Stripped screw on multitool
Offline Trnkggt
  • New User
on: August 03, 2023, 02:06:23 AM
Hello, wanted to regulate the screw but I didnt have exact tool needed, so I used what I could find. Now the screw is stripped and I cant move it with anything. What should I do?
us Offline smiller43147
Re: Stripped screw on multitool
Reply #1 on: August 03, 2023, 02:23:05 AM
I'd start with the right  tool.  You might need to wrap it in a layer of aluminum foil to fit tight.
These usually have locktite on the threads so a little heat might be needed as well.
- Steve
us Offline HarleyXJGuy
Reply #2 on: August 03, 2023, 03:04:28 AM
I wonder how LM warranty would treat that.
Reply #3 on: August 03, 2023, 03:42:58 AM
Welcome to :MTO: :cheers: I would do as stated above by smiller first with the heat and aluminum foil :salute: if that doesn't work then we can try to figure out something else :tu:
Reply #4 on: August 03, 2023, 08:12:40 PM
Cry !   :oops:
gb Offline Cynan
Reply #5 on: August 03, 2023, 09:19:42 PM
Failing all tithe above you could cut a slot in it with a Dremel and then use a flat driver.
If you have a welder you can also weld another bit onto it and turn that, or using a drill press drill it out.
us Offline IMR4198
Reply #6 on: August 03, 2023, 10:03:17 PM
    You could always just say, "Well I buggered this one up" and use it anyway. Tools are tools to me.  Banged up doesn't really bother me.  Even if you get the screw out, you don't have a replacement, right?  There is no reason to think any repair you make will be satisfactory or look good either.
    A factory repair sounds good to me.  I would see how much they would charge, or just say to heck with it and use it as is.  Best wishes G
Reply #7 on: August 05, 2023, 02:01:04 PM
The last time I spoke to Leatherman about this (which admittedly was a while ago, they had nothing set up to charge people for repairs.  I think they just use the warranty service for pretty much anything.
us Offline DIAMOND
  • Sometimes I sits and thinks, sometimes I just sits
Reply #8 on: August 05, 2023, 02:49:10 PM
Ironic, isn't it?  :think:  Isn't this nearly the same thing as us using a multi tool? "Not quite the perfect or right tool for the job." Some times it buggers up the job.  :cry:
The Multi Tool truly defined... a jack of all trades, master of none.
Don't torch me... I carry and use one every day.  :salute:
I do truly feel for the op. I've done this exact thing several times. You'd think I'd learn.  :twak:
MTs: Gerber Dime, Gerber Suspension NXT, PLeatherman Wave, Misc China Cheapos
SAKs: Vic Climber, Vic Classic SD, Vic Classic (non-SD), Engraved 3-blade SAK (given to me as a gift)
Reply #9 on: August 05, 2023, 02:53:56 PM
The full phrase is “a jack of all trades is a master of none, but oftentimes better than a master of one.”
us Offline DIAMOND
Reply #10 on: August 05, 2023, 03:25:15 PM
I love it! Funny, I've never heard the full actual quote. I stand corrected and armed with a new quote. Thanks!
