Spartan Midsummer Challenge July 2022
Re: Spartan Midsummer Challenge July 2022
Reply #390 on: July 13, 2022, 09:40:35 PM
But alcohol on a paper towel or rag sounds like a better solution. I have a bottle of 91% around that I use on the contacts of old computer/electronics components.
Yes indeed! It's readily available, inexpensive, takes that nasty residue right off, and evaporates quickly.
de Offline tinker gnome
Reply #391 on: July 13, 2022, 09:53:35 PM
You can also use alcohol prep pads typically found in FAKits. I ordered a pack of 200 some years ago and stashed them everywhere: FAK, maintenance kit, photo bag, etc. They are single-sealed and great for cleansing on the go!
Best regards and stay safe,
Wolfgang
Reply #392 on: July 13, 2022, 09:58:53 PM
Excellent tip! :cheers: :tu:
us Online PitCarver
  • Average Old Guy.
Reply #393 on: July 13, 2022, 11:25:32 PM
Just enjoying the afternoon sunshine after a day indoors.
us Offline TonySal
Reply #394 on: July 14, 2022, 12:36:08 AM
for Day 14
Plus scales have a scratch so I have to decided use vs. looks...
join KNIFE RIGHTS
Reply #395 on: July 14, 2022, 03:30:42 AM
Tape residue doesn't worry me greatly. As Tinker Gnome said, a swipe or three with a paper towel dampened with isopropyl alcohol or Zippo juice will remove all but the most persistent tape gunk. And likely it will melt Cellidor (I've heard isopropyl alcohol will do the same to newer magnifiers).
Day 13
The Spartan posed with one of the few die-cast vehicles I can't bear to get rid of: a Corgi Austin Mini (which Austin called the Se7en) by Corgi.
Nice! The bigger 1:36 Corgi I've only recently gotten into, as they're bigger than the Juniors/Husky models I have several of, and are thus difficult to find a place for.
While I have several more in pretty poor shape (most of those being from the '60s, like your Mini), these are displayable at least. The Range Rover is new-old-stock, and the F1 car's wear is mostly to the chrome plated bits.
The John Player Special (Lotus 72E) is English, but the Range Rover is a fairly late Chinese-made piece (box is dated 1999, made not long after Mattel sold Corgi to a group of collectors), but the tooling was made in England originally. Currently, Corgi is owned by Hornby Hobbies, and we don't get 3/4 of the catalog in the States. A few years back they made a three-inch range called "Corgi Toys" that was very well done, and it was never officially sold here. I eventually found an RNLI Flood Rescue set with a Land Rover Defender and boat from an eBay seller in Georgia a couple of years ago, and that was it.
« Last Edit: July 14, 2022, 03:36:58 AM by cody6268 »
Reply #396 on: July 14, 2022, 03:34:59 AM
Day 14: tightened a screw holding on a mirror, and used the blade for various cutting chores.
Sorry about the lighting. The ballast blew on the fluorescent light that is used on this side of my room a month ago, and I've been meaning on replacing the whole unit with an LED, but have been having trouble finding people to do the work.
us Offline marlowe221
Reply #397 on: July 14, 2022, 04:03:18 AM
Day 13
No opportunities to use the 70s Standard today. Unfortunately I was in meetings all day…
Reply #398 on: July 14, 2022, 05:02:49 AM
Day 20
Light day for Woody. Some small blade work on a few packages, but nothing exciting. Instead, someone asked for a cat pic earlier in the challenge and never got one, so here's Pumpkin.
gb Offline Fast Bill
  • Carpe titanium
Reply #399 on: July 14, 2022, 09:25:19 AM
A Late day 13 post. Took my yellow scaled Sportsman out for the day but ended up using my Rescue Tool for some paper cutting of a large scale drawing on heavy gauge paper from its temporary mounting on a wall (where it had been drawn). Didn't want to take any chances ripping the paper inadvertently given it's size and content so the  111mm serrated blade was just right in the absence of a Stanley knife. A parcel of bike lube turned up later and the Sportsman helped open that.
Per Titanium Ad Tearoom.
Apex predator of fruit cake
  • Carpe titanium
Reply #400 on: July 14, 2022, 09:27:59 AM
Thanks for the tip!
I usually use water and a little dish soap. But sometimes I guess I get a little sloppy - I sometimes find I need to re-oil the blade I just washed because it gets stiff to open afterwards.
I tend to clean blade gunk with a little lighter fluid
us Online Barry Rowland
Reply #401 on: July 14, 2022, 01:17:00 PM
 :iagree: or some WD-40.
Reply #402 on: July 14, 2022, 01:19:14 PM
Day  14: Took a walk in the beautiful weather.
Reply #403 on: July 14, 2022, 01:22:30 PM
Powernoodle Day 14
NOOOOOO!!!!!!
 :ahhh  :rant:  :ahhh
In tribute to Captain Marlowe, this blade is sterilized, pasteurized and sanctified.
Reply #404 on: July 14, 2022, 05:29:55 PM
Powernoodle Day 14
Seeing that setup, how easy is it to use the SAK or the Spyderco, being held together withn that split ring? Do you separate them before or use as they are?
 :think: :think:
Reply #405 on: July 14, 2022, 05:32:03 PM
Powernoodle Day 13
Strangely, I used the Spartan to open an Amazon package.  And just for Marlowe, there is some tape residue on the blade.
   :cheers: :ahhh :ahhh
 :twak: :twak: :twak: :twak: :twak: :twak: :twak: :twak:
Reply #406 on: July 14, 2022, 05:44:11 PM
Oh man, I can't STAND to have packing tape gunk on my SAK. To the point that I will often avoid using it to cut tape like that - even after I wash it off it still feels a little sticky...
I often use the tip of the corkscrew or back phillips to try to "break" the tape. Sometimes if you can just get it started, the tape will split as you pull up on the lid of the box.
i usually use paint thinner to clean that horrible stuff off.
WD40 or similar in a pinch.
i prefer the small blade since it's easier to clean,with no grooves or indentations to trap that gunk
Day 14
i used the large driver to pry off the cap,and the awl to puncture,a deodorant can
20220714_141314 by Humayd a r Mahomedy, on Flickr
20220714_141402 by Humayd a r Mahomedy, on Flickr
Reply #407 on: July 14, 2022, 05:46:27 PM
 :think: :think:
I've only have these on the same ring during this Challenge.  I do it mostly to help me find them in my left front pocket, where I also have a big set of keys, a Sharpie and a 2xAAA pen light.  I do not separate them for use, as my usage is limited to opening Amazon packages, cutting a few weeds or maybe a red pepper.  I have not used the Spyderco during the Challenge.
 :salute: :salute: :salute:
Reply #409 on: July 14, 2022, 06:00:39 PM
Powernoodle Day 14
I am pleased to have attained the rank of Captain!
Reply #410 on: July 14, 2022, 06:32:36 PM
The John Player Special (Lotus 72E) is English...
Had I known you had that one, I'd have sent you a Hesketh 308 F1!
Here's Pumpkin.
Pumpkin reminds me of my Jimmy! :like:
In my case, that would mean jumping from E-4 to O-6.
Day 14
The Spartan made some friends today. Thanks to Cody6268 for an awesome trade! :cheers:
us Offline TonySal
Reply #411 on: July 14, 2022, 06:37:22 PM
Congrats Marlow !  :salute:
I agree with Farmer, me attaining O6 would be an actual miracle @
join KNIFE RIGHTS
Reply #412 on: July 14, 2022, 07:36:35 PM
Something came in the mail. I know! I'll use my 70s Standard to open it!
Hmmm.... What could it be?
It's a Camper!
Looks like a modern SAK, based on tang stamps, etc. I look forward to having a chance to use the wood saw (after this challenge is over, of course).
Reply #413 on: July 14, 2022, 08:16:11 PM
Looks like it's in good condition, too. Congratulations! I'm sure you can give the wood saw a quick test without running afoul of the challenge rules, and that you'll find it a very useful addition to your SAK arsenal.
Reply #414 on: July 14, 2022, 08:59:04 PM
Day 13, and my full EDC
Reply #415 on: July 14, 2022, 09:34:18 PM
It’s in great shape. Doesn’t even need any oil in the joints!
Also, I don’t know what the rules of the challenge even are!
Reply #416 on: July 14, 2022, 09:42:06 PM
DAY 14  How appropriate the last day of summer school falls on Bastille Day.  My last day in the no knife zone!  No SAK, no usage.   :(  So I took a Spartan group shot.   Spartans tend to get thrown in on deals, and have industrial advertising (which I like), so I've  got a lot of them.
Reply #417 on: July 14, 2022, 11:00:49 PM
Day 14 and its Pinstripe and tortellini
  • Carpe titanium
Reply #418 on: July 14, 2022, 11:05:34 PM
Day 14 with some Jaffa cake opening by my Wild Night.
Nice saw Marlowe  :cheers:
  • Carpe titanium
Reply #419 on: July 14, 2022, 11:06:33 PM
Smart, stylish … and tasty :like:
