Juice Level 3 Challenge: 2018 version, April 1-30
an0nemus · 234 · 11130
ph Offline an0nemus
  • I Tool Therefore I Am
Re: Juice Level 3 Challenge: 2018 version, April 1-30
Reply #120 on: April 20, 2018, 04:01:30 PM
For Day 18, another package from eBay arrived. Bunch of Nite Ize Hip Clips I'm going to resell
hu Offline Exeter
Reply #121 on: April 20, 2018, 10:02:54 PM
Day 15
Very busy day with work, but a very quiet one for the Juice, so just a photo from earlier for today.
Reply #122 on: April 20, 2018, 10:16:58 PM
Awlways seems to be a use for scissors.  :tu:
ph Offline MrWilson
  • just another SAK EDC'er
Reply #123 on: April 21, 2018, 03:57:27 PM
Day 05
It's the weekend so my Juice did kitchen duties. I sharpened the can opener tool to have an edge. I used the file to do this. This made opening a can much better than the first time.
ph Offline an0nemus
Reply #124 on: April 21, 2018, 04:01:34 PM
For my Day 19, did nothing much but posed next to debit cards to illustrate its size in an Facebook discussion
hu Offline Exeter
Reply #125 on: April 21, 2018, 05:50:50 PM
Day 16
Had to remove a couple of nails from the wall. One was easy to pull out by hand, but the other one was pretty stubborn - and very uncomfortable to squeeze with fingers - so the Juice's pliers came into play the first time in this challenge. Job done.
es Offline ThePeacent
Reply #126 on: April 22, 2018, 03:12:55 PM
Day 16
well done,  :multi: but I must advise you that I irreversibly bent the pliers of my C4 (or CS4, don't remember which) doing that 4 years ago  :oops:
My toys:
Reply #127 on: April 22, 2018, 03:25:14 PM
Day 05
 :2tu:
Reply #128 on: April 22, 2018, 03:30:31 PM
Day 16
 :o  Any pics maybe TP ?
hu Offline Exeter
Reply #129 on: April 22, 2018, 04:42:43 PM
Day 16
Well, fortunately it wasn't THAT stubborn, so I did not need to use the plier as a lever, I only needed it to grip and pull. I mean at least I take it yours got bent while the plier head provided leverage pressed against the surface. But of course correct me if I imagined it wrong.
ph Offline MrWilson
Reply #130 on: April 22, 2018, 05:04:55 PM
Day 06
Juice helping me replace the cellidor scales of my Champion plus with a custom wood burl scales I got from a friend modder in Bali, Indonesia. The small driver is helpful in prying out the old scales. My Champion now looks awesome!
hu Offline Exeter
Reply #131 on: April 22, 2018, 05:08:46 PM
It most definitely does! Wow, very-very nice!  :o :drool:
ph Offline an0nemus
Reply #132 on: April 22, 2018, 05:18:16 PM
Drool worthy Champion, indeed!
ph Offline an0nemus
Reply #133 on: April 22, 2018, 05:32:48 PM
For Day 20, had to use my adapter and pliers to remove an old latch. Whew.
hu Offline Exeter
Reply #134 on: April 22, 2018, 07:41:23 PM
Day 17
I've been posting left and right on the forum this afternoon, but almost forgot the challenge post. :) No task for the Juice today, but a photo and a question: is this corkscrew bent a bit outwards or is it not? I can't decide. ??? I mean it looks like it's leaning outwards a bit, but I don't have anything to compare it to. Is it like by default from the factory or did this come from carry/(ab)use?
EDIT: Added two, better pictures.
« Last Edit: April 22, 2018, 07:52:05 PM by Exeter »
Reply #135 on: April 22, 2018, 07:52:36 PM
More great pics and uses guys :like: :like:
Reply #136 on: April 22, 2018, 08:14:13 PM
Day 17
Hi Exeter,
yes, it's normal.
Here are some pics of mine...
But you can push it back  ::)
hu Offline Exeter
Reply #137 on: April 22, 2018, 08:51:00 PM
Day 17
Hi Exeter,
yes, it's normal.
Thanks Matt! :tu: And it makes sense, as the can opener has to fit somewhere and that pushes the corkscrew out a bit, also, looking down right into the spiral it looks straight, still, closed it just looks a bit weird, so it was impossible to figure out if it's okay or not, but now I can sleep well. :) I can't push it in like that though, but I guess I can live with that. :D
ph Offline an0nemus
Reply #138 on: April 23, 2018, 12:19:25 PM
Day 17
Hi Exeter,
yes, it's normal.
I'm keen on reading your thoughts about the bulk of your Juice at the end of our challenge
For my Day 21, used the scissors to nip a ziptie
ph Offline MrWilson
Reply #139 on: April 23, 2018, 04:01:53 PM
Day 07
Today is the last day of my challenge. I did not have the chance to use my Juice today but I took it out this morning for an outdoor shot in the yard. I thought it will be good to give my reflection of carrying the Juice as my EDC for 7 straight days.
What I like of the Juice
Size and width. I like the Juice to carry in my pocket. Not so thick and not too long as well. As an EDC, this is my first criteria—how comfortable the MT is inside my pocket. I am liking its size and thickness so far.
Pliers—I really like it knowing that whenever I need the plier, I have something dependable inside my pocket to do the job. When I repaired my partner’s broken eyeglasses—I used the pliers to straighten the frame before fixing it.
Blade- I am really impressed with the razor sharp blade. It cuts through paper and packaging like cheese. And they stay sharp for long.
Cork screw—I really like to use the CS of the Juice with the can opener used to hold on to a bottle to give that extra leverage. I did not had a chance to do this week. I think this will make this a better CS than the SAK. But I don’t know. I need to test it in the later days.
What I missed from carrying a SAK instead of this Juice
Scissors—for an EDC, I really think an MT has to have a scissors. Maybe I should swap this version of the Juice for a version with scissors.
The can opener—needs to be sharpen a bit to have that ability to make initial cut into the can. I have sharpened mine and I have experienced a huge difference. But I still like the can opener of the SAK—it leaves smooth edges on the can.
Overall, I like my experience and I will probably trade my Juice C2 for a version with more tools specially one with the scissors. I like to keep the CS though.
Thanks to an0nemus and good luck to all mates who are still continuing this challenge.
hu Offline Exeter
Reply #140 on: April 23, 2018, 07:40:53 PM
Day 18
Got new allergy medication today, used the Juice's scissors to cut two pills off the blister, one to each of my two pill containers, just in case.
hu Offline Exeter
Reply #141 on: April 23, 2018, 07:44:41 PM
Day 07
Well done, MrWilson! And yeah, I agree about scissors, a non-specialezed type multitool isn't complete for me witout them either. (How silly is that they left them off of the Rebar for example?)
Reply #142 on: April 23, 2018, 11:42:50 PM
Day 07
Congrats for finishing the 7 day Juice challenge.
Add thanks for the great writeup  :like:
ph Offline MrWilson
Reply #143 on: April 24, 2018, 04:08:13 AM
[/quote]
[/quote]
Thanks and good luck!
se Offline stoneshank
Reply #144 on: April 24, 2018, 04:16:38 AM
Will done guys! If the postal system gets its act together I might join in later.
~ i love whittling and SAK's  ~
Reply #145 on: April 24, 2018, 04:42:50 AM
Congrats  Mr.Wilson, badge awarded  :tu:
ph Offline MrWilson
Reply #146 on: April 24, 2018, 05:06:56 AM
Thanks SteveC! Much appreciated.
ph Offline an0nemus
Reply #147 on: April 24, 2018, 06:39:18 AM
Congrats, MrWilson and thank you for joining us in the Challenge! Couldn't agree more with your thoughts about our Juice
ph Offline an0nemus
Reply #148 on: April 24, 2018, 06:39:45 AM
I sure hope you'll be able to join us soon!
Reply #149 on: April 24, 2018, 11:59:12 AM
Great thoughts MrWilson and congrats on the badge :like: :like:
Total Receipts: $66.45
PayPal Fees: $3.99
Net Balance: $62.46
Below Goal: $237.54
21%
