I did continue to next slim scissor prototype. Added layer but still quite slim:(Image removed from quote.)(Image removed from quote.)Getting to be close to get friend for supertool. Vic "leather". Though don't know how well leather will last on scale.
Troubleshooter:All latest-generation parts, no keyring, fine driver instead of the chisel on the file, and a nail file on the hook.
Yes it will not be long life solution. Leather glued and rivets go quite much through leather. I did leave just scissors and use until have time and idea to make better scale..(Image removed from quote.)
Finished this one with an inline awl. The awl had a broken tip, so I had to shorten it a little.Also working on GAK rebuilds. Top row is all VIC with new blades except for one. Bottom row are mix-and-match rebuilds of other brands...two Adlers, Aitor and a B&H. Still have a pile of them to work on...mostly ICARs
Quote from: Spork, Lord of Lime Jello! on February 02, 2016, 01:18:28 AMFinished this one with an inline awl. The awl had a broken tip, so I had to shorten it a little.Also working on GAK rebuilds. Top row is all VIC with new blades except for one. Bottom row are mix-and-match rebuilds of other brands...two Adlers, Aitor and a B&H. Still have a pile of them to work on...mostly ICARsLovely Spork! Out of interest (as I'm about to embark on a mod myself) did the awl drop in ok as it is?Looking forward to pics of the Woodsmen - my fave SAK!
Quote from: magentus on February 02, 2016, 12:01:59 PMQuote from: Spork, Lord of Lime Jello! on February 02, 2016, 01:18:28 AMFinished this one with an inline awl. The awl had a broken tip, so I had to shorten it a little.Also working on GAK rebuilds. Top row is all VIC with new blades except for one. Bottom row are mix-and-match rebuilds of other brands...two Adlers, Aitor and a B&H. Still have a pile of them to work on...mostly ICARsLovely Spork! Out of interest (as I'm about to embark on a mod myself) did the awl drop in ok as it is?Looking forward to pics of the Woodsmen - my fave SAK! Spring tension is good...walks and talks. I was a little bit apprehensive because of the slightly larger pivot hole and the tang seeming to be a hair thicker, but it seems to work.
It's in the normal position in lieu of the pen blade. I think the reflections in the photo make it look reversed I'll have to take another photo of the blades closed later...
Did you thin down the spacer under the blade tip since the awl is a bit thicker than small blade? I did this on the ones I built, but Im not convinced it was necessary.
Black and red Pioneer, with scissors added and pen blade in place of the can opener.Hand made brass liners and small blade spacer. Note poor finish on edges of scale; thanks Victorinox.
Thank you! Other than drilling the pivot to 3mm and bending the blade inwards to clear the cap lifter it's as standard on the 91mm knives.
