and from yellow to red
Sean · 20 · 1854
ca Offline Sean
on: April 22, 2010, 03:42:00 AM
Spyderco Pacific Salt dye job yellow to red.  I am happy with the results.
ca Offline Sean
Re: and from yellow to red
Reply #1 on: April 22, 2010, 03:42:41 AM
ca Offline Sean
Reply #2 on: April 22, 2010, 03:42:59 AM
us Offline donvito
Reply #3 on: April 22, 2010, 04:23:38 AM
Looks good :tu:. I did a light green to dark green and left the knife in the dye too long, it came out almost black. Too embarrassed to post pics :ahhh
ca Offline Sean
Reply #4 on: April 22, 2010, 05:02:53 AM
ah that's too bad it didn't turn the color you intended but you should post a pic of it I'm sure if
it's not totally black and you can capture it with a pic it would be pretty cool.  :tu:
Reply #5 on: April 22, 2010, 05:27:55 AM
Looks nice Sean!
ca Offline Sean
Reply #6 on: April 22, 2010, 05:28:54 AM
thanks David. :)
Reply #7 on: April 22, 2010, 05:30:18 AM
Sean still waiting for the Kawasaki GREEN mate  :pok: :pok: :D :D
That looks really nice  8) 8) 8)
Glade the project came good  :D :D :D :D
Reply #8 on: April 22, 2010, 05:48:26 AM
DV my first Salt I I used at work to cut up rework which was mostly a coffee concentrate was turning brown so I soaked it in some stuff we use to clean with and it came out bright yellow again. I wonder if you soaked your knife in some sort of solvent if it would help.
ca Offline Sean
Reply #9 on: April 22, 2010, 05:48:58 AM
Mat,
Dye is cheap, cheap but I'm running out of dye'able knives.  :D  Kawasaki green would be very nice.  :tu:
Reply #10 on: April 22, 2010, 12:06:34 PM
I am considering a green Pacific Salt here myself.
spam Offline GraysonK
Reply #11 on: April 22, 2010, 01:53:42 PM
Isn't that green almost black color like the official state color of South Carolina?  They called it carolina green or something like that.
Offline Styerman
Reply #12 on: April 22, 2010, 04:28:56 PM
Do you have any problems at all with the die "bleeding " or wearing off ?
Chris
ca Offline Sean
Reply #13 on: April 22, 2010, 04:57:39 PM
Chris,
Being totally new to this I can't answer that for sure, however this seems permanent and it's not
on the surface it's absorbed in so I'm hoping it won't fade or bleed.  I can soak it in water and
you don't get any color coming out.
Ben,
I think a nice toxic green like on the Spydie USN would be the green to see if you could match!
Look forward to seeing the results.  :tu:
« Last Edit: April 22, 2010, 04:59:46 PM by Sean »
us Offline Ashley
  • AKA Knife Crazied
Reply #14 on: April 23, 2010, 03:32:30 AM
Ben,
If he can match that green he'll be doing me one also.  :drool:  :2tu:
us Offline Ashley
  • AKA Knife Crazied
Reply #15 on: April 23, 2010, 03:33:57 AM
Ben,
If he can make a lime green like that he'll be making me one also. :drool:  :2tu:
us Offline donvito
Reply #16 on: April 23, 2010, 04:45:38 AM
Don't know I'm from New York :D It's almost black with a hint of green in sunlight. The frn needs to be scratched in order to get to the original color. It's a failure lesson learned for me in both dyeing the handles and coating the blade with Duracoat :o Still looks good though, I will try to scrub some of the color of the handles for a two tone finish. Too lazy to start a thread and crop all the pictures I took of the project. :cheers:
ca Offline Sean
Reply #17 on: April 24, 2010, 04:42:02 PM
Pimped it out a bit more and took the black coating off the titanium clip.
Reply #18 on: April 24, 2010, 10:09:47 PM
Looks great mate.  :)
ca Offline Sean
Reply #19 on: April 24, 2010, 11:09:01 PM
Thanks Ben.
