Some of my Vic scissors only open halfway too. Very annoying. They're riveted too tightly and I've yet to find a way to loosen them. In olden times when they used a screw you could loosen or tighten a little as you pleased.
Ah, I see. The new ones seem to be sturdier though, can you confirm that?
Thanks you all for your reply!Here is a photo of my 91mm scissors after using it a couple times (1 or two quick snips) against my smaller scissors found on my manager. It tends to "stick" to that position and i have to kinda manually separate the scissors if i want a bigger gap. I know it sounds very very trivial, but it hardly seems any better than the smaller scissors found on the SD classics. Whats the point in carrying around a larger pair of scissors if they're just as effective as the small scissors? Hopefully, I'm probably just over-reacting and hopefully loosen over time. Thanks for letting me know about the scissor wobble.
I find the larger scissors a bit sturdier for cutting tough materials (like my fingernails ) than the smaller scissors, and of course they can make the same linear cut length with fewer cycles. I use my thumb to push up on the bottom of the back of the moving arm of the scissors if I want to take a bigger "bite" at something; after carrying 91mm SAKs with scissors for years, this has become second-nature. It would be nice if the spring opened the scissors just a bit wider, though.
I wish they put the Wenger scissors in all the knives.
Agreed about the tight riveting. They do loosen a bit over time. But if you do want to make it a bit looser, you could try removing a very small amount of material where the two parts ‘rub’ and are only visible when the scissors are open ~90°. If the area has roughness, then polishing it all smooth could do the trick. I do have some well used riveted ones that open to more like 1.2 or 1.3 cm on their own. ....But FWIW, the reason I think they riveted the scissors is to prevent breakage and wear from user errors like over tightening...and also mishaps that occur when closing the tool when it’s too loose. When the open tip-to-tip distance is about 1.8 cm to 2.0 mm the back end of lever will jam when you close (put away) the tool. Past about 2.0 cm and closing will push the lever to open the scissor and jam the scissor spring into the back spring or potentially hook the adjacent liners. I suspect this is how many double leaf springs were broken as well as from any mis-alignment of the double leaf spring itself. So I think Victorinox reduced how much the scissors open on their own for specific purpose...to reduce spring breakage and related warrantee repairs.
Hey all! Long time lurker. Big SAK fan
