What lurks in this deep drawer?
Chako · 31 · 2816
on: August 01, 2017, 03:21:29 PM
I believe I may have posted the contents of this drawer in some long lost thread on this forum. In any case, I am unable or incompetent enough to find it in a forum search. Because of this, and I think, it has been a few years since...here is another one of those what is lurking in this drawer thread. I think the older thread was just a bunch of photos. This time around, I shall bore you with my thoughts as well as some photos. The thoughts are free. Heck, so are the photos. You know what they say about free things...take them at face value!
Here is the drawer we are going to dive into in this thread.
It is one of the deeper drawers that holds a few gems.
« Last Edit: August 01, 2017, 03:44:35 PM by Chako »
Re: What lurks in this deep drawer?
Reply #1 on: August 01, 2017, 03:44:12 PM
1. Rite Edge Pocket Tool Box.
Here is an interesting kit simply because it is huge. How big you say? Well, it counts 84 separate functions, and they all cram into a somewhat largish zippered clam shell case. I just find this hilarious that Rite Edge decided to put a belt loop on the back of this monstrosity. I suppose you could carry it around on a belt, but it would be a bit awkward. I guess where there is a will, there is a way.
The Pocket Tool Box comes in a rather nice zippered case. Here is the front of the case.
This is the back of the case with belt loop.
The included literature itemizes all 84 functions.
When you unzip the case, you are greeted with 48 separate driver bits in 4-12 bit carriers, a pouch that holds 8 sockets in a red rubber carrier, and a sheath that holds the multi-tool in place. There is also a bit driver adapter held in place via an elastic loop. All in all, there is a lot of stuff taking up all that space.
This kit gives you:
- Pliers / gripper
- Wire cutters
- Wire strippers
- Fish scaler
- Custom belt sheath made of rugged woven material designed to hold all components
- Hook remover
- Scissors
- Coarse file
- Fine file
- Adapter post for driver bits
- Wood chisel / bottle opener
- Can opener
- Knife blade
- awl
- Wood saw
- Removable magnetic bit holder sleeve
- Socket connection adapter
- #0, #1, #2, #3 Phillips bits.
- PZ0, PZ1, PZ2, PZ3 Pozidriv bits.
- T10, T15, T20, T25, T27, T30, T40 Torx bits.
- 3mm, 4mm, 4.5mm, 5mm, 5.5mm, 6mm, 6.5mm, 7mm slotted bits.
- #0, #1, #2, #3, #4 Robertson bits.
- 2mm, 2.5mm, 3mm, 4mm, 5mm, 5.5mm, 6mm, 7mm, 8mm Metric hex key bits.
- 1/16", 5/64", 3/32", 1/8", 5/32", 3/16", 7/32", 1/4", 5/6" SAE hex key bits.
- 1/4 socket adapter bit.
- 5mm, 5.5mm, 5.6mm, 7mm, 8mm, 9mm, 10mm, 11mm Sockets.
- Ruler markings, inches and centimeters.
The multi-tool included in this kit resembles somewhat the Leatherman Super Tool in size and exterior looks. It does not come anywhere near the quality of a Leatherman product however. Much like the Leatherman Super Tool, you need to use another folding tool to disengage a metal spring tab that fits into a back groove. It is a bit fiddly, but it is workable. Just don't lock all the tools in place as unlocking them can be a bit hard without damaging the tool.
Pros:
- the perfect companion to have along if you use a lot of different screwdrivers in your daily activities. Heck, there are even Robertsons to keep those pesky Canadians happy!
- it all fits into a somewhat smallish package
Cons:
- It all fits in a somewhat small package. Stress the somewhat small part.
- multi-tool is of poor quality.
Overall, not a bad get up for someone who wants to be prepared for mostly anything. Myself, not sure who would ever need all those full sized driver bits. The tool itself is not a quality piece of gear. Nothing stopping someone in exchanging it for something of better quality though.
« Last Edit: August 01, 2017, 03:49:28 PM by Chako »
Reply #2 on: August 01, 2017, 04:16:56 PM
Beza Great Escape Tool Kit.
I came across this tool kit while trying to find something better for my motorcycle instead of the included crappy OEM one. I never did push this one into motorcycle service, instead opting to modify the OEM kit slightly and included a Leatherman MUT into the mix. As such, the Beza Great Escape Took Kit would make a very nice motorcycle repair kit, but it isn't limited to just motorbikes. What makes this kit so attractive is the inclusion of 2 separate tools. This means you can tighten nuts or anything that requires a second tool. This capability is much appreciated and needed. The Great Escape Tool Kit comes in an attractive Velcro Case, and much like the Tool Box mentioned above, this kit tries to meet your every needs, but I think it does it better due to that second tool.
The case features a separate exterior pouch for the smaller multi-tool, which means you don't have to open the full kit to access it. Everything is held together via Velcro, and the whole case opens up easily for full access.
Much like the above Tool Box Kit, this one also features a belt loop. Both are big kits.
The Great Escape gives you only 32 bits as opposed to the 48 in the previous kit. However, that extra room gained is put to great use. Once the full kit is opened, you will see 2 pockets, tow elastic loops, and a bit organizer.
One pocket holds some metal wire and 2 zip ties. There is enough space in this pocket to add other small items you may find necessary to have. The two belt loops hold a pair of socket adapters. The other pocket holds the main adjustable wrench multi-tool.
Included in this kit are:
- 1/8", 5/32" 3/16", 1/4" slotted bits.
- #0, #1, #2, #4 Phillips bits.
- 1/16", 3/32", 1/8", 5/32", 3/16", 7/32", 1/4" SAE hex key bits.
- 2mm, 2.5mm, 3mm, 4mm, 5mm, 5.5mm, 6mm Metric hex key bits.
- T8, T9, T10, T15, T20, T25, T27, T30, T40 Torx bits
- Essenti-Tool (the smaller pliers based multi-tool. Yes, this should get the worst name in the multi-verse award)
(The Essenti-Tool includes: scissor, small plain edge blade, file, hook sharpener groove, large flat driver, a small needle nose pliers, wire cutter/stripper, hole punch, 10mm wrench, small package opener)
- Ultima-Tool (the adjustable wrench based multi-tool. First place or runner up...you be the judge)
(The Ultima-Tool includes: an adjustable wrench, a fairly large folding needle nose pliers, a large plain edge knife, serrated knife, flat screwdriver, file, wire cutter/stripper, and bit driver with adapter.
- 2 zip ties
- mechanics wire
- 2 socket adapters
- 1 driver adapter
Pros:
- well designed case
- extra room to add a few small essentials
- 2 tools make easy work of removing nuts, etc.
Cons:
- The tools are cheap in quality, although the adjustable wrench is built like a tank
- a tad large to belt wear
Overall, the Great Escape kit is rather interesting. It would make an excellent addition to any motorized vehicle. The two multi-tools are functional if lacking in quality. These are no name branded quality items, but when the chips are down, they are perfectly serviceable. The fact that there is room to add a few more items to customize this kit is a bonus.
« Last Edit: August 01, 2017, 04:18:46 PM by Chako »
Reply #3 on: August 01, 2017, 04:38:08 PM
« Last Edit: August 01, 2017, 06:14:12 PM by ReamerPunch »
Reply #4 on: August 01, 2017, 06:03:55 PM
That is not the one I was thinking about.
gb Offline daverobson
Reply #5 on: August 01, 2017, 08:03:47 PM
Reply #6 on: August 01, 2017, 09:12:55 PM
Yes, they are one and the same.
Reply #7 on: August 01, 2017, 10:02:19 PM
CRKT Flux.
Seeing that I started with the larger items in this drawer, I figured I may as well continue with the same idea. Meet the CRKT Flux which came out in 2009-2010 if memory serves me correct. I just checked on the Flux and it appears to be now discontinued. The Flux is a modular system in which you can carry one or two components at a time. The system has 5 individual modules, and 2 rail carriers...one being a single rail and the other being a double rail. The carriers have a built in carabiner or two.The modules slide onto the rail carriers and lock in place via a locking tab on the module. Like most, er...all modular systems in the multi-tool universe, they tend to fail. For instance, you could buy the modules separately which would come with a single rail so that you can carry it around. You could also buy them in themed packs, which always came with 2 different modules. These packs would give you a double rail to carry both of the modules together. The modules came in several paired packs which are the  GoWork pack (knife and screwdriver module), the GoNerd pack (USB drive module and screwdriver module), and the GoPlay pack (wine module and LED light module). Of course, you could buy each separately as well. To add to the buying, if you wanted to keep everything together, a special case was also sold by CRKT. For instance, I wanted the complete kit. Thus I bought two module packs and a separate module, and also bought the carry case above that. The carry case is well constructed, but I have to wonder at how useful it is for everyday use.
The case is well constructed and features 2 front pockets with Velcro flap.
The usual belt loop...just a bit bonkers on something so large.
Inside, there is a foam organizer and a place for every tool along with the various rails you may end up with. As I bought to themed packs and a single, I have two double rails and a single rail. There is room for any variety of rails you may end up with.
The modules include (from top to bottom)
- USB Drive module which contains a 2 GB micro SD card
- LED light module
- Knife module
- Wine Tool module
- Screwdriver module
plus the single and double rails.
Thus you can carry either one or two modules at a time depending on the rail used.
Pros:
- modular system means you carry only the tools you want
- Accessory case keeps everything together
- the 2GB micro SD drive is a keeper
Cons:
- the two rail system is bulky, the accessory case more so
- limited modules
- expensive if you are looking for the complete set.
Overall, a nice effort by CRKT. Modularity and multi-tools never seem to go hand in hand, and usually ends in failure. the CRKT Flux system is no different as it is now discontinued.
Reply #8 on: August 01, 2017, 10:15:42 PM
Norwood Outdoors Gardening Kit.
Talk about an unusual set. The Norwood Outdoors Gardening kit features two small garden implements that fold upon themselves...a miniature rake and trowel, and a full sized garden shears with wood saw, PE knife blade, a weeding tool, and a seeding tool with half serrated blade. Everything fits inside a nice largish green case.
The front of the case with Velcro flap.
A belt loop is found on the backside.
Opening the flap, you will find a central pocket flanked by two double webbed belt loops.
The miniature garden rake and trowel fold upon themselves in a neat way. Just press together the wire handles and flip the implement to the closed position. The wires lock the tool open. To fold away, simply squeeze the wire handle to disengage the tool head for folding.
The garden shears are full size unlike the cute lilliputian rake and trowel. Each handle stores two folding implements.
Pros:
- everything stores in a largish case
- cute mini rake and trowel for small jobs
- garden shears have a locking mechanism to keep the blades closed
Cons:
- garden shears are not of the best quality
Overall, this is a unique set for the gardener.
Reply #10 on: August 02, 2017, 02:03:33 AM
Yes, that is the one. 4 years now...wow.
us Offline ColoSwiss
Reply #11 on: August 02, 2017, 03:03:53 AM
Interesting as always.  :cheers:
What's in the Beretta case?
Reply #12 on: August 02, 2017, 04:39:49 AM
It will have its day in the sun in a later posting in this thread.
Reply #13 on: August 02, 2017, 05:12:23 AM
Allied Tool kit.
Here is a 3 piece tool kit that fits on a belt. This Allied set included a 2 AA battery flashlight with incandescent bulb...which dates this set somewhat as it isn't an LED bulb, a generic SAKlike knife, and a pliers based multi-tool. I have a few other kits of similar ilk that contains Gerber, Leatherman,  or SOG and are geared towards the maintenance worker or building superintendent.
The sheath is rather nice as it contains 3 pockets, two of which are covered via a larger Velcro Flap. This leave the flashlight uncovered for quick access.
The back of the sheath has the usual belt loop present.
Once the flap is opened, you can see both multi-tools.
Both multi-tools have a very nice textured rubber inserts on the handles. The flashlight lacks this textured grip.
The SAK like object is the bog standard generic Victorinox/Wenger wannabe design.I will say, this tool is of higher quality than some of the newer like patterned knives I have seen. It is one of those situations when you think at the time of purchase that this is very low quality and cheap...and then 10+ years roll on and you think differently because you have now seen truly cheaper newer stuff.
The multi-tool is a mixed bag. I see bits of higher quality in this tool, and then some of the implements are a let down such as that combo fish scaler/file/hook release tool.
Pros:
- a nice little kit for someone who may need a flashlight and multi-tool far away from a toolbox
- nicely designed sheath
- multi-tools have higher quality fit and finish than design would indicate
Cons:
- flashlight is definitely dated
- flashlight will fall out of sheath if wearer is doing upside down acrobatics
Overall, not a bad little maintenance kit for what it is.
Reply #14 on: August 02, 2017, 05:30:54 AM
Jeep Multi-tool.
I have seen several different Jeep multi-tools, and this one sort of stands out from the rest of the crowd. I think of this tool more as a multi-functional knife rather than a pliers based multi-tool. I think so simply because this tool offers a very generous knife blade with a nice working liner lock. I am not usually a big fan of liner locks, but when done right, are secure. This is one of the secure liner locks.
The sheath has JEEP stitched on the Velcro front flap.
The back of the sheath is especially nice as the dual belt loops are 2 piece Velcro tabs which makes installing the sheath on a belt easier than permanent loops. Note that this is a licensed Chrysler product with a date of 2009.
Opening the flap, you will see a rubber bit holder which holds a nice assortment of Phillips, flat, and Allen key driver bits. Sharing the same compartment is a very interesting multi-tool.
The multi-tool has the JEEP logo raised on the rubber side of the tool. You can also see on the right, a section that slides off. That section contains a fire-steel.
The pliers fold out in an interesting way. They fold sideways.The design issue here is that one handle is super large compared to the other.
The smaller handle contains 3 small folding tools, a lilliputian PE blade, a combo bottle opener and flat driver, and the square driver mount that fits the bit adapter.
Here is the star of the show, a very nicely sized knife. This one came from the factory sharp.
Pros:
- excellent knife
- sheath is intelligently designed and of good quality
- includes a  built in fire-steel
Cons:
- pliers are an afterthought
- micro folding tools
Overall, one of the better JEEP branded multi-tools out there. The design is unique enough to make it interesting, especially to a collector.
« Last Edit: August 02, 2017, 05:32:00 AM by Chako »
Reply #15 on: August 02, 2017, 06:04:01 AM
Super Fisherman by John Benzen Tools Division of Chicago Tools.
What a boring name for a tool that is anything but boring. I find this model so fascinating as I don't think there are many designs quite like this one out there. The Super Fisherman by John Benzen of Chicago Tools is a truly dedicated multi-tool for the avid fisherman.
This wonder comes in a camo vinyl sheath. What amazes me about the sheath is the lack of water drainage. A grommet on the bottom of the sheath would fix that problem.
The back of the sheath has the usual belt loop.
You may have noticed that there is a side loop on the sheath. That loop contains a brass knot tying guide. The sheath is divided into two compartments. The first holding a pair of rubber organizers, one for driver bits, the other for a socket set. The rear compartment holds the multi-tool.
The multi-tool is very well constructed with easy to use lever locks. All ruler stamping are of good quality.
The other side of the Super Fisherman is dominated by a Ketchum type quick release tool.
Continuing in the fishing specialization, the pliers are very long with a bent tip to aid in removing hooks. The pliers feature several crimpers, etc for various fishing needs. The Super Fisherman is larger than a Leatherman Supertool in case you were wondering. This is one large multi-tool.
The tool load-out on this monster is very specialized.
- brass knot tying guide
- 4 1/2" fillet knife (yep, ever seen one like that before?)
- can opener
- long fine needle/awl perfect for removing knots in fine fishing line among other things
- tweezers
- half serrated knife blade
- scissors
- square driver adapter post
- fish scaler with built in hook remover
- Ketchum quick release tool for fly fishing
Pros:
- excellent quality in materials and finish
- highly specialize for fishing, especially for the fly fisherman
- does have an old school Leatherman type lanyard attachment on one side of the handle
Cons:
- no water drainage on the sheath
- no included lanyard
- will not float
Overall, a truly unique tool.
« Last Edit: August 02, 2017, 06:07:40 AM by Chako »
Reply #16 on: August 02, 2017, 06:20:36 AM
That super fisherman is looking good.  :o
Reply #17 on: August 02, 2017, 02:17:25 PM
It is rather unique.
Reply #18 on: August 02, 2017, 02:36:44 PM
COAST Pro Pocket Fishing-Pliers.
I just so happen to have bought two of these at different times, as I wanted  to EDC one. Imagine my surprise when I opened the newer one to find out that they had updated the tool. I never did manage to EDC this. The main reason why I wanted to EDC this multi-tool is the included sheath. The sheath is rather unique in that there is a zippered compartment which holds all the extra bits secure. The sheath also features a main pocket where the multi-tool resides. Furthermore, there is an attached swivel located on the back top of the sheath to secure it from any inadvertent accidents of gifting the whole thing to the fishes.
The sheath is very well constructed.
Note the included swivel attachment point. You can secure it from any tumbles into the water.
The sheath feature one front pocket for the multi-tool.
The real magic happens when you unzip the rear compartment. Note that the older version is on the left, and the newer version is on the right.
Upon first inspection, you can't tell which is the older (left) version and which is the newer.(right) version. Both feature rubber inserts that aid in gripping the tool in a wet environment.
The older version does not offer a spring loaded pliers (top). The newer version offers spring loaded pliers and some decorative detailing to the plier head. There are also some slight changes to the included bits. The older version gave you two different nut wrenches to fit fishing reels. The newer version ditches one of those and only offers you the one nut wrench.
Both versions give you the same tools including scissors, a full sized bit screwdriver adapter, half serrated knife blade, a Phillips driver, a long needle like awl, and a combination bottle open/flat driver. The pliers themselves are specialized for fishing. They are long nosed needle pliers with a bent tip. There are several crimpers included with the pliers.
Old version:
New version:
Pros:
- awesome sheath with zippered compartment and swivel attachment point
- good quality
- bent tip helps with delicate work
Cons:
- no lanyard attachment on multi-tool
Overall, here  is another sleek fishing multi-tool. This one isn't as specialized as the one listed above, but it has enough features to make it a real winner for any fisherman. The main issue with this tool is the lack of a lanyard attachment point on the tool itself, and no matter how I live this sheath, there still aren't any water drainage grommets at the bottom of the sheath.
Reply #19 on: August 02, 2017, 02:49:45 PM
Beretta Shotgun Tool.
The Beretta Shotgun Tool is another unique and very interesting piece. Designed to aid in all of your shotgun needs, this tool aims to please. Centered around a hammer and the included 2mm pin punch, this tool will aid you in taking apart most shotguns.
The sheath features a stitched Beretta logo. The sheath is well constructed.
On the back, is the belt loop.
Opening the Velcro flap, you will find one large pocket for the tool, as well as a side pouch for the pin punch. The pin punch is easily accessible even when the sheath is closed.
The included 2mm pin punch is one of the most professional ever included with a gun centric multi-tool. The Shotgun Tool also reeks of  quality.
Unfold the handles, and you have a surprisingly full sized hammer.
The tool includes the following features:
Hammer Head, Screwdriver, Fine File, 28-.410 Choke Wrench, 12-20 Choke Wrench, Optima-Mobil-Victory Enhanced choke Tool, #2 Phillips Screwdriver, Small Pliers, Sheepsfoot Knife Blade.
Pros:
- quality fit and finish
- only tool of its kind design wise
- an excellent companion to any shot gunner, or for any firearms owner for that matter
- one of the best pin punches ever included with a multi-tool
Cons:
- some of the included folding tools could be longer as there is plenty of space to make them so in the handles
Overall, another unique tool aimed squarely at the shotgun user, but will help anyone who is into hunting, or the shooting sports.
Reply #20 on: August 02, 2017, 03:04:15 PM
HDX 10 in 1 plumber Tool.
Another specialized tool, but this time for the plumber. The HDX revolves around a heavy duty PVC cutter.
The included sheath bears the HDX logo.
The back includes the usual belt loop.
The tool itself is rather large, with plenty of high grip rubber (orange), and textured hard plastic (gray) to aid in tool retention in wet environments.
The PVC cutter is large and well designed. It is also very sharp and included a locking mechanism. The PVC cutter will handle up to 1/2" PVC pipe.
This multi-tool includes a heavy duty PVC cutter, a combo knife, a drywall saw, a flat-head screw driver, a Phillips-head screwdriver, several hex keys, and a multi-use premium cutting blade. This tool also features a built-in flashlight for working in poorly lit areas.
Pros:
- not many plumber designed multi-tools out there
- sharp PVC cutter
Cons:
- I can't think of any other than it is rather purpose built for a niche market
Overall, the HDX is a cool tool for the folks who like to play with water and sewage. If you need something like this (I know my Dad who was a plumber would have loved this tool), then this is the only game in town that I know about.
Reply #21 on: August 02, 2017, 03:16:29 PM
Generic Adjustable Wrench Multi-tool.
I find these type of multi-tools somewhat fascinating as they are very useful tools but for some unknown reason, they aren't as plentiful as pliers based multi-tools. I guess pliers are always more useful for the majority of users out there. Combine one of these with a pliers based multi-tool and you have a killer combo...much like the Great Escape Kit mentioned in a prior post. As can be seen, this tool is very similar to the one included in the Great Escape Kit. The main difference with this tool compared to the one found in the other Kit is the back Phillips driver instead of a square post to accept a driver bit adapter. This tool isn't as heavy duty as the other, but then, that is only due in part to the Great Escape adjustable wrench has extra name plates riveted to the underlying handles.
The sheath is on the cheap side.
The usual belt loop. Cheap as in thinner materials used throughout...the belt loop included.
The adjustable wrench included the following features:
- PE knife blade
- combination serrated blade, large flat driver, and file
- Back flip Phillips driver
- full size pliers
- adjustable wrench
Pros:
- Pliers design give you plenty of leverage, and will open wide enough for most jobs
- all metal construction gives sens of durability
- adjustable wrench is very useful
Cons:
- cheap sheath
- fit and finish is lacking in spots
Overall, this is the perfect companion when combined with a pair of pliers.
Reply #22 on: August 02, 2017, 04:27:18 PM
Mastercraft Electrician Tool.
Mastercraft is the store brand of Canadian Tire. This electrician tool is perfect for all your cutting, crimping, and stripping needs when it comes to household wiring.
The sheath is very well constructed, and it eye catching with that yellow piping.
On the back, the usual belt loop.
The Mastercraft Electrician tool features rubber inserts for a good grip. There are no locking tools on this model, depending on a metal tab to provide enough resistance to keep the tool from folding on you during use.
This tool features the following functions:
- wire strip: AWG 10, 12, 14, 16, 18, and 20 sized wire
- 2 holes on pliers to aid in pulling wire
- tip jaw pliers
- wire cutter
- sheepsfoot plain edged knife blade
- large and medium flat driver
- Phillips driver
- wire hook tool/small flat driver
- drywall saw
- file
Pros:
- excellent sheath
- good ergonomics
- build quality is good
Cons:
- no locking tools
Overall, not a terrible electrician multi-tool. Not quite the quality of lets say the Bear & Son Electrician, but not bad either.
Reply #23 on: August 02, 2017, 04:38:03 PM
Mastercraft Shears Tool.
Much like the above posting, this is another Canadian Tire branded tool, this time centered around a nice set of shears. Now, there are only a few target audiances that I know which have multi-tools designed for them in regards to shears. You have the hunters, particularly the bird hunters who will need a nice set to cut off the wings, etc. Some of those will have a round bone notch in the shears to aid in that task. You also have the Gardening crowd. This one however doesn't meet those two groups. Instead, this one is geared more towards the worker who needs to cut things on the job site. I say this because the tool load-out isn't specialized for the other two groups. Of course, this tool will be helpful for anyone that needs a set of shears.
The sheath is once again of top quality.
This tool looks exactly like the Electrician Tool in the prior post. However, there is one difference. See those locking sliders. Those lock the shears in the open position, meaning the handles will not shift on you during a cutting task. Those are the only locking mechanisms on this tool The other folding tools do not lock.
The Mastercraft Shears Tool have the following features:
- shears with a closed locking tab as well as both handles locking in the open position
- PE knife blade
- large flat driver
- small flat driver
- drywall saw
- Phillips driver
- file
Pros:
- excellent sheath
- good ergonomics
Cons:
- no locking tools other than the main shears
Overall, another not bad tool. My only wish is to have a locking mechanism for the secondary folding tools.
Reply #24 on: August 02, 2017, 04:50:00 PM
Flip Grip Multi-tool.
I enjoy all sorts of designs in the multi-tool world. I especially like those that aren't all that common. This is one of those unique designs that I mostly see in a hardware store always as a 2 in 1 pliers tool. Flip the handles over and you can expose tow different pliers. Quite often you get a model with a needle nose plier as well as a blunt, or you may get a wire cutter along with a plier. The design differs upon the model. Those are multi-tools as you get dual functionality. However, I do not consider then true multi-tools unless they offer a little bit more than those standard blip grip style pliers. This one doesn't disappoint.
The sheath is of good construction.
The included belt loop is also well made.
That added functionality comes in the form of additional folding tools in the handles.
Note the sliding locking mechanism with the red sticking still on. A metal cover slides over the needle nose pliers and holds them in the close position.
Slide that mechanism off the pliers, flip the handles, and you now have different pliers.
A closer look at the locking mechanism.
Here you can see how that sliding metal cover locks the pliers.
So by flipping the handles over, you can either use the blunt or the needle nose pliers.
Pros:
- a conversation starter
- well made
Cons:
- due to design, this multi-tool is not compact
- small secondary fold out tools
- locking mechanism can be a bit fiddly at times
Overall, the Flip Grip is a somewhat unique multi-tool. I don't think they are all that common these days.
Reply #25 on: August 02, 2017, 05:00:54 PM
Generic Flip Grip Style Multi-tool.
Everything eventually gets copied, and the original Flip Grip is no exception. Both of the examples I have feature wooden grips, which do make them look expensive...although the fit an finish does not lie, nor does the quality of the sheath. Lets take a closer look at the first one now...
The sheath is cheaply made.
The belt loop doesn't inspire confidence either as it is thine.
Now this tool offers both a wire cutter and a needle nose pliers. Note the brass pins holding the wooden grips in place. This one is a looker.
Note the cheap locking mechanism to keep the tool in the closed position. That hook does get in the way while using this tool.
Flip the handles over 180 and you can use the needle nose pliers.
Because of the design of this tool, no matter which main tool function you decide to use, half of the secondary folding tool set will either be outside or inside opening.
You do get the following features:
- main wire cutter
- main needle nose pliers with wire cutter and crimper
- PE knife blade
- awl
- combination flat driver and bottle opener
- large flat driver
- can opener
- Phillips driver
- hook tool
- combo fish scaler, hook remover, and file
Pros:
- unique flip function
- a looker if you like wood and brass pins
Cons:
- cheap sheath and tool shows lack of fit and finish.
- not a compact tool
Overall, another interesting flip grip style tool. I sort of like these for their differences compared to the more mainstream multi-tool.
« Last Edit: August 02, 2017, 05:08:23 PM by Chako »
Reply #26 on: August 02, 2017, 05:07:32 PM
The Hawk Flip Grip Style Multi-tool.
Here is the second Flip Grip clone. Instead of offering a dedicated main wire cutter, you get a blunt nosed plier much like the original Flip Grip model.
The sheath is of higher quality than the one shown above...but not by much.
Once again, you get wooden handles and a hook locking mechanism.
Unlock the tool and flip those grips 180 degrees to expose the other personality of the tool.
The Hawk features:
- LED lamp
- combo flat driver and bottle opener
- Phillips driver
- PE knife blade
Pros:
Cons:
Overall, a slightly better tool than the other Flip Grip copy, but both aren't as high in quality as the original. Still a neat design, but comes at the cost of compactness as these do not fold up for storage.
es Offline ThePeacent
Reply #27 on: August 03, 2017, 01:10:41 PM
I have a FlipGrip very similar to yours, but very slightly different too, and better IMO.
Mine has same 5 tools on one handle but the other doesn't have a folding bit driver. It has a hollow handle with a cover, inside which you can store 4 bit heads of 6mm size, and then at the bottom of the handle there's a hole for the drivers, much like the one in the Crunch,
the other implements are equally crappy though  :D
My toys:
Reply #28 on: August 03, 2017, 11:11:51 PM
Lots of interesting looking stuff.   :tu:
us Offline Marcellus
  • What does Marcellus Wallace look like?
Reply #29 on: August 04, 2017, 02:44:27 AM
Another interesting Show and Tell, plus Chako even gives you a  Pros/Cons  part as well.
What a contributor to MTO !
Thanks, once again, Chako.
BTW - you referenced the Stamp collection recently , and it was another interesting  post ( for me, at least)
