The Go BIG Challenge
Nix · 2083 · 76579
Re: The Go BIG Challenge
Reply #360 on: August 07, 2021, 12:55:05 AM
Best scissors in the business for the job!
Day 6 of 60 (10% done!):
Deadheading some marigolds while on garden patrol.
us Offline TonySal
Reply #361 on: August 07, 2021, 01:20:15 AM
join KNIFE RIGHTS
fi Offline old Lefty
Reply #362 on: August 07, 2021, 10:12:57 AM
Day 7:
Trying to visually diagnose reason for intermittent engine control light*
*also known as staring the engine without a clue :) :)
by this axe I rule
us Offline TonySal
Reply #363 on: August 07, 2021, 02:03:25 PM
Magnetized now touch-up  :tu:
7/60
join KNIFE RIGHTS
Reply #364 on: August 07, 2021, 04:12:06 PM
Day 7: Packing lunch!
us Offline Jackpine54
Reply #365 on: August 07, 2021, 04:27:18 PM
Day 7
Was making breakfast this morning when a poor spider dropped into the hot bacon grease. I removed it with the pliers before adding the eggs. I didn't taste it, but it looks to be fried perfectly!
I also used the pliers to loosen the hold down clamps on RV propane cover.
Great pics so far, keep up the good work! :tu:
Reply #366 on: August 07, 2021, 04:46:41 PM
Day 7:
za Offline Max Stone
Reply #367 on: August 07, 2021, 05:19:39 PM
Nice to see awl the pliers getting used, one of my fav tools on a SAK.   :like:
Day 7
The Maxi and the Mini, red of course  :salute:
Reply #368 on: August 07, 2021, 09:11:59 PM
Day 7 of 60:
Swiss Champ accompanied me on watering duties.
Reply #369 on: August 07, 2021, 09:17:47 PM
Day 07/60
SC helped measuring the length of the staples currently loaded. I'll need to get aome 14mm ones.
It also accompanied me on my bike tour.
gb Offline Fast Bill
  • Carpe titanium
Reply #370 on: August 07, 2021, 10:51:34 PM
Day 7/60
Needed to change an inner tube on my bike. Found the irksome flint chip that had caused the mischief and then used the pliers to nip up the valve core on the new tube before insertion. This should stop my screw on pump from locking onto it and taking the core with it at removal. Scissors then helped with puncture repair patch cutting.
Per Titanium Ad Tearoom.
Apex predator of fruit cake
  • Carpe titanium
Reply #371 on: August 07, 2021, 10:52:29 PM
Day 07/60
That looks lovely riding McS  :like:
  • Carpe titanium
Reply #372 on: August 07, 2021, 10:52:51 PM
Reply #373 on: August 07, 2021, 10:57:31 PM
 :cheers: Bill
90% of my tour is on roads ways that size.
Up and down the hills through the country side.
I gave up washing the bike every month...  :D
Excellent fix on your bike  :like:
Reply #374 on: August 07, 2021, 10:59:03 PM
Day 7 of 30
Used fish scaler to help open can of fosters, my fingernails where too short to get pull tap enough high so swisschamp to rescue
Only Tools Matters
Reply #375 on: August 07, 2021, 11:01:53 PM
 :ahhh :ahhh Are we having fun yet?  :D :ahhh
us Offline TonySal
Reply #376 on: August 07, 2021, 11:28:03 PM
Day 7 of 30
Only Tools Matters
  yes... I've used my SAK for that too  :cheers:
join KNIFE RIGHTS
de Offline ulzhan
  • The Spirit of Central Asia
Reply #377 on: August 07, 2021, 11:53:23 PM
Day 07 / 60
That bit driver is a marvel!
Reply #378 on: August 08, 2021, 12:10:00 AM
 :iagree: :tu:
Reply #379 on: August 08, 2021, 12:57:31 AM
Great uses today!   :like:  :tu:
us Offline TonySal
Reply #380 on: August 08, 2021, 02:28:39 AM
 :like:   :iagree:
join KNIFE RIGHTS
  • Carpe titanium
Reply #381 on: August 08, 2021, 08:01:34 AM
:cheers: Bill
Thanks McS you lucky you to be taking a tour. I have a few Lezyne pumps but they're past Masters at removing valve cores from Presta valves from Conti tubes.  :doh:
  • Carpe titanium
Reply #382 on: August 08, 2021, 08:03:42 AM
Are we nearly there yet??
Reply #383 on: August 08, 2021, 09:57:00 AM
I've never had a Lezyne pump, but did you try the SwissChamp's pliers?
Just wondering if they would work for it  :think:
Edit: Saw Rizzie's reply below. I see how that problem could happen. What about screwing them in with some Loctite applied?
« Last Edit: August 08, 2021, 12:54:57 PM by McStitchy »
gb Offline Rizio Il Ghiro
Reply #384 on: August 08, 2021, 11:41:17 AM
Fast Bill - I know what you mean about the screw on fitting on Lezyne track pumps removing the cores from Presta valves! However, once I’ve nipped up the valves (using a Park Tools valve tool) the problem hasn’t happened again. In my experience, the Lezyne pump fitting which screws onto the valve is the best solution for getting tubs up to pressure (for me typically 160-220 psi depending on the tub) and the later pressure relief valve which I was able to fit to my older pump made unscrewing the connector so much easier…. For my other bikes and tubeless tyres I use a JoeBlow which is spot and simple to use, it just can’t go to the pressures I use on my tubs. Here’s a pick of the pressure relief valve (in gold - they didn’t have silver ones at the time) which is well worth getting if your pump doesn’t come with it fitted as standard which the I think the newer ones do.
us Offline TonySal
Reply #385 on: August 08, 2021, 12:09:31 PM
8/60
No idea what you're talking about so I'll just have a good old Nestlé Crunch
join KNIFE RIGHTS
Reply #386 on: August 08, 2021, 02:04:16 PM
Day 8:
I’m lighting with my Smith and my reputation burns all thru the west:
by this axe I rule
Reply #387 on: August 08, 2021, 03:23:20 PM
Always great to see a revolver and speedloaders!  :tu:
For Day 8, used the saw to cut up some kindling for a fire.
  • Carpe titanium
Reply #388 on: August 08, 2021, 03:44:05 PM
Thanks McStitchy and Rizio. After I experienced this out on the road a couple of times (there’s nothing like watching a speeding valve core for getting your undivided attention as it heads for the verge!) I’ve nipped them tight with small pliers and the SwissChamp pliers worked fine for this yesterday. I have also used Loctite. But this is the Go BIG challenge isn’t it  :pok:
  • Carpe titanium
Re: The Go BIG Challengeplus the
Reply #389 on: August 08, 2021, 03:48:52 PM
Thanks Rizio. I don’t run on tubeless as you’ll have gathered and I have seen the relief valve though I’ve never bothered to get one for my Lezyne track pump. Typically I run about 110psi on Michelin Pro 4 Endurance folding clinchers but I have run on Vredestein all weather tyres which go up to 140psi and that’s why I got into Lezyne (plus the sleek engineering).
