In looking for a multi-tool to add to my paracord tools, I'd want pliers, scissors, a blade, and very little else. A Leatherman Style PS almost fills that bill; all it's lacking is the blade. In theory, this seems like a very simple mod: disassemble, remove file, install blade, reassemble. However, in practice, there are things to consider: what blade to use, would it need to be re-profiled, is the nail nick on the side opposite of where it should be, are any other parts needed, and probably others. Is this mod feasible, or should I move onto my Plan B?
What you're wanting to do is definitely possible, and while reprofiling the 91 mm blade would work, there might be an easier way to get what you're looking for.
First off, if you don't care about the tweezers, you can just file off the "tweezer guides" from the plastic scale and a squirt/style blade will fit right in.
Not a big fan of the tiny scissors..... they work for very light duty only.. and their springs are extremely prone to breakage for no reason as you can tell from mine.
Nice. That’s almost exactly the ‘what I’d do’ I put in my first post!
Have you tried the scissors on 550 paracord, and if so, how did they perform? Your write-up has me curious. Perhaps I should reconsider my plan A?
I have tried my cheapish paracord before. Doesn't cut nice.
