It's not really "saving the debate" if you state your case while saying you're not going to state your case. 🤨 (https://en.wikipedia.org/wiki/Apophasis)[...]What did you think you were contributing with this reply?
To be fair with Nate, he did state that he isn't aware of anyone on the forum successfully construing a blade lock for 91 mm, so there's your answer to your question. I seem to remember I saw a post where someone built a Opinel-type lock for a 91 mm once, but at least to me it didn't look very practical.By the way, derailing threads are a common occurrence on this forum. Some like it, some don't, but either way it's one of the particularities of the forum, so there is little use getting riled up about it. SAKs are everyone's hobby or interest here, so most members have more or less strong opinions on about every aspect of SAK life. It's what makes this place lively and interesting (at least to me), and given that the tone of the discussions is almost always polite and friendly, you may even end up liking the place all the more for it.
I remember someone (maybe Syph?) attempting to make a 111mm-like liner lock for 91mm knives. If you search the mod squad subforum you should find it.
Ana from Spain did have a fabulous idea incorporating the 111mm liner idea to the mod.
Thanks, that's the one I had in mind
Derailing threads are a common occurrence on this forum.
Carry a 91 mm SAK for the other tools (or even do a blade-less 91 mm mod), and add any single-blade locking folder of your choice as your primary blade
If...you’re determined to build a locking 91 mm...I wish you luck with your project, and hope you’ll post some pics!
Anyone posting here should also check the OP’s other thread.
The purpose of the lock is to ensure the blade doesn't close accidentally while the blade is in-use, if you're pressing hard to cut something and the knife slips.
Hi kamakiri, your remark made me curious. I suppose you mean the "sensible Multi-Tool thread", which I have just read. I now know what you meant...
But yes, I haven’t managed to cut any fingers in use with any folder so far and not in the last 38 years of using SAKs. Can’t say the same of hobby/Exacto knives from right about the same time ago. Still have the scar from that learning experience.
Notice a theme developing here?
I can't imagine how hard you've got to hit a knife to break the lock, but it's got to be a really intentional and hefty amount of force, right?
Could you do something that mods the mainspring and knock up a new large blade to include a notch, then delete the corkscrew/screwdriver and replace it with a standard lockback style lever that pivots where the corkscrew was?That'd be my line of thinking, if I had the skills to make what's in my head.
This can be done, but I wouldn’t try to do it in the ‘last’/back layer where the blades and CS/Phillips are. Not a lot of room for the spring/release mechanisms…but doable and easier, I think, in a different layer.
I tend to find that knives close on peoples' hands not through mis-cutting, but from accidentally catching the spine when holding the knife and switching between cutting tasks.
I thought of that exact location for two reasons:1 - There's already a cutout in the scales/liner, into which you'd depress the end of the lockback lever. 2 - It's effectively the same idea as the Delémont Packlock, albeit executed differently, so it should be fine and still avoids having the release sticking up so much it catches on pockets.
I’m having a tough time visualizing this happening. Can you give a real world example?
I figured that’s what you were getting at. For the travel needed, the cutout is far too large, IMO. Based on 91mm design and using the 3rd/back pin as the lock bar pivot, only ~2mm depth or so would be needed as a cutout. Knife liners for the chisel or old back SD already have a decent cutout for this purpose…and look like a factory-ish assembly.
Unless you have a thumb that is under 2mm wide and/or fingernails of titanium, you'll need a decent size cutout in order to depress the lock bar...
