The wire cutter at the joint of the pliers (all the way down for max torque) won't do it?
Ok, so I did it quick and dirty and probably a little bit farther away from the rivet than optimal and it does "stick" where the two cutting edges meet since there is now a notch there. On the good side is that the problem should be lesser if the notch was done further in and the fact that that part of the scissors won't engage during normal use anyway (the spring doesn't open it that far). And it does cut guitar string! I didn't cut much so I can't speak of how well it will last or if it will take damage from this but it cuts.(Image removed from quote.)
Quote from: Fortytwo on January 11, 2017, 07:09:35 PMOk, so I did it quick and dirty and probably a little bit farther away from the rivet than optimal and it does "stick" where the two cutting edges meet since there is now a notch there. On the good side is that the problem should be lesser if the notch was done further in and the fact that that part of the scissors won't engage during normal use anyway (the spring doesn't open it that far). And it does cut guitar string! I didn't cut much so I can't speak of how well it will last or if it will take damage from this but it cuts.(Image removed from quote.) Now try bass strings
Cut guitar strings.Seems simple enough, the but Victorinox scissors don't cut it. And neither does the crimper on the pliers. I know there's a video on YouTube showing different ways to cut wire with a SAK, but none of then are appropriate for cutting guitar strings that are still attached to the guitar at both ends. - FiL
Hi, if you don't mind my asking but, why would you want to cut guitar strings with your SAK and risk messing it up? You can get a cheap small wire cutter for that. I have a small wire cutter in all my guitar cases and bigger ones on my tool chest. I would never use a SAK for something like that.
Quote from: Fortytwo on January 11, 2017, 07:09:35 PMOk, so I did it quick and dirty and probably a little bit farther away from the rivet than optimal and it does "stick" where the two cutting edges meet since there is now a notch there. On the good side is that the problem should be lesser if the notch was done further in and the fact that that part of the scissors won't engage during normal use anyway (the spring doesn't open it that far). And it does cut guitar string! I didn't cut much so I can't speak of how well it will last or if it will take damage from this but it cuts.(Image removed from quote.)Those notches are very useful. I make them with a 1/8 inch cylindrical diamond bur. The inside sufaces need a fine stone rubbed against th email to de burr and then they will operate smooth.
Quote from: MacGyver on January 11, 2017, 10:48:21 PMHi, if you don't mind my asking but, why would you want to cut guitar strings with your SAK and risk messing it up? You can get a cheap small wire cutter for that. I have a small wire cutter in all my guitar cases and bigger ones on my tool chest. I would never use a SAK for something like that.I'm hoping to reduce the number of tools I need to carry around. I do have some wirecutters in one of my instrument cases, but I play a lot of different instruments and I don't always have that case with me. But I generally always have a SAK with me. - FiL
Quote from: JamesJ on January 11, 2017, 07:14:32 PMQuote from: Fortytwo on January 11, 2017, 07:09:35 PMOk, so I did it quick and dirty and probably a little bit farther away from the rivet than optimal and it does "stick" where the two cutting edges meet since there is now a notch there. On the good side is that the problem should be lesser if the notch was done further in and the fact that that part of the scissors won't engage during normal use anyway (the spring doesn't open it that far). And it does cut guitar string! I didn't cut much so I can't speak of how well it will last or if it will take damage from this but it cuts.(Image removed from quote.) Now try bass strings Haha, I play with a low B on my bass; might as well try cutting through rebar
Quote from: eddie1115 on January 11, 2017, 08:52:50 PMQuote from: JamesJ on January 11, 2017, 07:14:32 PMQuote from: Fortytwo on January 11, 2017, 07:09:35 PMOk, so I did it quick and dirty and probably a little bit farther away from the rivet than optimal and it does "stick" where the two cutting edges meet since there is now a notch there. On the good side is that the problem should be lesser if the notch was done further in and the fact that that part of the scissors won't engage during normal use anyway (the spring doesn't open it that far). And it does cut guitar string! I didn't cut much so I can't speak of how well it will last or if it will take damage from this but it cuts.(Image removed from quote.) Now try bass strings Haha, I play with a low B on my bass; might as well try cutting through rebar I feel ya on that. I miss my 5er. Of course, the current set of strings on work horse Jazz have been there for years. Back in the 80s, when I was all over Satriani and Vai licks, and gigging for money, I'd change strings every week on at least two guitars. Sent from my SAMSUNG-SM-N900A using Tapatalk
Quote from: eddie1115 on January 11, 2017, 08:52:50 PMQuote from: JamesJ on January 11, 2017, 07:14:32 PMQuote from: Fortytwo on January 11, 2017, 07:09:35 PMOk, so I did it quick and dirty and probably a little bit farther away from the rivet than optimal and it does "stick" where the two cutting edges meet since there is now a notch there. On the good side is that the problem should be lesser if the notch was done further in and the fact that that part of the scissors won't engage during normal use anyway (the spring doesn't open it that far). And it does cut guitar string! I didn't cut much so I can't speak of how well it will last or if it will take damage from this but it cuts.(Image removed from quote.) Now try bass strings Haha, I play with a low B on my bass; might as well try cutting through rebar That's precisely what I used on my bass strings last time I restrung. Worked perfectly with no problem.
Although better availability of SAK scales would be realistic and appreciated. As it is, ebay seems to be the only place to find scales such as the traditional red scales.This is something I wish I could do with an SAK.
Although I understand that the thrust of this thread is what can be accomplished using an SAK (specifically, cutting guitar strings), I couldn't help thinking how wonderful it would be to modify & maintain our SAK to a greater extent than is currently possible.I watched a YouTube video showing a Victorinox representative at a trade show building a knife using a very impressive machine so I appreciate the complexity involved and think Victorinox's long-standing and proven approach is optimum from a business and support point of view. But moving away from this realistic approach of producing "closed" systems that don't lend themselves to user modifications, how cool would it be have Torx fasteners? I would also imagine retail sources for the individual SAK tools and easy availability of SAK scales. Realistic? Probably not. Although better availability of SAK scales would be realistic and appreciated. As it is, ebay seems to be the only place to find scales such as the traditional red scales.This is something I wish I could do with an SAK.
I would point out that there are a couple of people doing this on a regular basis, most noteworthy is of course Syph007 who posted in this topic. His work over in the Mod section is really cool and he's been very helpful to those who wish to follow his excellent example!
Quote from: Mizedog on January 12, 2017, 06:42:48 AMQuote from: eddie1115 on January 11, 2017, 08:52:50 PMQuote from: JamesJ on January 11, 2017, 07:14:32 PMQuote from: Fortytwo on January 11, 2017, 07:09:35 PMOk, so I did it quick and dirty and probably a little bit farther away from the rivet than optimal and it does "stick" where the two cutting edges meet since there is now a notch there. On the good side is that the problem should be lesser if the notch was done further in and the fact that that part of the scissors won't engage during normal use anyway (the spring doesn't open it that far). And it does cut guitar string! I didn't cut much so I can't speak of how well it will last or if it will take damage from this but it cuts.(Image removed from quote.) Now try bass strings Haha, I play with a low B on my bass; might as well try cutting through rebar I feel ya on that. I miss my 5er. Of course, the current set of strings on work horse Jazz have been there for years. Back in the 80s, when I was all over Satriani and Vai licks, and gigging for money, I'd change strings every week on at least two guitars. Sent from my SAMSUNG-SM-N900A using TapatalkYeah, I liked the 5-er as well, to the point that I restrung my P Bass as BEAD, with flatwound strings, which I don't plan on changing for years Quote from: kaput on January 12, 2017, 07:03:57 AMQuote from: eddie1115 on January 11, 2017, 08:52:50 PMQuote from: JamesJ on January 11, 2017, 07:14:32 PMQuote from: Fortytwo on January 11, 2017, 07:09:35 PMOk, so I did it quick and dirty and probably a little bit farther away from the rivet than optimal and it does "stick" where the two cutting edges meet since there is now a notch there. On the good side is that the problem should be lesser if the notch was done further in and the fact that that part of the scissors won't engage during normal use anyway (the spring doesn't open it that far). And it does cut guitar string! I didn't cut much so I can't speak of how well it will last or if it will take damage from this but it cuts.(Image removed from quote.) Now try bass strings Haha, I play with a low B on my bass; might as well try cutting through rebar That's precisely what I used on my bass strings last time I restrung. Worked perfectly with no problem. Haha, after I typed that, I wondered if someone would point that out For what it's worth, I keep a string winder/cutter in my gig bag. But I also make sure to bring the Rebar (or Wave w/ Rebar head) with me when I play.
