What did you use your Leatherman for today?
trouthunter · 5189 · 492981
Re: What did you use your Leatherman for today?
Reply #4560 on: May 20, 2021, 03:27:24 PM
Stroopwafels  :drool: :drool: :like:
ph Offline an0nemus
  • I Tool Therefore I Am
Reply #4561 on: May 28, 2021, 05:22:19 AM
One of my switch's pins got bent so I used my Juice's small pliers to bend it back straight  :multi:
(Thanks again, Nix, for this LM!)
Reply #4562 on: May 28, 2021, 08:45:51 AM
Good use, very fond of the Juice line, the S2 punches above its weight IMO, the CS4 has been my travel MT for many years :like:
cs Offline marko14
Reply #4563 on: May 30, 2021, 10:47:14 AM
OHT against thorn
Sent from my SM-G960F using Tapatalk
Reply #4564 on: May 30, 2021, 03:19:18 PM
Great uses guys  :like: :tu:
Reply #4565 on: June 09, 2021, 10:55:23 PM
My Bond just got used harder than I have used pretty much every Leatherman. Normally I have a pair of 160mm Knipex combination (linesman's type with bolt gripping channel) in there along with a 8" pair because the smaller pair fits between staves; and the 8" gives me good leverage, but fits in tighter spaces than my full-on fence pliers.  Well, today, Granddad and I were checking fences in the UTV, and noticed that a corner of the lower line fence had been pushed from underneath. The people that own that property bordering us are downright horrible when it comes to maintaining their fence lines. So, I had to push the fence in and affix two clips. I had the clips. But, somehow, I'd misplaced the smaller pair of Knipex pliers. The specialty tool I bought for post clips got one side of the first clip I used in, and then the other side would not go. Finally, I just had to bend that end with my Bond. Not my ST300; not my Surge (or even my better-for-fencing multitool the Swisstool). Took it surprisingly well. For jobs like these, I try to avoid using PST/Rebar/Bond sized tools. Rebar has done it before, however. I Just wish LM would go back to finer teeth on the pliers. These newer style teeth don't grip well; but they do wear better.
I'm going to find a bolt and drill a small hole in it; or perhaps find a hitch pin that will work (which I had). While the speciality tool works, it really only works about half the time. A lot of times, it either doesn't fit, or the clip is at an odd angle.
us Offline 5S Dude
Reply #4566 on: June 18, 2021, 02:50:02 AM
Skele helped install an very old CB radio into my very old motorhome today...
Offline MrToolJunkie
Reply #4567 on: July 06, 2021, 07:27:21 AM
I used my Surge several times this weekend. Today I opened a couple packages of Spax screws with the serrated blade. I used the pliers to get out a few wood screws that did not properly seat into some  plywood I am laying down to build up a subfloor. I used the saw to cut a small piece of ply to fit an area in a closet to help level before installing luxury vinyl planks. I used the bit exchanger and ratchet adaptor to dismantle an old office chair to fit in the trash.
So, what did you do today with the assistance if your LM?
nz Offline Syncop8r
Reply #4568 on: July 06, 2021, 12:09:17 PM
Good stuff. :tu:
You might want to check out this thread: https://forum.multitool.org/index.php/topic,37474.4560.html  :salute:
Reply #4569 on: July 07, 2021, 01:21:46 AM
Thanks! I searched threads and did not see this one. Can the mods merge them? Thanks!
Offline stugumby
Reply #4570 on: July 07, 2021, 03:38:18 AM
I used the P-2 screw driver/large to put on new temp tags on new security patrol vehicle.
Reply #4571 on: July 07, 2021, 05:38:27 AM
Done  :cheers:
Reply #4572 on: July 08, 2021, 06:13:46 AM
Thank you!  :hatsoff:
us Offline countrydirt
Reply #4573 on: July 10, 2021, 02:53:56 AM
No pics because...well, I was working on something.  I had a couple of big drywall patches to make and my Wave did a fantastic job with the serrated blade of making guided cuts to trim to size.  I've used the serrated blade more in the past month than I have in the previous 15 or more years.  And...I've learned how to sharpen that blade on my Spyderco sharpmaker deal.   The more I use the Wave, the less I think of the Bond.  I knew there was a reason I bought that first gen Wave 20 years ago.
bg Offline DavisNikolov
Reply #4574 on: July 12, 2021, 11:08:07 AM
Yesterday evening I went to the nearby river for a little "me time". The river has been high and muddy for quite long, which isn't good for fly fishing. But now it has lowered and cleared a bit so I managed to catch few chubs. The Wave rode with me and the scissors helped with cutting the excess line. What I found out is that I can take the scissors out, cut what I wanted, but instead of folding them back in the handle I just opened them so the tip would be covered (don't underestimate the tips on those small scissors, a Gerber Splice got me really good !). So next time I needed them they were one hand accessible and pretty much safe to carry. Knife cut some small branches from a willow tree to free my fly few times. The pliers helped get the hook out and safe the life of one especially greedy, finger sized, baby chub. A great way to end the week  :)
Reply #4575 on: July 12, 2021, 01:42:48 PM
 :like: :tu:
us Offline BadMechanic
Reply #4576 on: July 12, 2021, 11:27:22 PM
Used my BO Surge scissors to cut the plastic tie on new package of socks. My toes thank Mr. Surge.  :salute:
Offline dmattaponi
Reply #4577 on: July 13, 2021, 03:43:29 AM
To open the cap on a carton of Egg Beaters that didn’t want to cooperate
Reply #4578 on: July 17, 2021, 06:36:36 AM
Pulse used to prize out the tools on the Pradel. Rust and dirt removed, blade sharpened, joints oiled. If not quite good as new, not at all bad
za Offline Max Stone
Reply #4579 on: July 17, 2021, 02:34:04 PM
So please you resisted the temptation to use the awl there  :facepalm:
us Offline ElevenBlade
Reply #4580 on: July 17, 2021, 07:58:57 PM
Egg Beaters!
Blood hell.  I've been raking my brain trying to think of the name of the stuff.  I've been "googling" so many things under the shopping tab that Google has stopped giving me results and is only telling me to click on my recent searches any more.
Get frustrated... pop on MTo... and BAM!  I have the answer.  Now I can finish my shopping list
nz Offline Syncop8r
Reply #4581 on: July 18, 2021, 12:35:56 AM
A carton of egg beaters?  :think:
Reply #4582 on: July 18, 2021, 01:38:34 AM
Reply #4583 on: July 18, 2021, 06:18:46 AM
No awl on the pulse Max :pok:
Needed something flat to gently lever up the awl on the Pradel, worked perfectly :tu:
« Last Edit: July 18, 2021, 09:09:47 AM by Echotech »
Reply #4584 on: July 18, 2021, 10:34:26 AM
Pulse used to prize out the tools...not at all bad
Reply #4585 on: July 18, 2021, 10:45:49 AM
Reply #4586 on: July 18, 2021, 03:12:04 PM
Offline dmattaponi
Reply #4587 on: July 18, 2021, 03:48:43 PM
Egg Beaters!
Haha, glad to help out:-).  They are pretty good with some no salt garlic and herb seasoning by the way.
Reply #4588 on: July 18, 2021, 05:01:37 PM
Pretty hot day again here.
Opened a cold one with Flair  :P
Reply #4589 on: July 18, 2021, 08:41:48 PM
Looking cool  :tu:
