Carving folders
de Offline Shuya
Carving folders
on: February 19, 2020, 10:25:45 AM
Hi folks,
I really enjoy whittling at the moment.
What I miss is a proper carving knife.
For rough shaping I use some scandy fixed, and a folder afterwards.
What do I have/used.:
SAKs
usually okish, the alox lack a small blade, the celidor annoy when in longer use (something is always poking)
Case Whittler
Better, sheepfoot blade is good, but I prefer a bladeshape like Vic and then a smaller sheepfood for fine work. the small blades are very thin and flexing.
Boker Carbon Stockman
Good, mainblade too long and pointy.
Any suggestions for me?
se Offline RF52
Re: Carving folders
Reply #1 on: February 19, 2020, 11:18:19 AM
I have seen some flexcut folding knives for whittling, but haven't tried any of them.
You could check it out and see if it is something for you :tu:
https://www.flexcut.com/home/category/wood-carving-knives/carvin-jack-collection
« Last Edit: February 19, 2020, 11:33:14 AM by RF52 »
pt Offline FInixNOver
Re: Carving folders
Reply #2 on: February 19, 2020, 11:53:20 AM
You can use the electrician blade in the alox model.
Enviado do meu Redmi Note 5 através do Tapatalk
Re: Carving folders
Reply #3 on: February 19, 2020, 12:30:06 PM
I have a Carving Jack from Flexcut which I haven't really get to use much.  But it's definitely a legit tool for carving, and beware whenever opening/closing the tool implements, it got pretty stiff spring/pivot and the tools are sharp.
Re: Carving folders
Reply #4 on: February 19, 2020, 02:03:38 PM
us Offline Marcellus
  • What does Marcellus Wallace look like?
Re: Carving folders
Reply #5 on: February 21, 2020, 02:38:40 AM
Two of my favorites
Schrade  34OT , the  older model with tang stamp Schrade Walden if you can find one has better blades for whittling I have found
Victorinox Tinker. I ground off smooth the key ring holder, for more comfortable use. Use a rotary cut off wheel, files and finally fine sandpaper to remove and smooth surface.
My 2 cents
Re: Carving folders
Reply #6 on: February 21, 2020, 06:18:05 AM
 :iagree: I'm not the best or most regular carver but from the little I did do it was pleasurable.
Re: Carving folders
Reply #7 on: February 21, 2020, 10:13:22 AM
Btw, I don't know whether it's completely relevant, but one of my favorite for wood related task is Brisa Enzo Birk 75.  True scandi grind and a solid perfomer, love that knife:
