Well, it has been an interesting ride. No gap. Isn't it beautiful?(Image removed from quote.)This is the order of the tools, if you want scissors and the package opener in.Leave the can opener and Phillips side as it was. The Phillips allows the pliers to sink deep in the handle, and the can opener is completely to the side of the pliers.On the other handle, from the file's side, you want: FileScissorsPackage openerAwlSmall flat-headPE blade(Image removed from quote.)The thumb plate of the scissors and the tip of the awl get in each other's way. The package opener is short, and the thumb plate goes past it.(Image removed from quote.)Removing a tiny bit of the thumb plate allows the scissors and awl to deploy without issues.If you put the flat-head in the place of the awl, the tip of the flat-head comes more to the middle of the thumb plate, requiring more material to be removed. It is better to have the awl there, and remove just a tiny bit.(Image removed from quote.)So happy it all came together. All you give up are the lanyard ring, and the large flat-head. There is a washer between the can opener and Phillips by default. It could have been a figure 8, and serve as the lanyard hole, instead of having the lanyard take up a whole tool spot. That washer is thick enough to be the lanyard hole.
