Five Minute Walking Stick Wrap
bdAmmo · 47 · 3972
us Offline bdAmmo
on: January 05, 2016, 09:32:06 PM
I use a walking stick quite often in the summer, most of the time while I'm wading the rivers on my almost daily pursuit of pacific salmon.  River currents can be very deceiving and I've found a walking stick is a lifesaver in those swift currents rushing over slippery rocks.
Here's my quick five minute KISS para cord wrap for a walking stick.
I started off with a nice piece of birch that was sitting in my garage that I cut and stripped a few months ago.  I put a quick stain on it the other day for a different look, without stain the wood was almost white. I'm not sure about the hardness of birch wood but I've been using a birch walking stick for a couple seasons and its held up great.
The first step is to lay the cord out and tape it in position.
Second, start wrapping making sure to keep the cord tight and adjusting the cord underneath as necessary to keep it in a straight line.
After the first few wraps, the lower piece of tape can be discarded.
Once you have it wrapped up to the upper tape, remove it.
Wrap all the way up to nearly the top of the cord, leave just enough to feed the cord through the loop.  Make sure to keep the cord tight.
Grab your Leatherman and pull the cord at the bottom of the wrap to tighten the loop at the top cinching the loop at the top closed.
Next I fed the cord through the hole I drilled and tied a simple overhand knot.
After pulling the cord from the bottom again to make sure I got it good and tight, I trimmed the cord and melted the ends as pictured.
Well that's pretty much it.  A quick, simple and clean para cord wrap.
Re: Five Minute Walking Stick Wrap
Reply #1 on: January 05, 2016, 09:41:30 PM
Nice work !
Reply #2 on: January 05, 2016, 09:57:43 PM
Excellent work.  I too am a big fan of walking sticks when out on the trails. It's never a bad idea to have an extra point of contact or cordage  :tu:
us Offline bdAmmo
Reply #3 on: January 05, 2016, 10:13:20 PM
Thanks guys :tu:.
Reply #4 on: January 05, 2016, 10:16:32 PM
Nice work! I believe pouring boiling water over it will make the cord shrink somewhat, and tighten up so it doesn't start shifting over time
Reply #5 on: January 05, 2016, 10:19:57 PM
Great thread :salute:
I should do that to my staff before the spring!
Reply #6 on: January 05, 2016, 10:32:38 PM
What is the carabiner for?   :pok:
us Offline bdAmmo
Reply #7 on: January 05, 2016, 10:44:36 PM
One of the rivers that I fish often is extremely muddy.  I jam that walking stick in the mud and use the carabiner to hold my stringer of fish. Works out great for me, many other people just tie their stringers around their waist or leg.
Reply #8 on: January 05, 2016, 10:45:08 PM
You've definitely got me thinking about doing the same now.  Nice walk-through. :cheers:
us Offline bdAmmo
Reply #9 on: January 05, 2016, 10:48:52 PM
I've heard that as well but never tried it.  Maybe I'll give it a go :think:
Reply #10 on: January 05, 2016, 10:49:28 PM
That makes sense. I'm really hanging out for fishing mission. Might try and sneak out tonight for a couple hours.   :ninja:
us Offline bdAmmo
Reply #11 on: January 05, 2016, 10:53:25 PM
Thanks gents :salute:
Also, I forgot to mention that I started off with about 20 feet of cord for that wrap.
Reply #12 on: January 06, 2016, 01:28:22 AM
And that wrap gives you a supply of cordage for emergencies - arm sling, trauma dressing, wound closure, etc.  I'm not a big fan of paracord bracelets, but you have a practical usage for the paracord in addition to any emergency usage.
us Offline bdAmmo
Reply #13 on: January 06, 2016, 05:09:27 AM
Absolutely!  Not a big fan of bracelets either but I really like to have the cord at my disposal.  I've used paracord several times while out camping/fishing, usually just for tying up tarps for rain/windbreaks or for stringing between a couple trees to hang my waders to dry. Luckily, I haven't had to use any for first aid but it's there if the need arises.
us Offline bdAmmo
Reply #14 on: January 06, 2016, 05:10:58 AM
Went ahead and poured some boiling water over the wrap, tightened up very well :salute:.
Reply #15 on: January 06, 2016, 09:02:46 AM
Excellent! Glad it worked out well  :cheers:
Reply #16 on: January 06, 2016, 12:35:50 PM
Looking good.  :salute:
ca Offline derekmac
  • Little to the right...
Reply #17 on: January 06, 2016, 03:55:22 PM
That looks great!
no Offline Grathr
Reply #18 on: January 06, 2016, 04:29:11 PM
That looks good! I might have to try that my self
Reply #19 on: January 06, 2016, 05:59:06 PM
Nice neat job there BD  :salute:
Reply #20 on: January 06, 2016, 05:59:42 PM
Nice job! :tu:
I did the same on my walking stick, but I put a few things on the stick(zip ties,razor blade, fishing line, and a few other things) then wrapped over them, you'd never know their there, except the zip ties that show at the top.. I also made one of those rock fling things as a wrist  rest.
us Offline bdAmmo
Reply #21 on: January 06, 2016, 06:03:09 PM
That looks great!
Thanks guys!
Here's the final product after the cord was allowed to dry overnight.  I had it wrapped up pretty tight in the first place but that hot water sure did have an effect. This grip is solid, probably won't be able to tell from the picture though.
us Offline bdAmmo
Reply #22 on: January 06, 2016, 06:03:54 PM
us Offline bdAmmo
Reply #23 on: January 06, 2016, 06:04:57 PM
Nice job! :tu:
Great idea! :tu:
Reply #24 on: January 06, 2016, 06:14:31 PM
I'm going to have to find mine now and try this  :salute:
Reply #25 on: January 06, 2016, 06:38:51 PM
Nice work! This is my favorite method for wrapping cord on my staffs. Thanks for sharing.
scotland Offline Boaz
Reply #26 on: January 06, 2016, 08:19:08 PM
Nice job, I love seeing all the different types of cord projects. Cheers.
us Offline bdAmmo
Reply #27 on: January 07, 2016, 01:05:13 AM
Thanks fellas :salute:
Reply #28 on: January 07, 2016, 02:14:37 AM
Yeah, I love walking sticks and canes. I can't seem to stop adding the odd one here and there whenever I stumble upon a new one.
I can only imagine how much worse it would be if I made my own.  :facepalm:
us Offline bdAmmo
Reply #29 on: January 07, 2016, 05:54:00 AM
I'm not one bit surprised that you collect walking sticks too. :D :tu:  Making your own could be a new hobby for you.  I've thought about it...  I could make a bunch over the winter time and when fishing season hits, take them down to the Russian River and sell them for $20 a pop!  Shoot, maybe I could slap a "Made in Alaska" sticker on them and charge extra. :think:
