EDC'ing a sub $7 folder
Grathr · 15 · 1278
no Offline Grathr
on: June 17, 2017, 07:05:24 PM
To my surprise, you can actually get a good folder for less than $7!
For the last couple of days I have been EDCing a sub $7 SanRenMu 7065RUC-5C, and its actually pretty nice little gentlemans folder.
It was a little gritty to open in the beginning, but it has a solid lockup and no bladeplay.
It also came very sharp, almost spyderco sharp, from the factory.
Im liking it a lot so far. :)
Time will show how well it holds up.
00 Offline Mechanickal
Re: EDC'ing a sub $7 folder
Reply #1 on: June 17, 2017, 07:34:31 PM
Worth looking into! Thanks!
Reply #2 on: June 17, 2017, 07:36:28 PM
wales Offline Smashie
  • In Memoriam
  • Smurf it!
Reply #3 on: June 17, 2017, 07:37:12 PM
They do produce some good knives  :tu:
Si vis pacem, para bellum
Reply #4 on: June 17, 2017, 08:44:47 PM
Nice catch Gaute  :tu:
I have three of their HO2 knives, and they are perfectly fine little knives. I dare say that one of those would handle most of my cutting chores perfectly fine for several years.
es Offline ThePeacent
Reply #5 on: June 17, 2017, 11:59:11 PM
excellent little knives indeed!
better -and cheaper- than Ganzos
My toys:
no Offline Grathr
Reply #6 on: June 18, 2017, 07:06:07 AM
:facepalm:(Image removed from quote.)
They have it on SPAMCORP for $6.06.
Edit:
I totally forgot the spamcorp thing. :facepalm: if you cant find it, send me a PM an ill tell you where I found mine.
« Last Edit: June 18, 2017, 08:03:53 AM by Grathr »
no Offline Grathr
Reply #7 on: July 15, 2017, 07:54:06 PM
A quick update.
This little SRM is still going strong. It needs frequent stropping to stay sharp, but its easy to maintain. The hollow grind makes it a real nice slicer.
It does have one issue thoug. The tip of the blade is just barely under the edge of the scales when closed. That means that you can cut your fingertip when pressing your finger against the opening just infront of the tip of the blade.  Espescially if you drag your finger towards the tip at the same time. See pic below.
I might just grind the point down a bit to fix it.
mx Offline Dragon Lord
  • Follow your dreams they would lead you to happines
Reply #8 on: July 20, 2017, 04:29:50 PM
Sanrenmu make really intresting and unexpensive knives indeed
This one cost $11
Reply #9 on: July 20, 2017, 05:07:11 PM
A quick update.
You could try filing a bit of the part of the blade that hits the stop ( don't know what you call it ). I've done this on a couple of Trad. folders
gr Offline kkokkolis
  • Τετραφάρμακος
Reply #10 on: July 20, 2017, 05:32:15 PM
The basic one has very smart lines.
Reply #11 on: July 20, 2017, 05:38:30 PM
A quick update.
The Kick  :salute: This doesn't always work depending on the tang profile, but it's certainly worth a try  :cheers:
no Offline Grathr
Reply #12 on: July 20, 2017, 06:00:21 PM
A quick update.
Ill have to look into that :tu:
Reply #13 on: July 20, 2017, 06:12:08 PM
note that you need to take off a tiny bit, check, take some more off... and so on, slowly.
 If you take too much off then the nail nick will go too low inside the knife body and you will not be able to use it to open the blade
Reply #14 on: July 20, 2017, 06:51:33 PM
A quick update.
Thanks Al !  I've heard it called that but couldn't remember.
