The best firesteel striker ever
jzmtl · 10 · 4485
ca Offline jzmtl
on: December 09, 2008, 03:02:22 AM
I just tried to use a carbide knife sharpener on firesteel. This thing is nuts! The best I could do with a hacksaw striker is some spark shower (the spine of hacksaw is sharpened), but the carbide sharpener scrapes off so much material they actually becomes tiny molten fire balls and roll around for a second or two! I scraped toward a piece of printer paper and one of the balls burned a hole through the paper! I haven't tried this outside yet (because it's -16°C out) but with this you probably won't even need any prepared tinder, just any dry stuff will do.
I'm not talking about those pull through sharpeners but this (or one of the clone/rebadges which is what I have).
is a video I made compare hacksaw and carbide sharpener.
Re: The best firesteel striker ever
Reply #1 on: December 09, 2008, 08:04:26 AM
The best striker I've used to date it the spine of the F1 :)
I swear you could practically weld with it :D
ca Offline jzmtl
Reply #2 on: December 09, 2008, 10:10:04 AM
I've tried knife spine too, but trust me, it doesn't come near what the carbide sharpener can do.
Reply #3 on: December 09, 2008, 06:11:11 PM
I'll bet it doesn't :D
Doesn't it wear out the ferro rod faster though :think:
ca Offline jzmtl
Reply #4 on: December 09, 2008, 10:30:10 PM
I'm sure it does, but they aren't that expensive, and if it lights stuff up easier this way why not.
Reply #5 on: December 09, 2008, 10:32:04 PM
Well if your cold, wet and needing to get a fire going sharpish, that could be just the thing :)
  • Benner fan club #003
Reply #6 on: December 10, 2008, 01:20:59 AM
If you carry one don't forget their original function...sharpening and steeling...multifunctional is good :tu:
« Last Edit: December 10, 2008, 01:22:33 AM by SporK »
Offline Leatherman123
Reply #7 on: December 10, 2008, 01:21:27 AM
How do those sharpeners work exactly?
B
Reply #8 on: December 10, 2008, 01:39:12 AM
Using the sharp corner of the insert leading will actually scrape metal away. Dragging the sharpener lightly with the corner trailing will work as a steel for freshening an edge.
It's really intended for coarse sharpening of garden tools like Machetes, Axes, Shears etc...it will do in a pinch for knife blades if you know what you're doing and you have nothing else available.
Corona Sharpener Instructions PDF
us Offline Smitty44
Reply #9 on: December 10, 2008, 06:15:04 AM
I have the corona carbide sharpener also,I use it for all my garden tools,scissors,and on knives that are really worn down,it's one of my favorite tools. :salute:
« Last Edit: December 11, 2008, 05:50:55 AM by Smitty44 »
Total Receipts: $0.00
PayPal Fees: $0.00
Net Balance: $0.00
Below Goal: $300.00
 0%
