Yup.... so are the scissors on the outrider and workchamp...Sent from my iPhone using Tapatalk
Quote from: jaya_man on August 07, 2017, 03:34:10 AMYup.... so are the scissors on the outrider and workchamp...Sent from my iPhone using TapatalkHi, Jaya_manI appeal to your wisdom. Do you (or anyone) know(s) when the inline Phillips was first added in 111mm???I do have an outrider without it. (Image removed from quote.)Thank you
Quote from: koke on August 07, 2017, 10:43:55 AMQuote from: jaya_man on August 07, 2017, 03:34:10 AMYup.... so are the scissors on the outrider and workchamp...Sent from my iPhone using TapatalkHi, Jaya_manI appeal to your wisdom. Do you (or anyone) know(s) when the inline Phillips was first added in 111mm???I do have an outrider without it. (Image removed from quote.)Thank youWhat's that first model?
That would be the 2017 LE Outrider Damascus... Yes it doesn't have the wood saw...
Quote from: koke on August 07, 2017, 10:43:55 AMQuote from: jaya_man on August 07, 2017, 03:34:10 AMYup.... so are the scissors on the outrider and workchamp...Sent from my iPhone using TapatalkHi, Jaya_manI appeal to your wisdom. Do you (or anyone) know(s) when the inline Phillips was first added in 111mm???I do have an outrider without it. (Image removed from quote.)Thank you+1 Good question. This one also has scissors screw pivot, so maybe the same time as the rivet showed up? For the 91mm that would put it in the early 90's, when the hook was added too?I used to think this Outrider was uncommon, now I see them everywhere.
Quote from: twiliter on August 07, 2017, 12:22:33 PMQuote from: koke on August 07, 2017, 10:43:55 AMQuote from: jaya_man on August 07, 2017, 03:34:10 AMYup.... so are the scissors on the outrider and workchamp...Sent from my iPhone using TapatalkHi, Jaya_manI appeal to your wisdom. Do you (or anyone) know(s) when the inline Phillips was first added in 111mm???I do have an outrider without it. (Image removed from quote.)Thank you+1 Good question. This one also has scissors screw pivot, so maybe the same time as the rivet showed up? For the 91mm that would put it in the early 90's, when the hook was added too?I used to think this Outrider was uncommon, now I see them everywhere. Everywhere... I've only seen two of them .... Yours and mine. :-)I will keep on thinking it's uncommon
