The Farmer X Double Secret Adventure Society
Jothra · 478 · 80221
de Offline ulzhan
  • The Spirit of Central Asia
Re: The Farmer X Double Secret Adventure Society
Reply #120 on: August 05, 2020, 09:21:38 PM
I'm in, too.
Yay!
us Offline 39hotrod
Reply #122 on: August 06, 2020, 01:48:32 PM
All who wander are not lost..
It only take a little bit of sharp..
nz Offline Storm
Reply #123 on: August 06, 2020, 08:50:34 PM
Another winner? How many winners can there be?
Dunno, how many units has Victorinox shipped ?  :P
ca Offline Jothra
  • Queen's Venturer
Reply #124 on: August 07, 2020, 04:23:03 AM
I'm not sure, but I don't think you'd ask unless the number is really low or really high.
nz Offline Storm
Reply #125 on: August 09, 2020, 02:49:00 AM
Round these parts the numbers per members are really high I should think  :rofl:
ca Offline Jazz
Reply #126 on: August 16, 2020, 10:31:08 PM
Would someone please post a top down end to end pic of a Farmer X and a Climber? I think even the Climber is thicker.  I’m on the verge of getting a Farmer X, but need some help. Thanks ahead.  8)
us Offline Frailer
Reply #127 on: August 17, 2020, 03:24:25 AM
I don’t own a Climber (I’m a Compact guy), but here is a Farmer X and a Trail Guide. The file layer on the TG is the same width as the opener layer on a Climber, so this should be pretty close. The Farmer X is a wee bit thicker.
ca Offline Altis
Reply #128 on: August 17, 2020, 06:25:04 AM
Keep in mind Victorinox includes the "height" (thickness) of the corkscrew... so the Climber at 18mm is the same body exactly as the Super Tinker at 17mm (which has the T-Phillips instead).
So the climber is probably ever so slightly thinner than the Farmer X, but lacks a layer and has thinner tools instead of the beefier tools of the Farmer X.
Farmer X has become my dedicated outdoors workhorse multitool.  :D
us Online nate j
Reply #129 on: August 26, 2020, 05:49:36 AM
Farmer X colored alox distributor exclusives are starting to show up on US shores!   :mail:
tr Offline ddogu
Reply #130 on: August 26, 2020, 11:16:43 AM
Still hoping for a Farmer X without a saw and a combo tool instead of two openers...
pt Offline MacGyver
Reply #131 on: August 26, 2020, 12:16:57 PM
You mean an Alox Compact...?  :think:
us Online nate j
Reply #132 on: August 26, 2020, 03:17:24 PM
I wouldn’t hold my breath for a 93mm combo tool, but stranger things have happened.  Of course, this would also mean the loss of the outstanding 93mm awl on models with the combo tool.
Also note that the Pioneer X is actually the same thickness as the (cellidor) Compact, though somewhat heavier.
pt Offline MacGyver
Reply #133 on: August 26, 2020, 03:38:40 PM
And IMO the perfect thickness for comfort, both as a knife and as an SD. Anything thinner or thicker is not as comfortable.
I bloody love my PX!!  :tu:
gb Offline SurgeUk
Reply #134 on: August 26, 2020, 05:47:51 PM
:iagree: :salute: :tu:
They don't like it up 'em!
tr Offline ddogu
Reply #135 on: August 27, 2020, 01:20:43 AM
that one doesn't have the awl :(
tr Offline ddogu
Reply #136 on: August 27, 2020, 01:21:54 AM
nah nah the awl is compulsory! And I mean that awesome side awl, not the perpendicular one one the back layer.
maybe a mod would succeed at this?
ca Offline Jothra
  • Queen's Venturer
Reply #137 on: August 27, 2020, 01:31:41 AM
You'd be amazed what you can ream with the fixed blade of the scissors. Like, putting a hole through a chunk of 3/4" plywood. It takes a lot more time and effort, though, and if anything goes wrong you could really donk those scissors up.
My Compact's scissors survived that horror show, but I still switched back to tools with a dedicated awl.
us Online nate j
Reply #138 on: August 27, 2020, 07:29:51 AM
Not totally sure how this would come together... :think:
The 93mm awl shares the layer with the main blade, and is in the same spot that would normally be occupied by the small blade or combo tool (at least on 91mm knives).  It might be possible to leave the 93mm main blade/awl layer alone, and put in a combo tool something like the 111mm Hunter has.  But, unless there is some other tool that would be of great value and be able to share the layer with the combo tool, might as well stick with the stock opener layer.
ca Offline Altis
Reply #139 on: August 27, 2020, 08:27:33 AM
I'm sure it works in a pinch, but the scissors only work so well when the blades lock up tight and smooth. Any warping or loosening might ruin them, and it's one of the thinner tools.  :twak:
You can even awl with the corkscrew in some occasions.
tr Offline ddogu
Reply #140 on: August 27, 2020, 09:09:04 AM
 :( ouch... thank you for the details, maybe I had my hopes too high.
ca Offline Jothra
  • Queen's Venturer
Reply #141 on: August 27, 2020, 09:13:06 AM
...and if anything goes wrong you could really donk those scissors up.
Anyway, doubling back to combo tools and layer savings: I can understand why some people like combo tools, but it's one of only two Victorinox implements I've ever damaged, and the only one I damaged through normal use. I also value the small blade on cellidor models, the awl on alox models, and the two driver sizes on both. Full opener layer for me!
pt Offline MacGyver
Reply #142 on: August 27, 2020, 10:37:22 AM
That's why i said "Alox Compact"....
It's impossible to fit the combo tool in there any other way.
Fitting SAK tools together follows a (mechanical) logic, if one deviates from that logic it just doesn't work...  ;)
us Offline ElevenBlade
Reply #143 on: August 28, 2020, 01:38:39 AM
Alox Compact... Voyageur?
ca Offline Jothra
  • Queen's Venturer
Reply #144 on: September 12, 2020, 03:43:44 AM
I've been trying so hard to come up with a cheesy pun for this post, but it's just no gouda.
us Offline 39hotrod
Reply #145 on: September 12, 2020, 01:28:53 PM
 :like: :cheers:
gb Offline SurgeUk
Reply #146 on: September 12, 2020, 03:32:11 PM
I can see you thought about that post "Caerphilly" :facepalm:
gb Offline SurgeUk
Reply #148 on: September 12, 2020, 08:38:32 PM
Oh, I see what cheddidder.
Clearly Jothra had "Grater" plans for the SAK  :whistle:
us Offline BClogic
Reply #149 on: September 12, 2020, 09:37:53 PM
My goodness you all are getting real cheesy......
Awlways know if the juice is worth the squeeze.
