My turn for some 111mm fun
Syph007 · 59 · 22780
ca Offline Syph007
  • SAK Surgeon
Re: My turn for some 111mm fun
Reply #30 on: November 09, 2013, 07:57:10 PM
If all goes well I should be showing off the re-assembled 111mm shortly. :D
How shortly? :wait:
I had it mocked up fast, but there is a problem.  The phillips drivers each seem to take a bit more than their width in a layer, so the stock liners I was using dont quite work.  I need to shave some off where it rubs and try again.  Also I need to make a notch in the lock release for the cap lifter as its blocking the tab to flip out the long phillips.  It'll work though, just a few tweaks. :D
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
us Offline Marius
Reply #31 on: November 11, 2013, 07:32:13 PM
I always liked the Locksmith and after seeing this thread had to order a non-OH one :D Maybe I will put DD scales on it.
Robert, alox scales for 111 mm would be very, very nice. Even without parts mix between side lock and liner lock models. I like the side lock ones too, I do not see them less solid than their OH brothers - well, except the large flat screwdriver that's a big improvement for me on the later. The main blades are nice for me on both kinds.
de Offline crackout
Reply #32 on: December 16, 2013, 03:40:15 PM
Any news?
Say my name.
ca Offline Syph007
  • SAK Surgeon
Reply #33 on: December 16, 2013, 03:56:28 PM
Well I gotta use the alox scales I made up now, but still havent had a chance to get to it.
ca Offline Syph007
  • SAK Surgeon
Reply #34 on: April 11, 2016, 06:44:36 PM
Well a few years late but thanks to the pioneer x scissors I can finally finish this mod.  :D
This is just the mockup but its good to go and I just have to peen and put scales on.   :tu:
Offline samek
Reply #35 on: April 11, 2016, 09:11:23 PM
My 111 mm mod is quite simmilar, with almost same tools, but with regular scissors  :D
And also with linerlock.
http://forum.multitool.org/index.php/topic,65424.0.html
Samek
us Offline sLaughterMed
Reply #36 on: April 11, 2016, 11:38:18 PM
Noice!
Laughter is the best Medicine
us Offline twiliter
Reply #37 on: April 12, 2016, 02:09:14 AM
I´m going to try a simple "Sentinel Plus" with a blade and opener layer and no backside tools (or maybe the Awl only) as  a first try.
I knew I saw this idea somewhere! Thanks Lowtech!  :hatsoff:
de Offline lowtech
Reply #38 on: April 12, 2016, 09:30:17 AM
I´m about as quick as Robert, though  - All I have is a stash of torn apart knives, spare scales and crazy ideas.  :facepalm:
ca Offline Syph007
  • SAK Surgeon
Reply #39 on: May 03, 2016, 11:03:39 PM
And... finally got around to assembling this.
I put a point on the blade as well as it drives me nuts the come blunt.
Reply #40 on: May 03, 2016, 11:10:50 PM
ooh ! I like that one  :tu:
us Offline HarleyXJGuy
Reply #41 on: May 04, 2016, 02:13:02 AM
You still have my address Robert?
au Offline Grass
  • First, we take Manhattan
Reply #42 on: May 19, 2016, 01:21:26 PM
Hi Syph,
I've been thinking about this and wondering if this sort of thing may be feasible:
1. Start with a Vic Nomad or Centurion
2. Change the blade to a one handed opener
3. Put the scissors and Philips layer in between the blade and the opener layers.
Cheers
de Offline lowtech
Reply #43 on: May 19, 2016, 06:54:43 PM
you will loose the locking feature on the opener layer, but it will be doable.
us Offline tattoosteve99
Reply #44 on: May 19, 2016, 07:46:47 PM
A sentinel later would work for that. Only one locking point ;).
ca Offline Syph007
  • SAK Surgeon
Reply #45 on: May 19, 2016, 08:09:39 PM
Yup or you can bed the lock tab to be straight.  But my goal was to keep the locking feature which is why the scissors layer can't go there.
de Offline lowtech
Reply #46 on: May 19, 2016, 08:29:55 PM
you could use 2 lock liners maybe?!
ca Offline Syph007
  • SAK Surgeon
Reply #47 on: May 19, 2016, 08:36:58 PM
Tried that and it makes it a lot heavier.  They are thick steel liners.
bavaria Offline Tomcat_81
Reply #48 on: May 19, 2016, 08:38:59 PM
« Last Edit: May 19, 2016, 08:40:52 PM by Tomcat_81 »
Sent from my Boconcept sofa, using the 'post'-button
Owing a beer to Whoey since 2016
us Offline wonderwolf
Reply #49 on: May 26, 2016, 01:39:26 AM
Nice! is it possible to do a 111mm with the torx type screws you use in your other builds? what are those called exactly? and where do you get them? I've got some plans to do a 111mm pseudo alox build once I figure out what features I want.
I love my Trekker, kind of want different scales and scissors. Have thought about just getting a Hercules but want to keep it simple and OHO.
"A good plan today is better than a perfect plan tomorrow" - The Edge
at Offline Steelshark
Reply #50 on: May 30, 2016, 12:32:07 PM
@wonderwolf: I've been looking for 111mm Vic's with torx construction for a quite a while now, and I can't make them myself since I don't have the tools/shop (or the experience).
I guess parts can be had from > http://www.knifekits.com/vcom/index.php.
They have pivots and torx screws.
br,
Steel
us Offline Obi1shinobee
Reply #51 on: November 24, 2016, 08:08:28 AM
Any Idea you can put Cybertool into 111 mm?
ca Offline Syph007
  • SAK Surgeon
Reply #52 on: November 24, 2016, 03:35:09 PM
The only way I can see that working is with a custom made backspring.  It's a very wide tool.
Reply #53 on: November 24, 2016, 07:53:58 PM
Yeah need custom made backspring  :facepalm:
us Offline SAK Guy
Reply #54 on: November 24, 2016, 08:34:42 PM
Awesome! What about a double backspring in that bay?
Added: ....with the sides sanded flat to mate perfectly side by side with no liner.  Like a double tool bay on a big 91mm in reverse.
« Last Edit: November 24, 2016, 08:39:03 PM by SAK Guy »
- Robert
Quo Fata Ferunt
Reply #55 on: November 24, 2016, 09:15:02 PM
au Offline Grass
Reply #56 on: December 05, 2016, 10:58:38 AM
Hi All,
Late last night, a rethink of this concept came to me...
3. Put the scissors and Philips layer *in front of* the opener layer.
This would leave the awl in the middle of the back layers, but that should be OK. The access to the opener layer may be a bit tight, but hopefully still viable. If it could work... the ultimate three layer 111mm! ... :o
Cheers
Hi Syph,
Cheers
ca Offline Syph007
  • SAK Surgeon
Reply #57 on: December 05, 2016, 01:43:46 PM
Hi All,
Cheers
Hi Syph,
Cheers
I tried that but the oho blade is too far away to open with one hand.
Also I don't think the can opener would work.
au Offline Grass
Reply #58 on: December 06, 2016, 01:20:05 PM
Hi All,
Cheers
Hi Syph,
Cheers
Doh!
(...thanks for replying to my feeble idea!)
