What did you use your Leatherman for today?
trouthunter · 5189 · 492958
us Offline countrydirt
Re: What did you use your Leatherman for today?
Reply #4620 on: August 21, 2021, 11:44:37 PM
The pliers on my Wave served to pick up half a lizard that the cat delivered in the living room.
us Offline Rich_SD
Reply #4621 on: August 22, 2021, 01:50:10 AM
I used my Skeletool in muddy water to fix a sprinkler head.  I have 2 Skeletools, and this one is heavily used, so I figured it was my most expendable Leatherman.  When I was done, I sprayed it off with the hose, wiped it off, then gave it a good spray of WD40.... as good as new :)
Offline frickinflip
Reply #4622 on: August 23, 2021, 05:22:14 AM
Took my stich off. Used my p2. Got the injury from playing with my sideclip.
Sent from my LE2125 using Tapatalk
us Offline pa_strunk
  • MAJ/APA
Reply #4623 on: August 25, 2021, 12:56:46 AM
Awesome, keep dermabond at my place, but that is more definitive for sure.  :tu: :tu: :tu:
us Offline hsherzfeld
Reply #4624 on: August 25, 2021, 09:01:45 PM
Leatherman giveth, and Leatherman taketh away. The Circle of Life continues...
Boomer Sooner!
Reply #4625 on: August 25, 2021, 09:04:54 PM
My Curl's first cutting job (aside from receipt-cutting sharpness tests): lunch!
Boomer Sooner!
Reply #4626 on: August 27, 2021, 02:52:40 AM
I cut some twine holding a pallet of bales together at the State Fair.
us Offline trouthunter
  • The missing village idiot.
Reply #4627 on: September 01, 2021, 06:26:28 PM
I used my Leatherman Rebar to cut some leather strips.  Leather was to think for my other knives to cut in 1 pass.
ro Offline Raoul Octav
Reply #4628 on: September 05, 2021, 01:51:55 PM
Hello. Juice came handy for my sak pin mod :)
Sanger's laws:
-any problem has more than one resolve!
-by the way you look at the problem, the resolve may change!
-where's a will there's a way !
nz Offline Syncop8r
Reply #4629 on: September 06, 2021, 08:13:17 AM
My OHT has been missing for many months... today I found it whilst moving (again :bnghd: ).
I went to use one of the blades, chose wrong but went with it anyway.
Reply #4630 on: September 07, 2021, 12:31:57 AM
Wave+ helped me on my last Colorado State Fair meal of the year.   Oh and it also cut strings on bales of hay and straw and cut zip ties in signs today
us Offline NetsNJ
Reply #4631 on: September 08, 2021, 11:24:03 PM
Used the awl and Phillips on my rebar to drill some holes in drywall and install a towel rack, respectively.  It just reminded me how badly I want an awl on the wave!
Offline Engineertopi
Reply #4632 on: September 12, 2021, 09:39:12 AM
I always keep atleast one leatherman on my work desk so I am using them daily. Cutting fingernails, opening letters etc.
Wave's diamond file is just superb for small adjustmens. Last fix was to grind a counter part of the door lock little bit bigger to make it work proper. It is difficult to find as good size diamond file as Wave has anywhere. Normal hand tool files are way more thicker and bigger or then they have way too small.
Reply #4633 on: September 12, 2021, 04:10:35 PM
ca Offline AndyS
Reply #4634 on: September 12, 2021, 11:25:26 PM
Cut a bouquet of flowers to fit in a vase that wifey bought.  :salute:
Offline frickinflip
Reply #4635 on: September 13, 2021, 01:33:25 AM
Before getting ready for work. Mother in law's battery wont crank. So Tread and ratchet came in handy. When I couldn't find an extension.
bg Offline DavisNikolov
Reply #4636 on: September 13, 2021, 02:29:36 PM
You know, you are the first one I see actually using a Tread.  :like:
Reply #4637 on: September 13, 2021, 05:56:00 PM
+1
Other than as a piece of jewellery, of course.
 :D :D
Reply #4638 on: September 18, 2021, 08:24:41 PM
Had to clear the grown up weeds and little tree sprouts from in front of the gas meter, so the serrated blade on the Wave+ came to the rescue.  Too small of stuff for the saw.
Offline Yoda mpb
Reply #4639 on: September 18, 2021, 10:26:54 PM
Breaking in a new BO supertool 300.   Used it for for putting up some outside lights today and very happy with it.
Awl was great for making some holes in plastic, small flat head great for terminal blocks, philips for screws, pliers for cutting and stripping wires and handle crimper. Also used the body for banging in some Rawl plugs🤔 excellent tool. Alway stayed away from total inside tools but very happy with the supertool
us Offline PitCarver
  • Average Old Guy.
Reply #4640 on: September 19, 2021, 07:19:35 AM
Had to bend a clip that I bent too far with the hammer.
Super tool to the rescue.
Reply #4641 on: September 19, 2021, 01:28:43 PM
Great uses everyone !   :like: :tu:
Reply #4642 on: September 19, 2021, 03:24:29 PM
 :iagree: :like:
Reply #4643 on: September 24, 2021, 11:53:09 PM
Had a tough weed in the driveway.  Chose the aerated blade rather than the saw.  It worked.
ph Offline Zephon
Reply #4644 on: September 27, 2021, 05:51:22 AM
Pipe repair where valve broke and half was still stuck deep in the PVC pipe. Managed to get the stuck part/s out. Used the Crunch to get rusted parts unstuck to assemble the flush tank and bidet assembly again.
Reply #4645 on: September 27, 2021, 12:19:41 PM
Great uses cd and Zephon :salute: :like:
Reply #4646 on: September 27, 2021, 01:48:45 PM
 :D Never heard it being called that way, had a good laugh. Love the serrated blade on my Leathermans, but prefer using the saw when it's a sawing job - it's just easier to sharpen in my opinion.
Reply #4647 on: September 27, 2021, 05:56:21 PM
I used the bit extender and 5mm hex bit on my Curl to tighten my office chair’s wobbly arm. I made sure to bring the bits to work today specifically for this purpose.
Boomer Sooner!
Offline stugumby
Reply #4648 on: September 27, 2021, 08:11:20 PM
Put new plastic safety shield on the old weedeater and opened several boxes with the works well so far Free P2 and T-4.
ph Offline Zephon
Reply #4649 on: September 28, 2021, 04:42:14 AM
I suddenly remembered that the Crunch in my pocket has a philips driver.
