Sharpening Angle Mystery
Craig · 21 · 2907
gb Offline Craig
on: March 10, 2009, 10:14:33 PM
After reading Gadget Guy's very useful post on sharpening with a leather strop I have had really good results with a SAK and a Taylor's Eye Witness pen knife using an old wallet and some Autosol. The knives were MUCH sharper as I have ever managed before :D
Then tonight I tried it on a Leatherman Juice -and I just couldn't get it to work :( Try as I might I couldn't get even a half decent edge. So, out came the Lansky and I sharpened the blade at a 20 degrees like I had done with the pen knives. After the Lansky it was better but still not much good. 'No matter I thought, the strop will make all the difference.' It didn't,  several minutes with the leather and polish and , the blade still wasn't even close to a  decent level of sharpness.  ???
I pressed on - another session on the Lansky and more polishing and if anything it was blunter than before ??? ???
The finally, I tried a steeper angle, 25 degrees instead of the 20 I had been using and success!  :D The steeper angle made all the difference. After a Lanskying the blade was finally reasonable sharp. I've had enough for now, when I get around to it I'll put the Juice on the strop and see if I can get it as sharp as the pocket knives.
I don't know why changing the angle made such a difference though. If it was a piece of junk knock off and the edge was folding under as I sharpened it I could understand it, but that didn't seem to be happening. ???
Any ideas?
Prone to daydreaming.
Re: Sharpening Angle Mystery
Reply #1 on: March 10, 2009, 10:20:58 PM
By increasing the angle, your effectively convexing the edge to an even more acute angle :)
Reply #2 on: March 10, 2009, 10:23:00 PM
He did a what now  ???
Reply #3 on: March 10, 2009, 10:28:16 PM
Actually your right, for some reason I read it that he'd increased, not decreased the angle ::)
Maybe it was just the very tip of the edge that needed sharpening, and the rest of the time on the 20 degree angle, you were just removing/wearing down the shoulders :think:
Reply #4 on: March 10, 2009, 10:29:31 PM
I could lie and pretend that I spotted your mistake, but I genuinely didn't understand what you meant.  :D
Reply #5 on: March 10, 2009, 10:31:47 PM
Well I'm not about to call you thicky after my faux pa :D
Reply #6 on: March 10, 2009, 10:48:30 PM
 :think: Yeah looks like it would have helped if he had went to say a 15 degree angle for the back bevel on it then went to the 20 degree angle for the working edge but going to a 25 degree angle seems like would not have solved the problem :ahhh :D
gb Offline Craig
Reply #7 on: March 10, 2009, 10:56:21 PM
[/quote]
[/quote]
That makes sense :)
Reply #8 on: March 10, 2009, 10:57:22 PM
[/quote]
That makes sense :)
[/quote]I'm glad it does to someone :D
Reply #9 on: March 10, 2009, 11:03:20 PM
That makes sense :)
[/quote]
It makes sense to me too, but then I've had a couple.. :drink:
Reply #10 on: March 10, 2009, 11:07:06 PM
That makes sense :)
[/quote]
[/quote]Booze does seem to help people to decipher my ravings :D
us Offline WhichDawg
Reply #11 on: March 11, 2009, 12:22:00 AM
speaking of acute why is everybody messing up the quotes?! :think:
drop the "/" in the first set of brackets! :twak: :D
  • Benner fan club #003
Reply #12 on: March 11, 2009, 01:11:13 AM
I'm not even sure what we're discussing anymore...but I wanted to get a quote in... :D
Reply #13 on: March 11, 2009, 02:08:43 AM
Could be that it was pretty blunt to begin with and you just weren't getting to the edge.  If I find I'm getting nowhere with a blade I take a permanent marker and run it along the edge.  After sharpening if you can still see a black line along the edge you just haven't removed enough metal yet and might be better off going with a coarser stone to get you started.
Alternatively there's all the other stuff that's been misquoted in this thread :P
Neil
Reply #14 on: March 11, 2009, 02:33:21 AM
Neil
 ::) :surrender: :rofl:
Just hope I got the quote right :ahhh :D
Reply #15 on: March 11, 2009, 02:38:05 AM
I think Neil may be on the right track. During the initial sharpening with the coarser stone, you want to go far enough to raise a light burr on one side, then the other to clean up and set the secondary bevel.
Offline crls1
  • I do Exist!!!!
Reply #16 on: March 11, 2009, 02:51:26 AM
Maybe there was a lot of "burned" metal from the initial sharpening in the factory that needed to be removed to get a decent edge. Is it the first time you sharpen this blade?
Carlos
Reply #17 on: March 11, 2009, 03:01:50 AM
Carlos
That seems to be a good point Carlos :tu:
Offline crls1
  • I do Exist!!!!
Reply #18 on: March 11, 2009, 05:44:49 AM
Carlos
Thanks!  :salute: Usually, when i sharpen a new blade, i use a very coarse stone to remove all the steel in the surface, and when i change to finer grits i have better results than when i don't use the coarse stone. Hope this can help.
Carlos
gb Offline Craig
Reply #19 on: March 11, 2009, 07:46:01 PM
Carlos
This is the first time it has been really sharp so you may well be right.  :)
gb Offline Craig
Reply #20 on: March 11, 2009, 07:46:48 PM
Neil
Great tip.Thank you :)
Total Receipts: $21.00
PayPal Fees: $1.42
Net Balance: $19.58
Below Goal: $280.42
