO love on Maxpedition and similar bags soon.
An organiser would be cool too, and something I hadn't really thought of.... although I did strongly consider this interesting organiser with woven elastic straps all over it that was basically infinitely customisable.  I can't recall the name off the top of my head but they were pretty cool... and unfortunately also quite pricey.   :ahhh
The search for MTO Swag continues!  :D
us Offline BIG-TARGET
Reply #4 on: February 28, 2017, 03:53:23 PM
:like: both of them :gimme:
us Offline Wallace72
Reply #5 on: February 28, 2017, 05:08:25 PM
If quality is a concern, you could always repurpose surplus bags or simply put the MTO logo on a surplus bag
Something as simple and cheap as this would be cool   https://www.varusteleka.com/en/product/polish-breadbag-surplus/9250
or this https://www.varusteleka.com/en/product/british-pattern-37-small-pack-used/10500
« Last Edit: February 28, 2017, 05:10:25 PM by Wallace72 »
Reply #6 on: February 28, 2017, 05:13:08 PM
Velcro patch?!
Reply #7 on: February 28, 2017, 05:21:46 PM
I would be interested in getting something like those done.  I really like those.  The question is, how do we get the logos done on them then, and still manage to keep them reasonably priced?
Reply #8 on: February 28, 2017, 05:22:24 PM
Velcro patch?!
Anything is possible....  :whistle:
Reply #9 on: February 28, 2017, 05:26:43 PM
Yeah if you know anybody that sews, you can just design a patch that then attaches to the surplus bags..I think they have heat activated glue for fabric but I don't know how well it works.
The bags are like 10-12 bucks and a patch probably costs around 3-5 bucks so at most 17 bucks...maybe sell them for 30
« Last Edit: February 28, 2017, 05:30:10 PM by Wallace72 »
us Offline Demel
Reply #10 on: February 28, 2017, 05:28:47 PM
I was excited by the title then kept reading :facepalm: I've been wanting a good sling bag so hopefully you can find the right company to make a quality bag.
00 Offline Mechanickal
Reply #11 on: February 28, 2017, 05:59:01 PM
Oh, while you're at it...
I'd love a MTO pocket organiser :D
:bnghd:
br Offline BleaKrytE
  • Hello world. I'm Vinícius!
Reply #12 on: February 28, 2017, 06:27:14 PM
Maybe you could look into knock off Maxpedition stuff... I mean, decent copies aren't expensive and will probably hold up a lot better than the sling bag you found. Also I love the surplus pack idea!
Enviado do meu iPhone usando Tapatalk
Uni student, environmental activist (yes, I'm that annoying guy that mentions climate change every third minute), motorcyclist.
Reply #13 on: March 01, 2017, 03:12:58 AM
Glad the rucksack was good and to bad about the sling bag :facepalm: :D
gr Offline firiki
Reply #14 on: March 08, 2017, 01:52:17 PM
No idea what the cost would be but I'd be all in for designing some bags! Sick and tired of looking at stuff that doesn't really suit my needs. I'm not terribly demanding, either!!
Reply #15 on: March 09, 2017, 02:32:47 AM
We could keep the costs down to a reasonable level if everyone who ever registered at MTO would commit to buying a thousand of them.
Reply #16 on: March 09, 2017, 10:40:21 AM
Maybe not designing one from the ground up, but adapting some other? Like making pockets for multitools and SAKs...
gr Offline firiki
Reply #17 on: March 10, 2017, 12:55:58 PM
:o Riiiight; a dream just got broken. :-\   :cry:
gr Offline firiki
Reply #18 on: March 10, 2017, 12:59:29 PM
Well, that's what I had in mind really; improve on some existing designs by adding/changing details and using materials of choice.
One day, some day...  :D
Reply #19 on: March 10, 2017, 05:32:34 PM
So 5k members * 1k bags per member = 5 million bags?  :o
Reply #20 on: March 10, 2017, 06:47:06 PM
Don't go bringing sense and maths into this!  :twak:
Reply #21 on: March 10, 2017, 06:50:54 PM
Screw logic, let people be happy! :twak:
Reply #22 on: March 10, 2017, 08:47:10 PM
Velcro and iron on patches to convert our own gear to MTO tributes FTW!
Reply #23 on: March 11, 2017, 02:33:06 PM
Velcro and iron on patches?  What great ideas.... why didn't I think of that?   :whistle:
I'm heading out today to look at some new bags that we may consider, along with some that may go for another project that I'm not allowed to talk about yet (not MTO  :pok:), but will be really cool and exciting.
If anyone has any ideas or specific features they would like to see, let me know and I'll try to keep it all in mind when I'm poking about.  :D
Reply #24 on: March 13, 2017, 07:43:55 AM
FB does have some advantages after all :whistle:
Reply #25 on: March 13, 2017, 08:22:30 AM
Yeah nar.
Reply #26 on: March 13, 2017, 01:12:14 PM
Yeah nar.
Not saying that the pro's outweigh the cons...
We should get a "welcome back, zoidberg" patch too!
Reply #27 on: March 13, 2017, 09:39:25 PM
Yeah nar.
Except nobody would buy that.
Offline mtn
Reply #28 on: March 13, 2017, 09:55:22 PM
Check out eBags for "custom" bags. Their branded stuff is just phenomenal quality with a pretty much unlimited lifetime warranty. And then they also have pretty much every other brand available as well.
Yeah nar.
no Offline Steinar
Reply #29 on: March 13, 2017, 10:21:37 PM
Somebody's had a rough day/week/month/year/decade/life, it seems...
