Blackbeard · 5839 · 502525
Reply #240 on: August 27, 2009, 07:11:05 PM
:pok: Need to see the lighter :)
Very much so.
My Fuse and Flat GasBaby helped me resurrect a small lockback today.  Pics will be up once my glue dries.
Looking forward to them pics  :tu:
Reply #241 on: August 27, 2009, 07:15:51 PM
Very much so.
Okey dokey, I'll try and sort some pics of my recent lighters later :)
Reply #242 on: August 27, 2009, 08:01:42 PM
Very much so.
Pics here http://forum.multitool.org/index.php/topic,7623.msg251081.html#new
Magic Bus
  • Guest
Reply #243 on: August 27, 2009, 08:15:52 PM
Good job there mate  :tu:
us Offline HBlaine
  • It does WHAT??
Reply #244 on: August 31, 2009, 09:45:08 PM
Used my SwissChamp's pliers to pick up a ton of old wood staples that escaped during one of my cleanups of the burn cage out on the farm.  I noticed something strange, though.  One of the jaw on the pliers appears to be magnetized.   ???  Anyone else every notice this??
Nothing says extraterrestrial like...
hn Offline cliosguy
  • no nacimos con miedo...
Reply #245 on: August 31, 2009, 11:29:22 PM
used my highlander to bring a HD back to life :)
9/10
A
Offline heavy handed
Reply #246 on: September 01, 2009, 11:20:41 AM
my gf has finally stopped nagging me about carrying a multi tool or a sak all the time, it was here b'day at the weekend and her dad had a bbq to build with no tools, out comes the trusty sak, job done   :D, im even allowed to get a few more now i can justify them.
1-0 multi tool :)
spam Offline GraysonK
Reply #247 on: September 01, 2009, 11:27:28 AM
Yes!  I knew there was hope!
Reply #248 on: September 01, 2009, 12:47:22 PM
 :climber: , im thinking of getting one for each day of the week lol, i never realised when pople know you have a sak on you every one wants to use the corkscrew can/bottle opener,(i let them of course only if it was infront of her :D)
um Offline Mr. Whippy
Reply #249 on: September 02, 2009, 01:58:53 AM
1-0 multi tool :)
Winnar!  :D
ph Offline duckman1975
  • Naked without my multitool!
Reply #250 on: September 02, 2009, 02:07:04 AM
I know what I did is stupid and I know will forget and do it again
heres a tip: Do not use an all metal SURGE to unscrew computer screw without unplugging the computer first even if it is off! :P
hn Offline cliosguy
Reply #251 on: September 02, 2009, 02:10:32 AM
cant say ive been there, but yeah is an easy mistake :D
A
Reply #252 on: September 02, 2009, 02:15:16 AM
Thanks Cman, its nice to know I'm not alone  :D :D :D
Reply #253 on: September 03, 2009, 10:28:30 PM
Used the awl on my Wenger Camper to depress the release catch for the head rest in my bosses car after he broke the catch ::) :D
hn Offline cliosguy
Reply #254 on: September 03, 2009, 10:30:06 PM
ST200 phillips to help install a new switch
10/10 :tu:
A
Reply #255 on: September 03, 2009, 10:32:36 PM
10/10 :tu:
Technosorcery :ahhh :ahhh :ahhh :ahhh
Reply #256 on: September 04, 2009, 12:06:28 AM
Old Vic. Gardener for cutting vinyl flooring round a toilet pan.  I get all the fun jobs :(
us Offline Pacu
Reply #257 on: September 04, 2009, 12:17:36 AM
I used my SOG Paratool to open a server rack to see if the soot from last weeks fire got sucked into the workings. (yes it did) :-\
I used my Farmer to open a slim jim and a pack of Mrs Fields cookies.
:like:    :MTO:
Offline Anthony
  • Improvise.
Reply #258 on: September 04, 2009, 01:15:51 AM
Used my Powerlock to pickup someones old shirts left in the back of a truck :P
Used the bottle opener on my new Wave to open a Sam Adams Blackberry Whitbier...I bought a 6 pack of regular boston ale, but apparently someone did the ol switcheroo in the store and one was this blackberry beer.  It's OK, but I woulden't buy it.
us Offline donvito
Reply #259 on: September 04, 2009, 02:06:10 AM
Fixed a jammed stapler with my Skele.
ca Offline PyroJames
Reply #260 on: September 04, 2009, 04:07:21 AM
LOL
Reply #261 on: September 24, 2009, 03:07:00 AM
So we're doing some renovation work in the basement.  We have a Generator panel that in an emergency, can be run from a generator with a manual disconnect from the powerlines.  We've run for a week that way after Hurricane Isabel a few years ago.
Anyway, we swapped from a standard hot water heater to an on-demand unit and therefore, the breaker for the hot water heater (240V) needs to be replaced with a 120V circuit (in the generator panel).   Since it was gonna be open, I decided to put a dedicated plug to the freezer and a separate one for the computer (instead of having to run extension cords).
I did the whole job with my Cybertimer 41 and Skeletool (Skeletool for cutting wire and pliers work, everything else with the SAK).
Opening the panel box, pulling out 1 circuit and putting in 3 new ones, running the 3 circuits and wiring in the GCFI recepticles.
Reply #262 on: September 25, 2009, 09:57:23 PM
Used the pliers on a clutch to sort out the shredder.  "Someone" had decided to try and shred an address label still attached to a plastic bag  >:(
Offline Blackout
Reply #263 on: September 26, 2009, 02:33:12 AM
I used the flat blade on the Surge to tighten a hose clamp on a fuel line.
Also used the pliers on the Surge to tear off some of those crimp on fuel
line clamps.Then I used those same trusty needle nose pliers, to fish out
a nut off a solenoid that I dropped into a crack.
All of this took place on a generator, that I worked on for six hours today.
Never did get it to run right, but the guy helping me, did manage to set it on fire. >:D
spam Offline Zack
Reply #264 on: September 26, 2009, 02:38:03 AM
I used the Crunch to pull an old stubborn cotter pin to put in the control arm on my John Deere mower, however he cotter pin was too big, so I found a nail, put it in the hole and bent it to hold the arm, so I could finish the job.  Tomorrow I will replace with the correct cotter pin.
00 Offline Freudian Frog
Reply #265 on: September 28, 2009, 05:40:24 PM
No multitool use... but I did saber a jar of pickles with a mora yesterday. :)
Somehow the homemade pickled cucumber process had sealed the lid shut... four burly men attempted to open it to no avail.
So of course I had to saber it. :D
Got those frog legs.
Reply #266 on: September 28, 2009, 05:52:07 PM
Two words:
Strap wrench.  :P
gb Offline Screwtape
  • I am the Toast King!!
Reply #267 on: September 28, 2009, 08:25:49 PM
Dismantled a large cot, broke down and re-build child's bed and constructed a single bed.  All with a Vic Spirit and ratchet
And so the chain of hand me down items continues to flow thought the family.  So who needs a good full size cot?
"Hello! I am the Toast King and I rule over the Moon!"
us Offline David Bowen
  • Multitool Enthusiast
  • Site Manager
Reply #268 on: September 28, 2009, 11:01:20 PM
My zipper on my shorts fell apart earlier, used the crunch to put the metal cover back on it that holds the zipper pull on.
Reply #269 on: September 28, 2009, 11:52:28 PM
Two words:
Strap wrench.  :P
Two words:
Saber
Wait no that's one, how about "more fun", or "glass in teef"?
Total Receipts: $90.65
PayPal Fees: $5.47
Net Balance: $85.18
Below Goal: $214.82
28%
