Ahhh... you place it over something and squeeze, each tab goes into a hole and presses on a button, thereby releasing whatever is inside so it may slide out. Nope, no idea.
A tool for removing and inserting IC's?
Tiny pulley puller
Watch crowns!
Ok two photos for this one(Image removed from quote.)(Image removed from quote.)
This is to remove watch hands (arrows)
You are correct Sir
So is it my turn to ask then?
Does it hold so type of medieval blade? A regular blade?
Is it something to do with levelling frets?
You could almost get a crown for that answer.
Something for installing/removing the nut and/or saddle?
