Show off your Sak mod's!
Offline kimchi
Re: Show off your Sak mod's!
Reply #6030 on: June 30, 2023, 06:48:10 PM
I just finished my first SAK mod, a Hiker from which I removed the openers, put the awl where the back Philips was and changed to screwed on G10 scales. It was a bit of a struggle getting the last liner on and I had to bend the saw away from the outside scale but I got there!
Sent from my SAK using Tapatalk
« Last Edit: June 30, 2023, 08:53:55 PM by kimchi »
us Offline PitCarver
  • Average Old Guy.
Reply #6031 on: June 30, 2023, 08:46:48 PM
Nicely done.
Offline kimchi
Reply #6032 on: June 30, 2023, 08:48:56 PM
Nicely done.
Thanks!
« Last Edit: June 30, 2023, 08:54:11 PM by kimchi »
Reply #6033 on: June 30, 2023, 11:41:53 PM
 :like: Keep 'em comin!'
us Offline pa_strunk
  • MAJ/APA
Reply #6034 on: July 11, 2023, 03:33:04 AM
Got the itch to do a two blade SAK mod and need some help naming it. Any thoughts?
se Offline kottskrapa
Reply #6035 on: July 11, 2023, 08:32:10 AM
Nice mod! I have been thinking about doing one with the dual blades but never got around to it. Looks, but I don't have any name suggestions
00 Offline Dutch_Tooler
Reply #6036 on: July 15, 2023, 11:13:19 AM
"Double-edged sword"?
Cheers!
Dutch_Tooler
  • MAJ/APA
Reply #6037 on: July 15, 2023, 03:41:50 PM
“Double edged sword” is far better than anything I could come up with myself.  :dunno: Usually you could say some standard version with  “compact” or “plus” modifier, but “Compact Champion Plus”seems wrong without the magnifying glass. Made this model to be a five layer pocketable SAK to pair with Leatherman Mini or Knipex pliers.
pt Online pfrsantos
Reply #6038 on: July 15, 2023, 06:38:11 PM
How about pfrsantos's EDC SAK? You just have to send it to me, so the name is correct...
 :whistle:
 :D :D :D :D
no Offline nakken
Reply #6039 on: July 15, 2023, 06:58:01 PM
DualSlasher3000 :viking:
I'll show myself out. Great looking SAK though
  • MAJ/APA
Reply #6040 on: July 16, 2023, 06:38:39 AM
You guys are awesome, dual slasher 3000  :viking: it is. I update my will to leave the dual slasher. 3000 in the capable hands of pfrsantos.
fi Offline Pilotsupergrip
Reply #6041 on: July 17, 2023, 08:35:53 AM
Hi
This is my first post to this forum although I've been lurking here for a long time.
Only very minor modding on this Huntsman but the practicality of this tool has been upgraded greatly. Filed a bit the flathead to fit into a Leatherman bit adaptor and added a sewing needle inside the scales with a loop of thread to pull it out. Mostly going to need that needle to dig something out of the skin but as it is a sewing needle I can also sew with it.  Edit: also swapped the scales from my Spartan because I didn´t grow to like the original transparent blue.
Curl, Surge, OHT, Crunch, Micra, Squirt PS4, Style CS, Huntsman, Spartan, Classic SD, Armbar Slim Cut
Offline kimchi
Reply #6042 on: July 17, 2023, 08:44:22 AM
Nice work! How did you get the needle in?
Reply #6043 on: July 17, 2023, 08:53:48 AM
Thanks. The scales have a needle hole where the corkscrew is. Normal/small size sewing needles fit there snug and don´t fall of. Only thing here to know is that if you dont push the needle far enough, when you close the corkscrew it may snap the thread hole as this happened to me. But there is no way to pull the needle out without pliers so thats why I made the loop of thread as a way to pull it out
Offline kimchi
Reply #6044 on: July 17, 2023, 09:17:29 AM
Ah, ok. I wondered if it was the pin hole or if you had modded the scales
no Offline nakken
Reply #6045 on: July 17, 2023, 10:56:49 AM
Nicely done, Pilotsupergrip :tu:
And welcome to :MTO:
pt Online pfrsantos
Reply #6046 on: July 17, 2023, 01:13:18 PM
 :woohoo: :woohoo:
Wait, your will?! Oh man, now I'm torn between wanting it and not wanting it.
pt Online pfrsantos
Reply #6047 on: July 17, 2023, 01:14:52 PM
+1
 :cheers: :tu:
  • MAJ/APA
Reply #6048 on: July 17, 2023, 08:05:43 PM
Hi
Nice mod, if you ever wish to use the Leatherman bit adapter as a T-handle driver it fits perfectly without modification on the 2.5 mm fine screwdriver on back of models like the ranger, craftsman, champion, swisschamp, etc...
« Last Edit: July 17, 2023, 08:12:39 PM by pa_strunk »
Reply #6049 on: July 17, 2023, 08:32:27 PM
Thanks. Didn't know that. I like that I can use the Huntsman as a screwdriver and there is also that torque setting when the flathead is 90 degrees. But if I had one of those sak's there wouldn't be any need for this mod. Btw, I was thinking about buying the Ranger but bought the Huntsman instead several months ago to keep it more compact for edc. On the other hand im still itching for that file as I tend to use file on everything
00 Offline variable
  • Gone Fishing
Reply #6050 on: July 30, 2023, 08:22:23 AM
This is a Delemont version that I just did using ALM Knives titanium scales from E-bay with .110 416ss heat treated pivots from USA Knife Maker.
The Delemont layers I purchased from E-bay. They seem to be from various Delemont versions, I think the S557 and S17. I am really enjoying the inline Phillips.
Reply #6051 on: July 30, 2023, 03:28:00 PM
Interesting,,
00 Offline variable
  • Gone Fishing
Reply #6052 on: July 31, 2023, 05:38:10 AM
Interesting,,
Thanks.
This is what I have done with some of the left over parts last night.
Reply #6053 on: July 31, 2023, 02:21:39 PM
Thanks.
Cool, here’s what I did with a bunch of leftovers, I really wanted to use that carabiner and mini Philips, let alone the nail file and not double bladed,,
00 Offline variable
  • Gone Fishing
Reply #6054 on: July 31, 2023, 03:16:00 PM
Very cool, I really like the carabiner built-in! A nice selection of tools and scales.  :like:
I wish the parts I purchased included scales.  :(
It just included one set of outer plates.
us Offline Enginears
Reply #6055 on: August 01, 2023, 01:27:27 AM
Those are some cool Delemonts guys. I always liked the wrench/phillips layer.
00 Offline variable
  • Gone Fishing
Reply #6056 on: August 01, 2023, 05:55:57 PM
@Enginears, Thanks!
I am enjoying the inline phillips over the t-phillips.
Reply #6057 on: August 01, 2023, 06:53:22 PM
@Enginears, Thanks!
Oh totally! I mean I customized a compact, I switched out the corkscrew for a Philips, cause well,I really just don’t need a corkscrew, but I also added a layer and added a saw to make it my like perfect tool arrangement,,
00 Offline variable
  • Gone Fishing
Reply #6058 on: August 02, 2023, 11:05:24 AM
Funny, I did the opposite switched out the t-phillips  for the corkscrew since I added the wrench / phillips layer for my perfect tool setup. I did not need two phillips or do I. :dunno:
Your builds always look factory mode.  :like:
Reply #6059 on: August 02, 2023, 03:26:27 PM
Why thanks, it’s probably just because I reused the same scales, yeah that one has both the carabiner / Philips and the t-Philips, but I just have absolutely no use for a corkscrew, I fig since the one across from the carabiner is so short having the longer one on the back would be good just in case..  :dunno:
