Livarno, Romisen, C8, Small Sun cheap HID torches
dks · 225 · 73999
Re: Livarno, Romisen, C8, Small Sun cheap HID torches
Reply #120 on: April 04, 2015, 07:49:07 PM
I assume that LEDs like a PD of around 4.5V and 3 batteries can produce that, or maybe it's just for the round shape you can get with 3AAAs close to each other
Reply #121 on: April 04, 2015, 07:52:59 PM
Yeah, but I think these are aimed for the folks than buy and use alkalies. For rechargeable batteries users that's not the ideal combo.
cs Offline Vladimir
Reply #122 on: April 04, 2015, 08:49:50 PM
I have one of those lanterns, and they are surprisingly bright and easy to use.
Great to have around the house.
Reply #123 on: May 16, 2015, 06:22:22 PM
I really like the lanterns mentioned previously and have gotten another 5, to give.
The battery life is very good - a couple of weeks with a few hours of use every night on rechargeables.
....on to new things.
I got this Stanley minitripod 1-95-393, as it was on offer in a shop I was visiting. 3.5 Euro. It was cute and cheap. (other colours are also available)
It is a keychain light that can be used as a regular torch or as a standing torch, on a tripod, and can throw, in that position, a beam at upwards, at 45 degrees and vertically. If you only pull out the front leg you can also make it throw a beam downwards.
The beam is OK but weak by today's standards as the torch uses an old fashion LED (possibly a 0.5W one). It runs on watch style batteries. There are some other similar models with 3 LEDs.
The beam has a very strong purplish tint in the middle and a funny shape.
Only one power setting and no zoom
OK for the money and the "look"
« Last Edit: May 16, 2015, 06:51:41 PM by dks »
Reply #124 on: May 17, 2015, 10:43:57 AM
I remember seeing one of them at a B&Q (a big DIY store) and it was a heck of a lot more than 3.50 Euro!  If I remember correctly it's got a much bigger brother that's marketed at builders and the like.
Reply #125 on: May 17, 2015, 11:09:31 AM
 :pok: enki-ck ?
It is available for sale on amazon UK for £13.5 which is way too much. I do remember seeing them around here for around the same, which is why I never got one before... but for what I paid I am happy as the batteries probably cost as much.
Reply #126 on: May 20, 2015, 10:00:48 PM
What? :P
Do the legs serve as battery tubes? I see a potential problem there with bending or braking the contacts. :think:
Reply #127 on: May 21, 2015, 10:00:23 AM
I was getting worried   :D
No, the batteries are in the torche's head, behind the LED.
« Last Edit: May 21, 2015, 10:02:43 AM by dks »
Reply #128 on: July 10, 2015, 09:32:24 PM
Olight S80 Baton, Cheap - $25 from SPAMCORP
With that you get a branded light, charger, included 26650(3.7V) 400mAh battery, Diffuser, hard case... really the actual light is just a bonus  :D
Looks good. Takes 5h to charge and the battery has to be a specific Olight one, in order for the charger to work.
Other 26650 batteries can be used, but not charged in the light. The olight battery was available for sale for about $11, so if you wanted to, you could have bough an extra one.
Tailstands!
Hidden Strobe
Orange peel reflector
Specs from Olight:
    750 lumens   180 lumens   10 lumens
    2 hrs                   8 hrs                80 hrs
XML Cree LED
No PWM was noticed
Included:
Charger port - the newer olight models come with a charging base
High
Medium
low
with the diffuser on
I decided to take some comparison shots with the SA22 as they are both easy to use, floody, same cost lights.
high
medium for the olight and 3rd stem for the Sa22
low for both
The Olight appears a bit brighter on high (Ceiling Reflection test), with a more white tint. But, it does run on LiIons
Overall a very good buy, for the price.
The included battery and charger make it easy to use for people without LiIon chargers or experience.
The main issue I saw, was that it does not have anything to stop it from rolling, so if you put it down make sure that it is not pushed  :D
« Last Edit: July 10, 2015, 09:49:05 PM by dks »
Reply #129 on: July 10, 2015, 09:48:02 PM
I got a couple more SK68, SPAMCORP edition, in Camouflage
XP-E Cree LED
3 modes, low, high, strobe
Next mode memory..
compared with some other similar models
(see previous posts)
(All on LiIons)
both have similar beams
high and low
with the UltraOk
The ultraOK has a warmer tint and is noticeably brighter
With the Ultrafire
Similar...
Good, shiny, thick anodising
Better quality than the Ultrafire
"Branded"
Very smooth operation, good, smooth threads.
Not very noticeable PWM on low
Overall a good product, though You just buy it for the look - TACTICAL !!!
Reply #130 on: July 10, 2015, 10:59:17 PM
Tailstands!
Hidden Strobe
Specs from Olight:
    2 hrs                   8 hrs                80 hrs
XML Cree LED
No PWM was noticed
Included:
High
Medium
low
high
low for both
$25 is a flipping steal mate!
Reply #131 on: July 10, 2015, 11:12:27 PM
I did post a link at the time... I think they have run out of stock, currently, but they may get them back....
bg Offline N_N_R
Reply #132 on: July 17, 2015, 08:03:16 PM
It took me ages to find this thread.... so eventually I had to go through all dks'  posts (and lemme tell you, he spams a lot [and he spams with lots of pictures, too]), through lots of pictures... through lots of hairy men pictures... to finally arrive here, post a pic of my clone and forget about it.
But those lights are quite nice for their price.
Reply #133 on: July 17, 2015, 08:41:50 PM
There is a link here through my signature  :D
Really, only enki and Gareth read this..... :facepalm:
Good to have some new readers  :salute:
Nice light ; they are classics.
cs Offline Vladimir
Reply #134 on: July 17, 2015, 09:28:38 PM
I also have 2 SK68 torches (black and red), but I'm planning to get few of those camo ones from SPAMCORP...
Reply #135 on: July 17, 2015, 09:34:47 PM
Another regular reader  :D
The camouflage ones are nice. Use the BLF coupon gbblf to get a discount, if they are not on offer...
bg Offline N_N_R
Reply #136 on: July 17, 2015, 09:39:03 PM
I don't even see any signature unless you mean your badges which, true, I don't read or check  :ahhh
Reply #137 on: July 17, 2015, 09:45:23 PM
Maybe you have selected the option not to show signatures.
There are a few MTO links under my posts, in the signature area.
bg Offline N_N_R
Reply #138 on: July 17, 2015, 09:47:41 PM
Ohhh, since there's such an option, I've probably done so, indeed  :facepalm: I like stuff as simple as possible usually  :cheers:
Anyway, if I'd seen the signature, I wouldn't have had the pleasure to browse all the hairy men pics :dd:
Reply #139 on: July 17, 2015, 09:51:42 PM
Good to know you like hairy men....  :2tu:
cs Offline Vladimir
Reply #140 on: July 17, 2015, 10:12:36 PM
I'm a regular reader, although I don't post much...
I like these cheap LED flashlights, and I bought quite a few in the last year:
Convoy C8, Convoy S2+, couple of SK68's and some Nitecore and Xtar chargers along with different size Li Ion batteries.
I do own some more expensive torches, like Surefire, but I lately almost exclusively edc Convoy S2+ and I'm very satisfied with it.
Reply #141 on: July 17, 2015, 10:16:32 PM
I have some branded lights too, but I just use whichever is closer to me.
The cheap ones seem to work just as good as the branded ones  :D
bg Offline N_N_R
Reply #142 on: July 17, 2015, 10:23:26 PM
No thanks, hehe. some people have hair on all the wrong places sigh
bg Offline N_N_R
Reply #143 on: July 17, 2015, 10:24:16 PM
freaking phone and double posts
« Last Edit: July 17, 2015, 10:26:06 PM by N_N_R »
Reply #144 on: July 17, 2015, 10:26:41 PM
You do not have to tell me twice  :rofl:
bg Offline N_N_R
Reply #145 on: July 17, 2015, 10:37:58 PM
rofl
bg Offline N_N_R
Reply #146 on: July 17, 2015, 10:39:26 PM
rofl
Reply #147 on: December 05, 2015, 05:45:40 PM
OK, so after some time I got some lights to give as stocking fillers, though I may keep some for myself.
1st the Nitecore tube, for about $6. There are several proper reviews of them around the forum, by the way.
I got a black, a blue and a pink one.
Specifications:
Max Output
45 lumens
Max Beam Distance
24 m
Max Beam Intensity
150 cd
Max Run time
48 h 0 m / 2 d
LED
High performance LED ???
Battery
Rechargeable Li-ion
Beam color
White light
Length
56.5 mm / 2.22 in
Head Size
21 mm / 0.83 in
Weight
9.6 g / 0.34 oz
You have the option of 1Lm, 45 Lm and through a "secret" menu the option for various setting between these, something that does not seem too useful/clever.
The light will go from low to high, but, it will not stop at high and instead it will start from low again.
A 3rd, 10 Lm, fixed mode, would have been more useful, but less gadgety.
There is an instant turbo mode, from off, if you keep the button pressed,which is just the 45Lm mode, faster/tactical.
It comes with two different sized key rings
It is small, not minuscule, but small.
Here is a comparison picture with a classic
and another one
and one with the definitive SAK
It is light but it does not feel flimsy
The packaging does not say much about charging, but it has the usual USB charging port most phones and tablets have nowadays, microusb, so charging it will be easy.
You connect it, a blue light comes on, and when it goes off it is charged.
The charging port is covered with a rubber cover.
Inside the light you see the battery, which remind me of LiPo batteries used in RC cars/toys, rather than of a LiIon battery.
The wires are also visible
The beam is floody and at small distances it has a weird shape
However, it is bright enough
Compared with the Ultrafire A3 (on high), which produces around 100Lm
on Low there is a difference
but on high not so much
Also compared with another, floody, light
A good buy, which has the backing of a proper company.
« Last Edit: December 05, 2015, 05:46:48 PM by dks »
Reply #148 on: December 05, 2015, 05:55:34 PM
2nd, something cheaper, $0.70.
I am sure replacing the battery will cost more..
It comes in carious colours, and you need to keep the switch pressed for it to give out light (shown here next to a proper SAK  :P  :D )
Compared with the nitecore above (low)
again (high)
Less bright, but decent. It seems to give out about 20Lm.
and compared with a "police" AA light
A classic keychain light, a lot more useful in reality than a fancy multi mode lumen monster
Reply #149 on: January 15, 2016, 09:01:22 PM
BLF Special edition, A6 XPL
Specifications
Product name:   BLF A6 CREE XPL Non-anodized EDC LED Flashlight
Brand:   BLF
Model:   A6
Emitter Brand   CREE
Emitter Type:   XPL
Circuit Driver: A17DD-L FET+1 Driver
Light Tint:   3D (5000K), 1A (6500K), 5A(4000K)
Material:   Non-anodized
Mode:   Group 1:Moon-Low-Med1-Med2-High1-High2-Turbo(Short press<0.5s)
Group 2: Low,Med,High,Turbo (Short press<0.5s)
Moon-Turbo-Tactical Strobe-Battcheck-Bike Flasher (Medium press 0.5s-1.5s)
Battery Configurations:   1 x 18650 battery (not included)
Switch Type:   clicky
Switch Location:   tail of the flashlight
Impact Resistant   1 meter
Max Output:   1600lumens (max) (use 18650 protected power battery)
Working Voltage:   2.8-4.35v
Lens:   Toughened ultra-clear mineral glass
with anti-reflective coating
Reflector:   Orange Peel Reflector
Carrying Clip   included
Waterproof:   IPX-8 waterproof 2 meters
Color:   Silver
Weight:   80g without battery
Size:   120mm x 24mm(length x body diameter)
A good looking torch
Special driver, limited edition with branding on the pill. XPL emitter.
Feels solid and is well finished.
compared with another 18650, small light
came with some accessories
Solid clip
OP reflector
Compared with the Olight S80 on full
The A6 is definitely brighter
It is also brighter than the SA22
Not as bright as the TR 3T6
Clever modes, reasonably easy to use
Battery level mode  :)
Bright but not for long.
The light goes off max after less than a minute.
Even so, it gets hot quickly.
In summary, the main problem with it is that it gets hot quickly and switches to minimum.
I was replacing a socket at nigh in dark room, and after about 5 minutes (including the automatic stepdown) it got so hot it went to minimum, leaving me basically in the dark.
The light is definitely bright but it gets too hot very quickly even in cold weather and uses up power fastly. (Panasonic unprotected, 3400mAh)
It should work better as a bike light, with the wind providing additional cooling.
PWM is not noticeable and the battery check mode is a good addition.
