CRK Nyala & a strop
00 Offline kwakster
CRK Nyala & a strop
on: April 12, 2017, 06:55:30 PM
This strop is what i give to customers who regularly send or bring me a CRK knife for sharpening and some TLC, so they can maintain & keep the appearance of their new edge themselves for some time at home.
It's a new & cut-to-size piece of clean MDF coated with a thin layer of 1.0 micron (+/- 14000 grit) mono-diamond compound made by 3M, and i put self-adhesive rubber bumpers (also made by 3M) on the bottom.
These make the strop non-slip plus they elevate the working surface a bit which makes the strop more convenient to use on a table (more room for your hands)
The Nyala used as a prop for the pictures was recently reprofiled (from 35-40 degrees inclusive to an even 30 degrees inclusive) & sharpened (with 15 micron diamond compound on a Paper Wheel) and will be picked up by it's owner somewhere in the coming weeks.
BTW: it's main purpose is to cut oranges,  about 5 each day, :D
Re: CRK Nyala & a strop
Reply #1 on: April 12, 2017, 08:39:02 PM
Always interesting K  :salute:
ca Offline jcs0001
Reply #2 on: April 14, 2017, 04:50:24 AM
That's an interesting and easy way to make a strop.  Thanks for the idea.
John
00 Offline kwakster
Reply #3 on: April 14, 2017, 04:32:43 PM
Cheap & easy to make, it already has a perfectly flat surface, the material works very well as a substrate for fine diamond (or CBN) compounds, and for me the most important feature: MDF is noticeably harder than leather, so there is much less chance of rounding the apex of your edge.
Total Receipts: $90.65
PayPal Fees: $5.47
Net Balance: $85.18
Below Goal: $214.82
28%
