Buck Strider 881 mini tanto convex regrind
00 Offline kwakster
on: March 21, 2022, 08:23:18 PM
For quite a few years this Buck Strider 881 mini tanto in BG42 steel was gathering dust in a drawer, as to me it was more a knife-like object, literally unable to cut anything.
Over the last few weeks i changed that with the help of my Tormek SB-250 stone (for the point area), a 300 grit diamond file, a Foss 7205 black/green silicon carbide stone, and some 400 grit wet & dry SiC paper on glass (for the straight edge)
The apex on the now full convex blade measures somewhere between 22.5 and 25 degrees inclusive, and i'm first going to do some test cutting to find out if i can safely lower it a bit more.
Also rounded the overly sharp G10 grip plates a bit and sanded the screw heads.
Before:
While grinding the blade with the diamond file:
After the 400 grit SiC paper and removing the tiny burr on a piece of hard cardboard with a dab of 1.0 micron diamond paste:
Considering all work was done with only one eye currently functioning at about 80 % (plus a pair of reading glasses) i'm quite pleased with the result, :-)
Re: Buck Strider 881 mini tanto convex regrind
Reply #1 on: March 21, 2022, 08:26:56 PM
Nicely done!
Reply #2 on: March 21, 2022, 09:24:33 PM
That looks much better now.   :tu:   :like:
se Offline RF52
Reply #3 on: March 21, 2022, 10:08:11 PM
Very nice! Well done :hatsoff:
Reply #4 on: March 22, 2022, 02:20:20 AM
Good work!    :tu:     It looks scary sharp even from here.    :o     :ahhh      :D
us Online SteveC
Reply #5 on: March 22, 2022, 02:21:31 AM
Reply #6 on: March 22, 2022, 02:25:18 AM
Looks excellent.  Very nicely done.   :tu:
00 Offline kwakster
Reply #7 on: March 24, 2022, 01:14:45 PM
I knew beforehand that the outcome wouldn't be everybody's cup of tea, but for me functionality trumps looks every time.
Grinding the rough convex form with the diamond file (without apexing) took a few hours in total.
Most time was spent shaping & smoothing the blade surfaces on the Foss combination stone and the wet & dry paper on glass.
Visually it's still not 100 % perfect, but the current edge already holds up fine whittling an old piece of hard beechwood cutting board.
A few more pics:
