Cleaning a Mora 2000
Grathr · 37 · 2756
no Offline Grathr
on: December 19, 2014, 02:05:08 PM
A guy at work wanted to throw this Mora 2000 in the trash after it had gotten dull and full of constuction foam. I could not let him do that, and he was happy to let me have it :)
The question is:
What is the best way to remove the construction foam? Acetone?
Do you have any suggestions?
us Offline Luna Knife
Re: Cleaning a Mora 2000
Reply #1 on: December 19, 2014, 03:12:40 PM
scrape off what you can with a blade.  Then use mineral spirits
de Offline RT1969
  • Straight Silver!
Reply #2 on: December 19, 2014, 03:30:13 PM
With no practical experience I would say acetone, too. But maybe a mineral spirit would work, too?
My thoughts: Would acetone attack the handle? I fear you could damage it while cleaning the blade (Not that any other new handle wouldn't look better  :whistle: )
Reply #3 on: December 19, 2014, 04:25:35 PM
I'd also scrape first ( hard plastic ) scraper then use 0000 steel wool then if needed use acetone/mineral sprits or similar.
Congrats on getting this and getting her back in service.
« Last Edit: December 19, 2014, 04:27:54 PM by Aloha007 »
no Offline Grathr
Reply #4 on: December 19, 2014, 05:46:18 PM
Thanks for the suggestions!
Ill post pics of the result!
Reply #5 on: December 19, 2014, 11:18:36 PM
Is it stainless or carbon?
us Offline JAfromMn
  • Stranger in a Strange Land
Reply #6 on: December 19, 2014, 11:51:51 PM
I'd  scrape most of it off with a razor blade then use a scotch Brite pad soap and water for cleaning the rest.
Or try
Household Alcohol might melt foam but I can't remember. I work with that crap .Denatured alcohol will
« Last Edit: December 19, 2014, 11:59:45 PM by JAfromMn »
Defend the Hive!!!
Reply #7 on: December 20, 2014, 02:19:36 AM
Gas might melt it off.
Reply #8 on: December 20, 2014, 06:19:47 AM
I would try nail polish remover (acetone) to clean off the blade, but would be careful not to get any on the handle.
The Mora 2000 is stainless.
no Offline Grathr
Reply #9 on: December 20, 2014, 07:24:29 AM
Just for fun I stuck the blade in a glass of Cola Zero over night.
This morning i took it out and tried to scrape the foam off with a spatula.
It came off in big flakes with no effort at all
fi Offline Crow
Reply #10 on: December 20, 2014, 07:45:53 AM
Seriously?  ???
us Offline captain spaulding
Reply #11 on: December 20, 2014, 07:52:33 AM
Excellent. Now take it back to work and use it in front of the guy who wanted to throw it away.  :rofl:
I'm the milk man!
gb Offline greenbear
Reply #12 on: December 20, 2014, 07:56:03 AM
Right result, I only just read this thread and am quite relieved to see you didn't end up using acetone as it has some well documented problems when in contact with human skin, and would have been likely to soak into the handle material.
On the subject of coke you can also clean chrome with it and,.....your toilet. If you pour a litre of the cheapest coke you can buy into the toilet and leave it overnight it will remove all the limescale without damaging the vitreous porcelain from which it is made  :D
us Offline HarleyXJGuy
Reply #13 on: December 20, 2014, 08:54:25 AM
Makes me wonder what that stuff is doing to my stomach?
no Offline Grathr
Reply #14 on: December 20, 2014, 09:02:26 AM
Mee too.
Its got to be very clean down there :D
fi Offline Crow
Reply #15 on: December 20, 2014, 09:07:31 AM
Maybe giving your G-shock test a dip for 48 hours.
no Offline Grathr
Reply #16 on: December 20, 2014, 09:46:22 AM
I like the way you think! :tu:
de Offline RT1969
  • Straight Silver!
Reply #17 on: December 20, 2014, 11:08:18 AM
Great result!  :tu:
Thanks for sharing.  :drink:
Reply #18 on: December 20, 2014, 01:36:34 PM
Excellent. :tu:
Captain, weren't you doing some tests with Cola too a while back?
Reply #19 on: December 20, 2014, 03:57:44 PM
Nice Cleanup Job :tu:
did you sharpen yet?
Reply #20 on: December 20, 2014, 03:59:34 PM
Wow, that cleaned up well.
no Offline Grathr
Reply #21 on: December 20, 2014, 04:37:02 PM
No, I havent sharpened it yet. I will try to get it done within a couple of days.
Reply #22 on: December 20, 2014, 08:17:24 PM
Grathr, great job with the coke, I am surprised how well it turned out and one more use for coke for cleaning.  :tu:
us Offline deputy tom
Reply #23 on: December 20, 2014, 09:57:05 PM
Nice outcome. Did he give you the sheath as well? tom.
Thig crioch air an t-saoghal ach mairidh gaol agus ceòl The world will come to an end but music and love will endure
ch Offline Etherealicer
Reply #24 on: December 20, 2014, 10:01:32 PM
Thats what gloves are for... no seriously, its like with any machine you cleaned  thoroughly, you need to grease it afterwards :P. Acetone primarily dries out your skin. It also removes the protective layer, but if you don't do it on a regular base you're fine.
Reply #25 on: December 20, 2014, 10:08:10 PM
Mee too.
Well, stomach acid is no joke either it has a pH as low as 1.5, coke has merely a pH of 2.5. Stomach controls the pH level with proton pumps and it secretes mucus and bicarbonate to protect itself.
Reply #26 on: December 21, 2014, 08:48:21 AM
Excellent. :tu:
Sure was. I did a Fuse, Sideclip, and I think a Swisstool. Results were pretty good for removing rust. Syph did a test on black oxide to see if it would remove the black oxide coating and it did not so it should be safe on black oxide as well.
I'm the milk man!
no Offline Grathr
Reply #27 on: December 21, 2014, 09:03:40 AM
Excellent. :tu:
Thats nice to now :tu:
no Offline Grathr
Reply #28 on: December 23, 2014, 07:35:41 AM
5minutes on my spyderco pocket sharpener and the the Mora is nice and sharp again. :)
Reply #29 on: December 23, 2014, 11:59:38 AM
Only on MTO can we have 30 replies to a thread about someone cleaning some gunk off a knife lol.
