Show Us Your EDC gear!!!
Gadget Guy · 8430 · 1593556
Re: Show Us Your EDC gear!!!
Reply #8190 on: September 08, 2024, 07:07:44 PM
Thanks FX.Have never seen a voyageur SAK before. Thanks for sharing and do feel free to show a spread eagled pic LOL :-)
I had to go custom Cadet SAK to get a 91mm scissors installed
Mine is not an original Voyageur either, it is also a custom with modded 91mm scissors
Sent from my iPad using Tapatalk Pro
au Offline Heywood Floyd
Reply #8191 on: September 08, 2024, 07:39:07 PM
Very nice indeed Sos24. Thanks for sharing :-)
Reply #8192 on: September 11, 2024, 10:26:33 AM
Reply #8193 on: September 16, 2024, 10:33:01 PM
Reply #8194 on: September 17, 2024, 04:19:14 PM
That Opinel... :drool: But what did you crack the walnuts with? :think:
Reply #8195 on: September 17, 2024, 06:50:04 PM
Do you really need to ask?!
 :D :D :D :D
Reply #8196 on: September 17, 2024, 07:31:53 PM
 :D :D :D :D
The above previous post Opinel is a No.8 carbon.
Below are the two No 8 pin stripe brothers. The darker is a Bubinga wood handle, suntanned with some flame and connected to a stainless steel blade.
I use my hands to crack the wall nuts. Two nuts is trivial and a single between two palms is harder but quite doable. If we're talking about cracking Macadamia nuts by hand alone, well that's way beyond my pay grade.
Reply #8197 on: September 18, 2024, 03:20:45 AM
Those Opinels are fantastic! :like: :drool: Somehow I doubt I could crack a walnut by hand...and now I'm wanting a walnut Opinel. :D
us Offline G-Dizzle
Reply #8198 on: September 18, 2024, 03:43:37 PM
Did you do the work on these yourself? How much grinding was needed to fit the thumbstud? Thanks!
Reply #8199 on: September 18, 2024, 04:40:09 PM
(If this is too long, mods please remove)
Yes I did work on these myself. The two part answer to your questions …
First the simple "Checkering" tool from my youth and the handle pin striping then the thumb stud. Lastly a short vid of it in real life.
Part 1 • The Handle
Many years ago and well before yours truly had become a teenager, I was enamoured with firearms. Gees, I could recite projectile weights, load in grains, muzzle velocities, distance drops of my favourite cartridges and shoot pretty well too. Gun design and gunsmithing looked very interesting and so set my mind to modifying the stock of my Gecado air rifle. That meant making a tool to make it happen so whilst in my Dad’s workshop, I stole a welding rod (manual metal arc stick), beat the flux off it and wire brushed it at one arbor end of a stone grinder. Next formed it with heat from an oxyacetylene kit to get a desired handle bend and with hammer flatten what would become the cutting end. The cutting head got finally formed with some fine files and heat treated via oxyacetylene and oil. I tried firstly with water but over heated the rod material and cracked it via thermal shock.
If you’ve come this far, so what is the significance of this recount. Well, I still have that tool and it is what was used to put the pinstripe pattern on the Opinel shown.
On a personal note, my Father was incredibly gifted at making steel do what he wanted. He happened to be working on a project and in a sincere effort to be like him I took on my big checkering tool project at the same time. What a laugh in retrospect and yeah those were wonderful times.
My very old amateur "Checkering Tool"
Part 2 • The Thumb Stud
Here’s my current thumb stud solution …
In order for the KWIK thumb stud to sit properly I had to remove a modicum of handle wood. That is so the grub screw could at least completely bite the blade, the blade could land fully in the handle and when open the recasso (not the stud) acted properly as the stop. That locus point necessitated the simplest of handle mod pictured.
btw, the KWIK thumb stud also acts as a neat thumb ramp when the blade is deployed.
Operating the Opinel swivel lock with thumb and forefinger is not a problem with one hand.
No 8 Carbon Steel result …
us Offline G-Dizzle
Reply #8200 on: September 18, 2024, 05:28:12 PM
Part 1 • The Handle
Thanks for such a detailed explanation!! You did a good job on those knives.
us Offline G-Dizzle
Reply #8201 on: September 18, 2024, 05:35:42 PM
Also, you should share photos of these in the Opinel thread in the Edged Tools section. I’m sure they would be appreciated.
Reply #8202 on: September 18, 2024, 05:47:46 PM
Sure, will do & thanks! :-)
Reply #8203 on: September 19, 2024, 12:43:25 PM
Reply #8204 on: September 19, 2024, 09:48:19 PM
 :like: What is the one-piece tool? It looks to have a link of motorcycle drive chain attached to it. :think:
Reply #8205 on: September 19, 2024, 10:12:29 PM
MULTITOOL: JDR Knife & Tool Hammerhead - CPM S30V
+ MC Chain master link
+ Cu lanyard bead twist single wrap weld by Yours truly
Reply #8206 on: September 19, 2024, 10:16:48 PM
 :hatsoff:
Offline Cypren
Reply #8207 on: September 19, 2024, 10:58:29 PM
Like any hopeless gadget nerd well-adjusted adult, the contents of my pockets are constantly changing, but this is what I'm carrying today.
us Online nate j
Reply #8208 on: September 20, 2024, 02:51:19 AM
You’re among kindred spirits here…
us Online nate j
Reply #8209 on: September 20, 2024, 02:53:16 AM
Looking good!
I was a little surprised not to see you and your fountain pens in the September pen challenge.
Reply #8210 on: September 20, 2024, 06:47:20 AM
Looking good!
Thank for mentioning it Nate.
Wasn't there because of my ignorance and too much RL going on at the moment.
The FP interest, use and collecting has been with me for a long time but online participation is limited. Nonetheless am trying to arrange attending a not so nearby Pelikan Hub later this month.
Reply #8211 on: September 21, 2024, 01:43:34 AM
I would have very much liked to have you along for the pen challenge. But I know how life can get. Maybe I'll repeat it down the road. :cheers:
Reply #8212 on: September 21, 2024, 11:12:11 AM
Thanks FX  :cheers:
Reply #8213 on: September 21, 2024, 11:13:16 AM
Reply #8214 on: September 21, 2024, 03:46:50 PM
Mini Tool! :like:
Reply #8215 on: September 21, 2024, 10:54:29 PM
Mini Tool! :like:
Thanks FX. It seems like the Mini-Tool still appeals to enthusiasts. It's one of my favourites. Unfortunately compactness, capability and usefulness do not always go hand in hand with sales so being a retired product makes them a bit harder to find.
Reply #8216 on: September 21, 2024, 10:59:54 PM
Reply #8217 on: September 22, 2024, 12:41:56 AM
Another nice carry! :tu: I don't know when I last looked for Mini Tools on eBay...indeed, if I ever have. I'm pretty fortunate and happy to have the one I do.
us Offline G-Dizzle
Reply #8218 on: September 22, 2024, 02:39:31 AM
Reply #8219 on: September 22, 2024, 11:59:56 AM
Would love to see the details on that SAK!
Victorinox SAK Pioneer Alox black custom by rickinFL
Had it for over a decade OMG!
It's Ceracoat-ed and has stonewashed tools as pictured.
IIRC rickinFL told me it was the first custom he'd ever completed.
Some closer pics ...
Family pic …
