Knife re-handling project.
Roadie · 247 · 23773
gb Offline Roadie
  • Hello...is this thing on?
Re: Knife re-handling project.
Reply #150 on: May 31, 2008, 10:22:30 PM
Me thinks it wasn't an MT.
Me thinks you're wrong :D
Reply #151 on: May 31, 2008, 10:22:39 PM
Well what the bloody hell is it :think:
gb Offline Roadie
Reply #152 on: May 31, 2008, 10:23:12 PM
You tell me :D
p.s. my collection pic isn't too hard to find so that should narrow it down ;)
Reply #153 on: May 31, 2008, 10:23:46 PM
A spirit.
gb Offline Roadie
Reply #154 on: May 31, 2008, 10:24:25 PM
A spirit.
Nope :D Not many left to go now!
Reply #155 on: May 31, 2008, 10:24:43 PM
You tell me :D
Your going to make...me...work :o
Reply #156 on: May 31, 2008, 10:25:07 PM
A crunch
gb Offline Roadie
Reply #157 on: May 31, 2008, 10:25:12 PM
Yes....yes i am :D
gb Offline Roadie
Reply #158 on: May 31, 2008, 10:25:31 PM
A crunch
Yep!! Thats the sausage :)
Reply #159 on: May 31, 2008, 10:26:19 PM
A crunch
I win!  And on my first guess too.  ::)
Reply #160 on: May 31, 2008, 10:26:25 PM
A crunch
So what does ben win, or is it the afore mentioned sausage :D
gb Offline Roadie
Reply #161 on: May 31, 2008, 10:27:26 PM
Well i thought the fact that he won something would be good enough for him :D
Damn, I lost.  :D
You ought to be used to that feeling by now :P :D
Reply #162 on: May 31, 2008, 10:27:36 PM
I don't wan't Ryan's sausage thanks!  >:(
Reply #163 on: May 31, 2008, 10:30:42 PM
Maybe just spelling lesson's from him then :P :D
Reply #164 on: May 31, 2008, 10:33:55 PM
Actually that was grammar related, not spelling.  :P
Reply #165 on: May 31, 2008, 10:34:58 PM
Well if you want to be pedantic... :D
us Offline WhichDawg
Reply #166 on: June 01, 2008, 01:29:43 AM
looks like it's coming along nice Roadie! it looks like fun too :cheers:
I am slightly confused (what a surprise huh!) why would you drill the holes
before you glued one slab on? isn't that asking for un-straight/problems?
if one slab was glued to the tang first (and set) "then" you drilled your
holes through it (through the tang first), wouldn't they be perfect then?!
:twak: me if I'm nuts :D
gb Offline Roadie
Reply #167 on: June 01, 2008, 10:15:57 AM
Not necessarily. The blade is only a couple of mm thick so that would be all the guidance you have for the drill which isn't enough really (unless you have a pillar drill, in which case you wont have any problems!) And once the first hole was done i slipped a pin in it to stop it moving then moved onto the 3rd one and pinned that. The only problem you might have is with the alignment of the front of the slabs. But a liberal application of gaffer tape stopped any movement of that during the drilling process.
Hope that makes sense :)
Reply #168 on: June 01, 2008, 10:37:32 AM
sounds like you got it to work ;) I know it's not done but how's it feeling in your hand now (weight)?
and how will you be sanding/finishing? sealant?
gb Offline Roadie
Reply #169 on: June 01, 2008, 10:53:04 AM
At the moment it's slightly lighter than an F1 (140 vs 150g) the balance point at the moment is just to the rear of the 1st pin but that will move forward as more material is removed. Its a bit too blocky though at the moment for any real feel of comfort but it's gonna be wider than the handle of the F1 so it should fill the hand fairly nicely :)
As for finishing, it will be taken up to 600grit sandpaper then i'll use some sort of oil to seal/finish it properly, haven't decided what sort yet though :)
gb Offline Roadie
Reply #170 on: June 03, 2008, 10:36:22 PM
Well a couple of hours with some sandpaper this afternoon brought me to this stage :) Still needs a bit more work at the blade end of it but i think it looks pretty nice! Can't wait to get it finished, but that will probably be a good few days :)
« Last Edit: June 09, 2008, 02:13:54 PM by Roadie »
Reply #171 on: June 03, 2008, 10:53:05 PM
It's good that your pacing yourself mate :), I used to rush through things and ruin them before I learned a modicum of patients ::)
gb Offline Roadie
Reply #172 on: June 03, 2008, 10:55:10 PM
It's not due to being patient! It's due to having to revise for exams :( It also looks a lot better in real life than that pic, i'll have to try get a decent pic tomorrow :)
Reply #173 on: June 03, 2008, 11:00:51 PM
Nowt wrong with that piccy mate :)
gb Offline Roadie
Reply #174 on: June 03, 2008, 11:02:36 PM
No it's a decent pic, but it doesn't show it in its best light :) (pun intended :D )
Reply #175 on: June 03, 2008, 11:05:34 PM
Sad ::) :D
gb Offline Roadie
Reply #176 on: June 03, 2008, 11:06:52 PM
Sad ::) :D
:P I don't care what you think of me :D :D
Reply #177 on: June 03, 2008, 11:08:26 PM
Sad ::) :D
Yes you do, and don't pretend otherwise :D
gb Offline Roadie
Reply #178 on: June 03, 2008, 11:17:41 PM
Yes you are in fact right, the only reason i joined this forum was to gain your respect and praise......
The preceding text was in fact utter codswalllop!!
Reply #179 on: June 03, 2008, 11:19:37 PM
I'm not so old that my eyesight can't read the small print whippersnapper :twak: :D
