Very interesting test and I'll be following! My own feedback on them (I own several leatherman tools and one older Swisstool):1) The Swisstool has far, far higher fit and finish and better tolerances. If the leatherman tolerances were on a dedicated pocket knife they'd be ridiculed and returned.2) Almost all steel will eventually rust, but the Swisstool has needed far less care than the leatherman tools. The bead blasted blades of the Rebar are particularly bad for this. I once hand-rubbed a bead blast into... a different finish and it fixed this issue, but I don't have the time and patience I did when I was 18.3) Leatherman blade steels tend to hold up better to use, which is no shocker, but realistically this isn't an issue for me since use on my blades is heavily spread around. For the price I'd want a better steel from the Leatherman, I don't expect that to happen on the Vics ever.4) I like OHO tools, this isn't a deal breaker (as multiple LM's I have don't have any), but it's a nice bonus on the Wave. A OHO Spirit with clip is on the list, eventually.5) I really like having access to metal files, I like having the finer diamond file on the Wave, but for cutting I found the ST's metal saw far more effective.6) ST's can be a real PITA when the tools are tight, Leatherman's less so.7) The answer is to have and use both!
if anyone has suggestions on how to test or what to test please let me know. My mind is open, i'm not asking as a leatherman fan boi, I really want to put them to the test. i'm going to go pick more splinters out of my hand.
If you want to turn tight nuts/bolts the locking pliers on the Leatherman Crunch are much better suited than any regular plier type MT, as once you adjust them properly and tighten them down you no longer have to keep squeezing the handles together to stop the pliers slipping (and making nasty metal splinters). When you really need locking pliers the extra time it takes to set up a Crunch is well worth it.Besides, all MTo members need excuses to buy a different MT, don't they ?
I had similar preconceptions about the swisstools.Until not many years ago I didn’t even look twice at a SAK, they were just toys in my (uninformed) view.Naturally I wouldn’t trust a toy company to make a good MT, and the shiny appearance didn’t help, so most of what I felt about SAKs carried over to the Swisstools.
I added a Surge not too long ago, <big snip> what’s worse is that it’s so sloppy compared to my older Leathermans. It’s the only Surge I’ve handled, so maybe it’s a bad sample after all, but it works and I don’t have time to deal with warranty as long as it can carry out what I need it to do.
I have a new Rebar and ST300 incoming, not sure which one to keep yet, but at least I’ll soon have another data point on current LM quality.
LMs that can be very easily replaced I’ve beat on so hard, and I’ve yet to break one. Lost many, but never broken.
I carried and used my Swisstool quite often. I now carry and use my Spirit quite often. They can and do rust.
I modified my Surge to include a chisel since I liked it so much. My main work tools are Spirit on my pants belt, Surge on my work tool belt with Crunch just because.
so after replying to you I decided to go dig in the drawer so I'd have more of an impression of those 2 vs the surge. And i have a few things to add, especially after spending all that time yesterday on the pliers the first thing I noticed on both the rebar and the ST are that the handles are not kind to your hand if you are putting a lot of pressure on the pliers. They have thin metal edges where you grip and dig right into your palm. If you will be wearing gloves you might be ok but they are not rounded and broad like the surge/charge/wave. They bite. I actually got out a blast as well. It's a discontinued tool and it had a novel way around the sharp edges. It added zytel liners to the edges to take the hotspots away and it worked fairly well at that. it is the same length folded and unfolded but 50% thicker than the rebar. and it fits the hand well.
The juices I have and the one I just bought were assembled with rivets like the swisstools, and I think the squirts were similar.
Do tell, what is it that you find sloppy? I have both the first gen and second gen surge and i dug out the second gen (post 2013) and it's large and cumbersome but i'm not finding sloppy. I have the rebar, st200, st300, st300m and i find the rebar just a touch too small and the st300 almost a little too big, If I had to choose between them for a work tool I would probably go with the st300
The lockup of the internal tools is kind of sloppy though. There's noticeable play/lock rock on every tool. Compared to my Spirit that has zero play.. that's not impressive.
I only have one other Leatherman with a bit holder, an older Skeletool CX, and the bit retention on the Surge is, well, actually quite sloppy compared to the Skeletool.
To fold and unfold the pliers feels anything but sloppy. It's really stiff. And to make it worse, the stiffness is very uneven distributed between the two handles, which maybe doesn't sound like a big deal, and it's not the end of the world, but it means I have to pay attention to how much force I'm applying to each handle so I don't bang into something.
so i dug mine out of the drawer again. There is a slight rock in my tools, doesn't seem like it would be more than a mm or so. does your tool have dirt in the catches on the back of the tools?
so i had the same thing with a charge AL and i sort of fixed it myself. if you look there is a retainer on the bit holder and when you are removing and reinserting bits it can get bent so it does not engage with the little slot on the edge of the driver. I did fix it myself without sending it in but it was a serious bitch. you have to pry that little strip of metal out of the housing bend it back towards the bit then reinsert it. If I was you, i would send it in and have leatherman fix it. It's a 3 hands job.
yeah mine was originally like that. i work at a desk and test software so i end up fidgeting alot, so i have taken to fidgeting with one of my leatherman. once you get it worn in. mine move very smooth. I don't lubricate anything until it moves smoothly. even if the resistance is higher than you'd expect. smoothness where it is the same resistance throughout the whole movement is what you want before you lubricate. If you lubricate before that point it will not wear in. I would suggest using water and soap to wash off the lubricant and then move it dry until the stiffness and movement is uniform then lubricate. i use tuff glyde about once every 3 months or so on the tool i am carrying at the time.
I will say, the swisstools I have, an old swisstool x in rough shape, an rs new in packageing, and a spirit. all have resistance, but it is different in that it seems uniform no matter the age or amount of useonce i cleaned and oiled the 24 yr old swisstool x it felt the same as the just out of the packaging swisstool rs. They do not seem to wear in. so that's somewhat of a flawed design by leatherman. but delegating the break in to the user is not always a bad thing.
Not sure how the LM warranty stuff works from Norway, if I have to send it back to HQ myself, I might just find it easier to pull out that 3. arm
List of Popular Acronyms https://r.tapatalk.com/shareLink/topic?share_fid=11325&share_tid=2260&url=https%3A%2F%2Fforum%2Emultitool%2Eorg%2Findex%2Ephp%3Ftopic%3D2260&share_type=t&link_source=app
