Giants of June/Big Blades Challenge - June 2024
nate j · 209 · 13753
us Offline TexasAKM
Re: Giants of June/Big Blades Challenge - June 2024
Reply #180 on: June 26, 2024, 12:46:56 PM
Day 22!
My fancy Resilience!
us Offline TexasAKM
Reply #181 on: June 26, 2024, 12:49:40 PM
Day 23!
I cleaned up my Hudson Bay knife.
Reply #182 on: June 26, 2024, 03:45:32 PM
i really dig the Native Chief,thanks for the mini review.
nice setup,easy to access.
us Offline TexasAKM
Reply #183 on: June 26, 2024, 07:23:43 PM
thanks Farmer.
Day 23
Seal Team 3
Love the look of those SOG fixies!   8)   :tu:
us Offline TexasAKM
Reply #184 on: June 26, 2024, 07:31:17 PM
I can spot a few subtle differences. What was done to the one on the left?
Day 25
The Resilience on the left is almost 1/8 inch shorter than the other.  Before I bought it, the tip must have been busted off, but the fix was nicely done.  They reprofiled it well.  I did clean it up a little, though.
Reply #185 on: June 26, 2024, 09:05:57 PM
Thanks man!
Day 26
I got this Tanto in a trade with Joel Bukiewicz (before he became Cut Brooklyn) maybe 15 years back.
It's 1/4 154CM,iirc,11.75 in oal with a 6.5 in blade.
Full flat grind with a convexed cutting edge.
Pretty solid knife,feels great in the hand,mean chopper for the size
Sent from my SM-G965F using Tapatalk
us Offline TexasAKM
Reply #186 on: June 26, 2024, 09:42:06 PM
these posts makes me want to try these pouches  :D
cool shot  :tu:
 :hatsoff: :cheers:
Reply #187 on: June 26, 2024, 11:20:26 PM
Looks good! :like:
Mean chopper for the size...
I believe that! :tu:
Day 26
Opening cat food bags is something I have to do too frequently.
Apparently my hand smelled like cat food after that task, thus Sophie's lack of interest in the No. 12.
us Offline TexasAKM
Reply #188 on: June 27, 2024, 05:02:27 AM
Day 24!
My CS Roach Belly with it's new sheath.
Reply #189 on: June 27, 2024, 09:48:20 PM
Day 27
1 of my favorite smaller Bowie style knives,CS Recon Scout,older Carbon V blade.
I carried this 1 a bit some years ago,but didn't do any outdoorsy type cutting chores with it.
Reply #190 on: June 27, 2024, 11:51:37 PM
The more I see that one, the more I like it. I'd like to forge up something similar, but full tang. :tu:
Another sweet Cold Steel! :like:
Day 27
No Giant usage today, but the No. 12 is looking pretty awesome. It's shown with the No. 6 I briefly thought I'd lost. Instead, I'd inexplicably put it in the closet.
Reply #191 on: June 28, 2024, 03:37:15 AM
Day 24
This is the Junglee Short Sword.  It lives up to its name with a 14 1/2” Teflon-coated AUS-8 blade.
The rubber handle is reasonably comfortable.
The Kydex sheath seems decent quality.  Interestingly, it is quite loose on the blade, i.e. not form-fitted/not designed for a friction fit, relying on gravity and or the retention strap to hold the knife in.
I have to admit that I haven’t carried or used this one.  The only use I can think of would be in a machete type role, and there isn’t much call for that in the woods of PA.
Reply #192 on: June 28, 2024, 04:31:56 AM
Day 25
This is a Case-made C. Platts’ Sons Large Clasp knife.  Its wide blade is about 4 1/4” of ATS-34 steel.
Handle slabs are bone, with a nice color and comfortable jigging.  Bolsters are nickel silver.
I’ve never used or carried this one.  I’m not opposed to doing so, just never really felt the need.
Reply #193 on: June 28, 2024, 05:09:15 AM
Day 26
This is the Cold Steel Pocket Bushman.Its clip point blade is 4 1/2” of 4116 stainless steel.
While it is possible to OHO the knife using the dual thumb studs, it is neither easy nor quick, as the action is extremely stiff (at least out of the box).  It is quicker, easier, and safer to 2HO this knife.
Cold Steel’s Ram Safe lock locks the folder  open very securely, with no blade play in any direction.  It is a bit of a pain to unlock and close, however, as the lock must be pulled back with considerable force (this would be difficult to accomplish without the included paracord) and held there while the blade is started on its closing path.
The handle is surprisingly comfortable, secure, and solid, especially considering it is simply a folded and shaped piece of sheet metal.  It features a pocket clip that can be switched for RH or LH carry, but tip up only.
While perhaps not unexpected for an all-steel knife of this size, the Pocket Bushman tips the scales at 6.6 oz.
I’ve never used or carried this one.  The amount of force required to OHO the knife and the lack of OHC capability make me not want to carry it.  However, if you’re in the market for a large, inexpensive folder that feels like it would stand up to considerable abuse, the Pocket Bushman might be worth a look.
Reply #194 on: June 28, 2024, 09:35:41 PM
Good stuff, Nate! :2tu:
Day 28
A while back, I wondered what barbecue sauce would do to carbon steel. Let's see...
I had to abandon the effort and finish with a brush. The pan wasn't allowing the No. 12 to do its best work. I'm still not sure if the barbecue sauce helped with the patina. :think:
Reply #195 on: June 28, 2024, 10:16:42 PM
Day 28
The Scout's bigger brother
Reply #196 on: June 29, 2024, 04:43:01 AM
Day 27
This is the CRKT Strafe.  It’s 4 5/8” blade is 8Cr13MoV.
The plastic sheath is an interesting design, incorporating a J-hook.  The sheath doesn’t seem like terrible quality, but unfortunately fails the shake test.
I haven’t used or carried this one.  It seems like a cool design, but CRKT just went a little too cheap on the execution.
Reply #197 on: June 29, 2024, 08:24:09 AM
Day 27
looks pretty cool,give it a workout
Reply #198 on: June 29, 2024, 10:24:16 PM
Day 29
Another big un from CS.
The Laredo is a decent Bowie (if you disregard the braided wire/pommel thing),and does work.
A friend of mine had to use 1 in the closest thing to a knife fight we've personally encountered.
My friend was repping hardware a few hours away,in a really dodgy area and stopped after hitting a pothole. As he was checking 1 of the tyres,the other guy yelled "hey",so my friend turned,and intercepted a knife coming at his face/upper chest with his left hand,while simultaneously drawing his Laredo. The other guy got a a few cuts and remembered he left his stove on.
My buddy needed stitches.
We were attending a combatives class together at the time,and my buddy's training and the grace of God saved him from being another statistic.
Reply #199 on: June 29, 2024, 10:39:14 PM
That's quite the blade! :like:
Give it a whirl!
Wi-Fi at the house is OOC. Hopefully I'll be able to post the Day 29 photo before I turn in. Worst-case scenario, it'll have to wait till Monday.
Reply #200 on: June 30, 2024, 01:12:53 AM
And the Wi-Fi is back!
Day 29
The action shot wound up on the cutting room floor, but I used the No. 12 to spread some chili sauce on the rice.
us Offline TexasAKM
Reply #201 on: June 30, 2024, 04:28:50 PM
Day 25!
My nicer Resilience again.
Reply #202 on: June 30, 2024, 06:05:10 PM
I like the red hardware!
This was a great challenge to participate in. The big blades faced down only one task that they couldn't quite handle, so they proved their mettle. Seeing the No. 12 develop its patina was a lot of fun, and it will be seeing additional duty in the kitchen. I'll also take it with me during camping trips (whenever that will be) when food will actually be cooked. The Old Hickory is now my go-to kitchen knife. I enjoyed seeing the many big blades y'awl have collected, and hopefully I'll add a few more to my arsenal. That should be easier after I move.
Thanks to my fellow challengers for making it great, and to Nate for hosting it! :cheers: :hatsoff:
Day 30
For the final official challenge photos, I shall contrast forced vs. naturally developed patina.
us Offline TexasAKM
Reply #203 on: June 30, 2024, 08:53:27 PM
Farmer X-
Thank you!  I bought the red screws off etsy, and the deep pocket clip.  Some of the red has rubbed off one or two of the screws, but in their defense,  I do pull keys and stuff that rub on them out of my pockets.  The titanium deep pocket clip works very well.
Love those Opinels!  And that Old Hickory! Very cool.
Reply #204 on: July 01, 2024, 07:20:12 AM
Day 28
This is the CRKT M40-15.  The 4” CE blade is 1.4116 stainless steel.
The blade sports dual thumb stubs, but I find it easiest and quickest to open it with the flipper tab.
It locks up solidly thanks to CRKT’s Deadbolt lock.  It’s also a cinch to OHC; simply depress the button and give it a little reverse wrist flick.
The action is great.  It’s a fun fidget knife.
F&F isn’t bad, but lacks the refinement I would like to see in a knife at this price point.
I’ve carried and used this one some, but the CE blade makes it less than ideal for a lot of my needs; and at 5.9 oz, you don’t forget you’re carrying it.
Reply #205 on: July 01, 2024, 07:26:06 AM
Day 29
Built a model with my 7 yo son.  The Opinel No. 12 had the perfect edge to trim the plastic mold remnants from the parts.
Reply #206 on: July 01, 2024, 07:28:50 AM
Day 28
That's neat,still has the Carson vibe.
Day 30
A giant for Giants of June
This "Master USA" (made in China) display piece to end the challenge.
91mm Climber for scale.
Reply #207 on: July 01, 2024, 07:40:45 AM
Day 30
This is the Buck 120 General.  It’s 7 3/8” blade could make other knives feel inadequate by comparison.
:-P
This particular version features a DymaLux wood handle, aluminum guard and pommel, and D2 steel.
This knife feels great in the hand.  It’s well-balanced and the handle really locks it in.
I’ve carried this one some, and it typically rides in the console of one of my vehicles, though I haven’t used it much.
The factory sheath doesn’t meet my personal requirements for a knife I’m going to carry, so this one rides around in aftermarket kydex.
It’s been a fun month.  Special thanks to the few, the proud, the brave, who completed this challenge with me:  FX, HARM, and TAKM!
Reply #208 on: July 01, 2024, 07:57:01 AM
Day 30
:-P
cool Buck.
thanks for hosting the challenge Nate.
