Custom parts for multitools
ru Offline loki-mobile
on: February 05, 2021, 08:11:59 PM
I'm starting a new project - custom parts for multitools.  :woohoo:
The first thing that will be made - straight blades for Leatherman Surge (slightly increased in length). It is supposed to be made of various steels - now k110 (about 30 blades) has been purchased.
In parallel, two standard sizes of awls for medium tools (rebar/wave) will be made.
At the moment, the size and shape are being worked out, equipment has been purchased, and the estimated production time of the first trial batch is the end of March 2021.
I will listen to your suggestions on the range of spare parts you need.  :whistle:
se Offline RF52
Re: Custom parts for multitools
Reply #1 on: February 05, 2021, 08:45:24 PM
Interesting, definitely following this :tu:
au Offline pietervn
Reply #2 on: February 05, 2021, 09:05:16 PM
I'll follow this too.
If I may add please, a straight blade option for the MUT and Signal will be nice too. Bearing in mind that the Signal grind is not symmetrical though
Pete
nz Offline Syncop8r
Reply #3 on: February 05, 2021, 09:09:37 PM
 :popcorn:
Reply #4 on: February 05, 2021, 09:17:39 PM
Pete
Received.  Blades for other one-handed opening multitool unparalleled with good steel will be as follows.  Tanto-shaped versions of the blade are also suggested.
Отправлено с моего Redmi K20 Pro через Tapatalk
hr Offline Vjeko Posavac
Reply #5 on: February 06, 2021, 03:11:04 PM
 :popcorn:
Great idea!
Reply #6 on: February 10, 2021, 10:05:15 AM
Not a spare part, but scissors that could be put into the Skeletool in place of the blade would be awesome.
Reply #7 on: February 10, 2021, 02:43:33 PM
Very interesting  :like:
I will have a look at my Wave for what would be a great tool to remove the last blade I have left and what would be a good tool to replace the blade to make the Wave a legal carry tool for the UK :tu:
Reply #8 on: February 10, 2021, 07:17:12 PM
Tell me what are the rules in the UK regarding knives? Should there be a two-handed opening or are there any other restrictions?
Reply #9 on: February 10, 2021, 07:19:00 PM
Tanto Surge Plane
Two version - 30° and 45°
Reply #10 on: February 10, 2021, 11:59:38 PM
The law is a pain in the @#*%
We are not aloud a locking blade of any size and the largest blade we can have is 3 inches but only if it is a folding knife with no locks or one handed opening if you would have a LM for instance with the locking mechanism removed it is still seen as a locking knife because you can’t fold the blade away as the handles get in the way of folding the blade back in the handle  ???
gb Offline shadow78
Reply #11 on: February 11, 2021, 10:31:19 AM
There are several ways going around the law in the UK. If you have a wave just put a washer under the blade and it will knock the liner lock out of action. There are also ways to convert a locking blade to non locking. Problem solved.
On the other hand if you have a valid reason to carry a locking blade (eg work) you will be fine. Just use common sense and don't carry one when not need to, so don't have a pint after work with a wave in your pocket ;).
I'm carrying all sort of tools and blades in the UK and never been checked or stopped by the police. I guess this is because I'm not pulling them out in crowd and don't act as a dumbass.
The law makers fall on the other site of the horse here unfortunately, wanted to stop knife crime with stupid laws and punishing people who would use the knife as a tool..
Reply #12 on: February 11, 2021, 12:05:24 PM
Great project, loki :like:
Can't wait to see what all comes of this :cheers: :tu:
ua Offline in_sympathy
Reply #13 on: February 11, 2021, 12:14:13 PM
How about a plain edged blade for a Signal?
Reply #14 on: February 11, 2021, 12:15:20 PM
Oh, I see I’m not the first with this idea
Reply #15 on: February 11, 2021, 01:06:30 PM
Tanto Surge Plane
Great!  :tu:
Can't wait for 30° version
us Offline tommywp
Reply #16 on: February 11, 2021, 01:53:26 PM
Longer blade for the skeletool would be great (there seems to be room for it).
be Offline Top-Gear-24
Reply #17 on: February 11, 2021, 06:27:11 PM
One more vote for a PE blade for the Signal, and a choice between tanto and regular style would be awesome  :tu:.
Reply #18 on: February 11, 2021, 08:01:26 PM
Though honestly any PE for Signal would be awesome  :drool:
nz Offline Syncop8r
Reply #19 on: February 12, 2021, 10:03:05 PM
Have you done a search on Skeletool with scissors mods? There's a few out there...
https://forum.multitool.org/index.php/topic,58438.msg1074485.html#msg1074485
https://forum.multitool.org/index.php/topic,20842.msg389647.html#msg389647
And I'm not sure whose these pics are that I stole for inspiration:
Reply #20 on: February 13, 2021, 03:28:44 AM
I’ll look at the links you posted as well as some more.  It is nice to know someone had success, because all the searches I had done on here and another forum, were listing the scissors that didn’t work.
Reply #21 on: February 13, 2021, 11:25:56 AM
 :o :popcorn:
I was thinking of getting more wrenches. Will wait to see what is available here first. :cheers:
Reply #22 on: February 13, 2021, 11:30:52 AM
Suggestions
Rebar
-Pocket clip
-Diamond file
-t-shank jigsaw holder
-Thinner lanyard ring to replace thick washer and eliminate the massive default lanyard ring
nz Offline Syncop8r
Reply #23 on: February 13, 2021, 11:32:54 AM
Suggestions
Rebar
-Pocket clip
-Diamond file
Oooh yes... pocket clips that can be easily retrofitted to a few models.   :dd:
Reply #24 on: February 13, 2021, 12:06:53 PM
Suggestions
Rebar
-Pocket clip
-Diamond file
The jigsaw holder would be awesome.  I know Metro makes ones for scalpel blades for in place of the Skeletool blade, but a jig saw holder that could work in a few different tools would be awesome.
Reply #25 on: February 13, 2021, 01:23:15 PM
:o :popcorn:
All wrenches in stock
Reply #26 on: February 13, 2021, 06:15:16 PM
Suggestions
Rebar
-Pocket clip
-Diamond file
Let me share your wishes on the complexity of production (on a 10-point scale):
- Wrenches - 3
- Thinner lanyard ring - 3 (You can use fuse/blast ring)
- Awls - 4
- Plane Blades - 5-8 (Depending on the type of steel)
- Serrated|Semi serrated blades - 6-9 (Depending on the type of steel)
- t-shank jigsaw holder - 7-8
- Pocket clip 8-9
- Scissors - 9-10
- Diamond file - 10+
For greater complexity, more technological operations, knowledge and experience are required. As well as equipment.
Offline Cleanser
Reply #27 on: February 21, 2021, 03:45:12 PM
Victorinox 111mm blade possible  :dunno:?
Reply #28 on: February 21, 2021, 04:05:20 PM
If only in the long term
Reply #29 on: February 27, 2021, 09:56:26 AM
First products (alpha version)
1. Large Awl 2.25in/57mm (rebar style)
2. Small Awl 1.65in/42.5mm (Signal style)
Price - $12 (Shipping $6)
No final processing yet. If necessary, you can polish it.
Perhaps by the end of the year will be tumbling.
