Scales: wood or synthetic?
on: June 06, 2017, 03:17:01 PM
I have an assortment of scale materials that I haven't used yet, and was considering what to use them on. Originally, I was thinking about Swiss knife mods, but then started considering other knives instead....
The Byrd Tern, Spyderco UKPK, and Boker+ XS are all UK legal, but still look a bit tacticool due to the black G10 scales on them all. I was wondering if wood scales (I have teak and olive slabs) would soften the look a little. They should still be nice and light if I don't use liners, although not as durable.
What's the thoughts here on clipped OHO folders? Do people stick to synthetic because that's what's most common, or is there a genuine preference to synthetic scales over wood?
Re: Scales: wood or synthetic?
Reply #1 on: June 06, 2017, 03:23:20 PM
I like both. I seen a pic were somebody did a SOG Vulcan with walnut scales and it looked very classy.
Reply #2 on: June 06, 2017, 05:06:45 PM
Here's the options that I'm considering - both the knives and the scales...
Wings Slipit - a great daily folder, particularly if there's a chance of needing a serrated blade. I've not carried it much since I sold the boat and stopped running a machine shop, but still a damn good option to have in the array.
Byrd Tern - Superb little knife. I liked it so much, I bought a spare. This means I could tweak one, and keep the other as stock.
Spyderco UKPK (original version) - Never gets carried, closed, and laid open on a table, it's sized very similar to the Tern. In hand, the blade is noticeably larger, so would it even be worth modding the handle when there's so much blade on show?
Boker+ XS - probably the most "offensive" looking to non-knife users. This usually resides in tool kits where many would normally have a lock knife (which I personally don't see the point of - slippie or fixed for me). Removing the BO and adding wood scales might make it more people-friendly, but if leaving it in tool kits, the standard scales would be more durable and forgiving of harsher use.
The other thing I was tempted to use the olive for, was restoring this old Sheffield made open razor, and rescaling it in something prettier than black plastic.
I do have some other scale materials too, including a block of wych elm burr, CF faced sheet, and GITD Kirinite, but I've not really got any plans for those yet
« Last Edit: June 06, 2017, 05:08:52 PM by 50ft-trad »
Reply #3 on: June 06, 2017, 11:05:06 PM
I've been looking at a few pics online, and  it seems the key is being quite selective on the grain of the wood used
nl Offline Ron Who
  • I'm blue!
Reply #4 on: June 06, 2017, 11:05:31 PM
IMO wood wood look great on the bolstered Wings. Removing the pocket clip.is another option to give it a more trad appearance.
Reply #5 on: June 07, 2017, 02:40:43 AM
I think I'd still want the clips on these. I don't want to reduce the function of them. I think i have some small pieces of oak somewhere, which would probably do nicely for the wings if i kept the bolsters  :think: that would probably be less wasteful than using the teak or oak slabs.
us Offline ColoSwiss
Reply #6 on: June 07, 2017, 04:02:39 AM
If you're looking for a softer look the light colored olive might be the way to go. It can also make for attractive handles, like on the Delta Z (bottom).
Reply #7 on: June 07, 2017, 10:47:34 AM
Yeah, that definitely works, Karl  :cheers:
wales Offline Smashie
  • In Memoriam
  • Smurf it!
Reply #8 on: June 07, 2017, 01:47:22 PM
I do like wood scaled folders and agree with ColoSwiss about the look of olive wood.
Lionsteel Mini
Si vis pacem, para bellum
mc Offline Gerhard Gerber
Reply #9 on: June 07, 2017, 03:12:13 PM
Best of both worlds - stabilized wood?
Sorry, I'm struggling a bit with my foot-in-mouth disease, and the nicest way I can phrase this is:  What does it say about sheeples' general intelligence if wood scales make a difference?   :facepalm:
Reply #10 on: June 07, 2017, 03:35:29 PM
Lionsteel Mini
Very nice!  :tu:
It's not just about what they think, but also what I might think  ;)
I do take your point though, and the question of "is it really worth it" has crossed my mind. The more I think this over, the more I think the UKPK would be a waste of time. In use, when the scales are covered anyway, there would still be a lot of blade on show (length of blade as well as height from edge to spine) - and in truth this is more blade than I tend to need from a folder. I've been on the fence about this knife ever since I bought it, and it never gets carried. I had thought that I ought to have one higher spec blade steel folder in the array, but now I'm wondering if this is just not the right knife for me....
I think keeping one Tern as standard, and fitting one with teak might be quite nice. Maybe that should be the first project.
Using the olive on the Boker+ XS will put more of the wood grain in play, and this knife is the one that stands to get the biggest cosmetic difference. Even so, it still may benefit from having other changes, like removing the black finish, and possibly even tweaking the blade shape a bit. A much bigger project, but also a much bigger difference to overall effect.
The Wings needs more thought. A darker wood would probably contrast better with the stainless bolsters - but even then, the scales aren't that large as to be a feature - so would losing the bolsters altogether be better....?  :ahhh
Reply #11 on: June 07, 2017, 03:37:13 PM
As to the stabilised wood suggestion, I'm only considering the stuff that's already lurking around the house. I'm not interested in acquiring even more stuff  :D :cheers:
nl Offline Ron Who
  • I'm blue!
Reply #12 on: June 07, 2017, 04:10:49 PM
I don't think intelligence has anything to do with it. Some people just don't need/like knives, the same way I don't need/like pliers. And I think the term "sheeple" is derogatory and should be banned from the site. I know it gets used a lot on MTo, but nevertheless. I hope you don't mind my saying so, I'll say nothing more about it
wales Offline hiraethus
  • I brake for cake
Reply #13 on: June 07, 2017, 04:24:23 PM
us Offline kaput
Reply #14 on: June 07, 2017, 04:25:51 PM
What about micarta, g10, titanium, carbon fiber?
Reply #15 on: June 07, 2017, 04:33:33 PM
Hi 50
I'm all for modding  :tu: for it's own sake  :cheers:
Reply #16 on: June 07, 2017, 05:10:25 PM
I have some pale yellow g10, some carbon fibre faced resin, some thickish home made micarta, wych elm burr, and some GITD Kirinite..... and I've not decided what to do with those either  :D I'm only considering using stuff that I've already got  :)
Reply #17 on: June 07, 2017, 05:11:48 PM
Hi 50
Well yeah, there isthat too  :D
Reply #18 on: June 07, 2017, 07:04:01 PM
Mmmm walnut   ;)
Boker biscuit
Reply #19 on: June 07, 2017, 10:36:58 PM
:2tu:  :salute:
Reply #20 on: June 08, 2017, 02:06:23 AM
Nice walnut!   :tu:
Reply #21 on: June 08, 2017, 09:26:47 AM
Those were from a few years ago
I really need to do some more of them... one day
Reply #22 on: June 09, 2017, 12:24:27 AM
I think the Wings, or perhaps the Tern, would look very well in some olive wood scales.  I think the perception might be softened a touch, but not s whole heck of a lot.
ch Offline Etherealicer
Reply #23 on: June 09, 2017, 08:30:03 AM
I'm not old and grumpy so, synthetic for me all the way :D
Sadly, I agree most synthetic handles are black and are meant to look tacticool not befitting my cheerful nature. In Switzerland pulling out a knife (a real one, not a metaphorical one) gives, if any (we are rather reserved, so usually you get no reaction), positive reactions. And no other knife gets that many reactions as my light-blue Mini Griptillian. If they see it, total strangers want do know what kind of knife it is.
That said... Sparky, that Boker looks gorgeous.
Boker biscuit
Reply #24 on: June 09, 2017, 02:09:44 PM
Fair play  :cheers: Since I started the thread, I did consider the bleedin' obvious factor that as soon as you start using it, the scales are covered anyway  :D
Oy!  :twak: I'm not grumpy, just a mildly eccentric, experienced optimist.
People who know me, tend to have a similar (neutral or positive)  reaction with my knives. It's people who don't know you that tend to get a little rattled in my experience.
Total Receipts: $90.65
PayPal Fees: $5.47
Net Balance: $85.18
Below Goal: $214.82
28%
