Maglite Flashlight Club
ca Offline buggs
Re: Maglite Flashlight Club
Reply #120 on: March 28, 2021, 08:12:59 AM
How do these LED Maglites compare to something like an Olight Baton or other similar light?
Dragging this out of the past, but what Maglite?  I have a few Maglites and more than a few Olights, including at least one iteration of Baton.
Any love out there for Incandescent Maglites?  No question everything beyond incandescent is brighter (Xenon, LED, etc.) but my eyesight is kind of crappy and I've found that the brighter bulbs wash out things (like combination locks in the dark) and I benefit from a softer light.  I've actually been grabbing up a few smaller (1AAA, 2AA) incandescent Maglites while I still can.
Don't get me wrong I have a few 3D big old Maglites and they throw so little light even compared to an Olight I5T but I still have soft spot for them.
us Offline ToolJoe
Reply #121 on: April 03, 2021, 09:01:07 PM
I had a couple incan Maglites recently and they were fine for around the house use.
Offline Scorpion Regent
Reply #122 on: August 27, 2021, 07:42:06 PM
Once I switched to LED I never looked back.  Not having to worry about needing batteries every twenty minutes is a really powerful argument for retro fitting.  The money I save on batteries alone has surely paid for the cost of conversion.
I can think of two possible options to have a LED Maglite and still not have it over glare what you are trying to work on.
Option 1) Spend money and make your light more complicated.  The Nite Ize IQ switch works with the Mini Mag, it has variable output settings.  The lowest output might be what you are looking for.
Option 2) Get crafty and make it work.  You can make a diffuser lens out of a translucent colorless plastic, (possibly a bottle).  The diffuser lens can replace the factory clear lens or be used in conjunction with the lens holder that comes with the manufacturers accessory kit.  This option would work for any size Maglite.
Reply #123 on: August 27, 2021, 08:21:29 PM
The one time I had trouble and required pliers to remove the tailcap was when the alkaline battery leaked; it corroded the cap, and part of the body but was still functional. A good scrub and clean with baking soda, a light smear of silicone grease everywhere, and a disposable lithium battery, and haven't had any problems ever since. I tend to smear silicone grease on threads and o-rings as a lube and improve somewhat the water resistance of my Mag's
Silicone grease is great for all sorts of things.   People who love WD40 haven't discovered Sil Glyde.
Baking soda neutralizes acid, but it doesn't remove corrosion.  Once all the acid has been removed, I attack any corroded parts with vinegar and cotton swabs.  Remember once the plating on metal has corroded away it's likely to corrode again.  To keep metal contacts from corroding due to condensation give them a light coat of silicone dielectric or white lithium grease, it conducts electricity, but doesn't allow in moisture.  Be careful to use you chemicals sparingly, there is nothing worse than a catastrophic short burning up something you just saved.
Reply #124 on: August 28, 2021, 03:51:46 PM
I wouldn't use dielectric lube on active contacts as it behaves like an insulator. It doesn't conduct electricity  :hatsoff:
Reply #125 on: August 28, 2021, 09:29:05 PM
You're right.   :oops:   I remember using dielectric grease on a soldered connection underneath shrink wrap tubing to prevent water getting in.  It doesn't matter if the grease is a extra layer of insulation if wires are soldered together.
White lithium grease is what is used on the tail lights of boat trailers.  If it's going to go into the water the lithium grease will keep the water out and still have good connection.  like wise lithium grease can be use on trailer ball mounts to prevent rust, but maintain a good ground connection.
Thanks for keeping me on my toes McStichy.
Reply #126 on: August 28, 2021, 11:20:44 PM
Great info SR  :tu:
us Offline ThundahBeagle
Reply #127 on: November 22, 2021, 03:16:25 AM
I got my first MagLite in the late 80's or early 90's. It is a 3 -D cell. Heavy and big. Still have it. Still works. Obviously it is incandescent. I have since purchased a number of mini Mags AA LED variety. And a couple Solitaire models for the Leatherman sheaths.
Unfortunately I find that as of recently, they are no longer available for purchase at Home Depot or Lowes. They are no longer a stock item! Will not be stocking them. I found out this week when I went to pick up some Solitaires to replace the ones I just lost.
So, now all the orange and the blue stores stock is "Coast", Energizer and some other Lux brand. All made in china. So it looks like 15 days on a boat, 35 days at port of LA for Chinese crap, and we still cant get American made flashlights from Cali anymore
« Last Edit: November 22, 2021, 03:26:26 AM by ThundahBeagle »
ca Offline Shock_me
Reply #128 on: April 20, 2023, 10:57:03 PM
I've had quite a few Maglites in the past, but this one was gifted to me back in the late 90's. It has a lot of sentimental value so I wanted to keep it in use even with today's LED offerings. I upgraded the bulb and reflector to LED with a kit from LITT Industries and it is a very capable little light now. I keep it in my Maxpedition Micro as a backup to my everyday Streamlight USB which I carry in my pocket.
no Offline nakken
Reply #129 on: April 22, 2023, 02:08:55 PM
Great way to keep a classic alive, nice kit too :like:
ca Offline Shock_me
Reply #130 on: April 22, 2023, 02:14:37 PM
Thank you nakken! I actually use something from this kit every day. Usually the cable kit to charge my phone, or the Leatherman Micra for the scissors.
ca Offline buggs
Reply #131 on: May 27, 2023, 06:58:16 AM
Still like my Maglites.  A few I use regularly are the soft LED solitaire, a larger 2 AA version and my big old 3 D cell incandescent.  It pales in comparison to anything truly modern but I still like the heft which I think was 50% of the purpose anyway.  Very sturdy lights.  Not sure I'd use anything as a hammer, but I'd be happier hitting something with a maglite than anything else if I had to.
us Offline gustophersmob
Reply #132 on: December 15, 2023, 09:24:18 PM
Bumping this to let you guys know that Maglite is having a 40% off sale with coupon HOLIDAY40 applied at checkout.  Also free shipping via UPS SurePost/USPS.
www.maglite.com
Reply #133 on: April 13, 2024, 07:31:24 PM
Shortly after my last post here, I called MagLught and confirmed they are going online only, no longer in stores.
So I bought a new XL50 from tem off of Amazon, along with a couple AA LED mini Mags.
Love the XL50!  Three AAA's in a carriage.  Bright as my truck HID headlights, I think.  Certainly powerful enough as my dog and I traverse our wooded acre at night.  Love the tail switch and 3 modes.  Still use the AA LED Mini from time to time as they throw a wider beam, it seems.
Also bought an LED conversion from a small family maker for my Surefire G2 Nitrolon.  200?  400? Lumens there, too.
wales Offline GearedForwards
Reply #134 on: April 14, 2024, 12:00:21 AM
What a weird light to cap out at 200 lumens, I wonder if it would take an 18650 since it takes 3xAAA?
I'm curious, how much do you folks pay for something like that off Maglite in the states?
Reply #135 on: April 15, 2024, 07:13:19 AM
I dont recall what I paid or # of Lumens, I'd have to look it up.  Came with an octagonal cap to prevent rolling.  Also colored lenses and pocket clip.  It has done me well.
The drop-in LED  conversion for my Surefire G2 Nitrolon was from Malkoff Devices of AL.  That was the best way to get new life into a 20 year old (xenon?) flashlight
us Offline charlie fox
Reply #136 on: April 15, 2024, 01:31:08 PM
A couple of weekends ago we went camping in the wilderness of Georgia...well, it was a State Park, but that's beside the point. My ML50L got a workout! I love this thing; bright, easy to carry, programmable modes = awesomeness! I carried a 3C for many years as in LE and Security and wish this one would have been around back then!
"Never pick a fight with an old man. If he's too old to fight, he'll just kill you."
Reply #137 on: April 15, 2024, 02:03:51 PM
My Mini Maglite
Only Tools Matters
Offline A30000
  • New User
Reply #138 on: November 15, 2024, 09:20:21 PM
Hello all Micron enthusiasts, I recently purchased a MAG-LITE black 6D
flashlight, but there is no "patented made in USA" engraved on the flashlight. Is this MAG-LITE flashlight a genuine product or a counterfeit product? I am looking forward to your reply as soon as possible. Thank you very much. :) :) :)
Reply #139 on: November 16, 2024, 12:18:07 AM
Welcome to MTO!   :woohoo:
I hope you get the answer you are looking for.   :salute:
us Online nate j
Reply #140 on: November 16, 2024, 03:32:36 AM
It has been a while since I bought a new Maglite.  May we see some pics, please?
Offline A30000
  • New User
Reply #141 on: November 16, 2024, 01:45:48 PM
Yes, of course if you may like, here is the photo bewrite the MAG-LITE 6D black flashlight with "patented made in USA", but I detriment the new one without "patented made in USA", Is this MAG-LITE flashlight a genuine product or a counterfeit product? I am looking forward to your reply as soon as possible. Thank you very much.
https://i.ebayimg.com/images/g/MNQAAOSwxNBnE~zL/s-l960.webp
Offline A30000
  • New User
Reply #142 on: November 18, 2024, 04:33:57 AM
Offline A30000
  • New User
Reply #143 on: November 18, 2024, 04:35:57 AM
pr Offline Juan el Boricua
Reply #144 on: November 20, 2024, 07:11:47 AM
Your best bet would be to contact Maglite directly with your query;
https://maglite.com/pages/contact?srsltid=AfmBOor_m7DyZWDHOuzBEJ5bDAXAp4xudZBXHVU6EWPIfjm0vdrsn53y
