Most useful 91mm pry tool?
Poll
What’s the most useful 91mm pry tool?
Can Opener
3 (21.4%)
Bottle Opener
11 (78.6%)
Combo Tool
0 (0%)
Total Members Voted: 14
us Offline tommywp
on: March 28, 2018, 05:40:36 PM
My knee jerk answer would always have been that the width and strength of the bottle opener makes it the better pry tool (and I think it might be advertised as such), but I’ve recently found myself using the can opener more often because it’s SD tip can get in the smallest of cracks. If you had to pick only one 91mm tool for prying, what would it be? For the purposes of this conversation, let’s ignore the other functions of the tool (i.e. assign no value to driving screws or popping beers)
Re: Most useful 91mm pry tool?
Reply #1 on: March 28, 2018, 05:43:23 PM
It depends on what are you trying to pry. If it's a heavy, thick wooden crate or a watch case. I think awl of them have a place and time where they're the best tool for the job.
 :tu: :tu:
us Online cody6268
Reply #2 on: March 28, 2018, 05:56:57 PM
The bottle opener works great for light, routine prying tasks.   The can opener works for jobs that a watchmaker's knife is best, such as disassembling electronics which often have the main case held together by a snap-fit. Combo tool is only used when I'm only carrying a Walker, which at present is the only model I have with it. Being as it's only as thick as the pen blade, I don't' even use it on tough screws as a screwdriver.
« Last Edit: March 28, 2018, 06:37:59 PM by cody6268 »
us Offline El Corkscrew
Reply #3 on: March 28, 2018, 06:54:05 PM
Agreed, Cody.   The can opener is best for prying off scales.  For heavier tasks,  definitely el Caplifter.   :salute:
00 Offline WWW
Reply #4 on: March 28, 2018, 07:22:40 PM
I can use the can or the bottle opener, but I've been using the can opener a lot to remove staples. I'm not even using the SD tip, but rather the pointy can opener part to get underneath the staple and open it up.
Reply #5 on: March 28, 2018, 07:29:43 PM
My 91mm models have both (except my Waiter, and I do not carry that ever), so I just use whichever tool fits.
That's what she said.
us Offline smiller43147
Reply #6 on: March 28, 2018, 09:53:09 PM
Agreed.  It depends on the task.
I also find the can opener to be great at staple removing, but I start with the small sd tip.
- Steve
us Offline WoodsDuck
  • Duck!
Reply #7 on: March 28, 2018, 11:20:53 PM
I've done the same thing numerous times. That can opener blade is quite versatile.
se Offline stoneshank
Reply #8 on: March 28, 2018, 11:31:53 PM
Agreed with above. I have dulled the shark fin on the can opener, just a bit so it doesn't accidentally cut anything
~ if you're not good, be creative ~
March Goal: $300.00
Due Date: Mar 31
Total Receipts: $379.86
PayPal Fees: $19.62
Net Balance: $360.24
Above Goal: $60.24
120%
March Donations
