It may not be a fancy anodized titanium multitool with combination wire cutters and a fish scaler, but when you have problems with your tires (as I frequently do at work
) this could be the best smurfing $6 tool you've ever owned.
Officially this is a 4 Way tool that taps internal and external threads and reams inside valve stems, but the other feature of this tool is 100% the reason I have it- it has a valve core wrench.
If you have ever tried removing a valve core with the tips of needlenose pliers or some other method, you know the value of a valve core wrench.
Worse, as useful and it is, and as necessary as it is, in all of my vast collection of multitools, I only have
one multitool that has a valve core wrench- the humble and mostly forgotten about Frog Tool from Gatco Timberline.
https://multitool.org/tools/one-piece-tools/gatco-timberline-frog-tool-review"But Grant, why do you need to remove the valve core so frequently that you require a dedicated tool?" you might ask.
The answer is simple- I drive in some seriously smurfy locations for work and I pick up a lot of nails and screws in my tires, and my boss won't pay for them, so I have to plug, patch or goo my tires for as long as I possibly can because those damned things are not cheap.
So, there you have it- the Victor 4 Way Tire Valve Tool- don't leave the driveway without it!
