I also want to see one call The Engineer, not sure which person that would be aimed at, but it could be something really neat.
Would a telescoping magnet be better for that use?
Quote from: Metropolicity on September 11, 2011, 07:37:39 AMWould a telescoping magnet be better for that use?Probably. My reflex is to keep magnets away from computer internals, but hard drives are well-shielded enough these days that a small magnet would not be a problem.
Any reason for the trapezoidal blade? Whittling? I am working on hammer attachment for another project, still trying to figure out some logistics like if it can be a two point connection or just a single. Great idea! What about adding a bubble level? I would err on the side of "wasting" an outside opening for a metric ruler in favor for the crook blade. What could happen is a metric ruler (I have a laser etched one) can be shaped and sandwiched on the outside of the scale, just plane down the scale .5mm to flush it up. I saw a crazy small wood plane the other day and I thought it was so neat! Maybe that too.I find the saw to be too aggressive for anything short of a knocking a tree, so possibly a T-shank based saw blade, outside opening, like the Surge. Also, what wood worker would be without a marking tool, a pencil or lead holder. Maybe this can be called The Craftsman...Marked down as an idea!
Quote from: Metropolicity on September 11, 2011, 02:42:44 AMAny reason for the trapezoidal blade? Whittling? I am working on hammer attachment for another project, still trying to figure out some logistics like if it can be a two point connection or just a single. Great idea! What about adding a bubble level? I would err on the side of "wasting" an outside opening for a metric ruler in favor for the crook blade. What could happen is a metric ruler (I have a laser etched one) can be shaped and sandwiched on the outside of the scale, just plane down the scale .5mm to flush it up. I saw a crazy small wood plane the other day and I thought it was so neat! Maybe that too.I find the saw to be too aggressive for anything short of a knocking a tree, so possibly a T-shank based saw blade, outside opening, like the Surge. Also, what wood worker would be without a marking tool, a pencil or lead holder. Maybe this can be called The Craftsman...Marked down as an idea!Great idea, plane and bubble level would be great!!! I was short on creativity yesterday. I also thought on something like a sandpaper holder, a device with a flat surface and some type of clamps to hold and stretch the paper. About the marking tool, good to have but I'm not sure how it would feel to write with a heavy multi-tool. And craftsman it's definetly a better name!!
Quote from: Metropolicity on September 11, 2011, 07:17:26 AMI also want to see one call The Engineer, not sure which person that would be aimed at, but it could be something really neat.I started off thinking about this before the Cordwainer, but wasn't convinced about what I came up with :-Replace plier heads with spring arrangement only - though maybe having a 1/2" ratchet drive at the head? Long arms for use as internal/external calipers and dividers - with quick set spring adjustment(though a fun concept, achieving a precise enough result on a multi-component assembly would be very challenging for accurate caliper measurements)Imperial/metric feeler guages and thread guages Automatic centre punch Replacable diamond fileTorx & hex keys (or bit driver) for swapping out indexable inserts on various tooling typesIf you can figure out a way to incorporate a variable velocity ultrasonic thickness guage and surface roughness meter, that'd be very nice
Quote from: 50ft-trad on September 11, 2011, 11:25:16 AMQuote from: Metropolicity on September 11, 2011, 07:17:26 AMI also want to see one call The Engineer, not sure which person that would be aimed at, but it could be something really neat.I started off thinking about this before the Cordwainer, but wasn't convinced about what I came up with :-Replace plier heads with spring arrangement only - though maybe having a 1/2" ratchet drive at the head? Long arms for use as internal/external calipers and dividers - with quick set spring adjustment(though a fun concept, achieving a precise enough result on a multi-component assembly would be very challenging for accurate caliper measurements)Imperial/metric feeler guages and thread guages Automatic centre punch Replacable diamond fileTorx & hex keys (or bit driver) for swapping out indexable inserts on various tooling typesIf you can figure out a way to incorporate a variable velocity ultrasonic thickness guage and surface roughness meter, that'd be very nice You mean like a feeler gauge and your finger? Haha!
The SAK-modder? With a ball peen hammer, pin head drill, punch, metal file, removable vise...
Quote from: Reinier on September 11, 2011, 12:58:19 PMThe SAK-modder? With a ball peen hammer, pin head drill, punch, metal file, removable vise...I've been thinking about this one too! Would a watch case opener from Wenger be a good scale remover?
Quote from: Metropolicity on September 11, 2011, 10:28:53 PMQuote from: 50ft-trad on September 11, 2011, 11:25:16 AMQuote from: Metropolicity on September 11, 2011, 07:17:26 AMI also want to see one call The Engineer, not sure which person that would be aimed at, but it could be something really neat.I started off thinking about this before the Cordwainer, but wasn't convinced about what I came up with :-I primarily do studio and location work and I haven't used a light meter in years...hahaReplace plier heads with spring arrangement only - though maybe having a 1/2" ratchet drive at the head? Long arms for use as internal/external calipers and dividers - with quick set spring adjustment(though a fun concept, achieving a precise enough result on a multi-component assembly would be very challenging for accurate caliper measurements)Imperial/metric feeler guages and thread guages Automatic centre punch Replacable diamond fileTorx & hex keys (or bit driver) for swapping out indexable inserts on various tooling typesIf you can figure out a way to incorporate a variable velocity ultrasonic thickness guage and surface roughness meter, that'd be very nice You mean like a feeler gauge and your finger? Haha! That's a bit like saying what do you need a light meter for if you've got eyes, but yeah - I'll give you that one
I primariliay do studio and a ton of location work, I havent used a light meter in years!
Quote from: WWW on September 11, 2011, 10:52:19 PMQuote from: Reinier on September 11, 2011, 12:58:19 PMThe SAK-modder? With a ball peen hammer, pin head drill, punch, metal file, removable vise...I've been thinking about this one too! Would a watch case opener from Wenger be a good scale remover?Always good to know! Nice idea but the can opener actually works better.
Quote from: Metropolicity on September 12, 2011, 12:51:15 AMI primariliay do studio and a ton of location work, I havent used a light meter in years!Cool, what do you shoot mostly? I did professional product photography for a few years.
Absurd huh? How about the Autotool? Oh wait, Victorinox already made that ..... what about one with a pate spreader and cocktail fork? Oh wait.... never mind....DefSent from my MB860 using Tapatalk
Quote from: Grant Lamontagne on September 12, 2011, 10:35:04 PMAbsurd huh? How about the Autotool? Oh wait, Victorinox already made that ..... what about one with a pate spreader and cocktail fork? Oh wait.... never mind....DefSent from my MB860 using TapatalkAhem...TACTICAL nose picker or OOOHOTNP.
Quote from: Metropolicity on September 12, 2011, 10:41:11 PMQuote from: Grant Lamontagne on September 12, 2011, 10:35:04 PMAbsurd huh? How about the Autotool? Oh wait, Victorinox already made that ..... what about one with a pate spreader and cocktail fork? Oh wait.... never mind....DefSent from my MB860 using TapatalkBack on topic! *whip*Ahem...TACTICAL nose picker or OOOHOTNP.Fixed.
I present: The Ghosthunter1. Guthook serrated blade and scale replaced with a laser thermometer/humidity pen2. One set of inner tools replaced with a holder for a vial of holy water3. Saw replaced with a folding iron cruciform4. Second set of inner tools replaced with a bell. Ghosts hate bells.5. File replaced with an infrared light source for low-light video recording6. Knife blade given a light coat of silver (That totally works on ghosts, right? Or I guess you should be prepared for werewolves as well).7. Knife scale machined to accept an Our Lady of Guadelupe or St. Michael's pendant with a relic in the back.
The Pornstar;dare I say more?
Quote from: Cleanser on September 11, 2011, 09:36:36 AMThe Pornstar;dare I say more?You need to elaborate. Whatever you say it must include the word fluffier haha
Well I would like to throw in the beerplumber but it really close to the already made arborman. I use shears for tubing cutters all the time. Tools would include but are not limited to a small Allen key (3 mm I think) for tap handle set screws, a digi thermometer set into the scales with a fold out probe, a tap wrench (I'll post a pic of one), bottle opener obviously, proly a large LM bit holder knife blade ect. Wondering about modding a plier head to use as crimpers instead of the shears or including a 1/4 inch nut driver for gear clamps. Zany factor is also lacking on this idea.
