What SOG are you carrying now?
ducttapetech · 1692 · 161095
es Offline ThePeacent
Re: What SOG are you carrying now?
Reply #450 on: April 24, 2016, 05:32:19 PM
On my second day of carrying I'm already thinking of swapping some of the Powerplier tools for scissors, they're just too handy, and who the hell needs a Robertson drive here in Europe?  :think:
What size Robertson is it?
Being an European I am quite unfamiliar with robertson screws/drivers, but I'd say it's a Robertson size 2 (it ain't written on the tool itself)
I carried this beauty today as well and it came handy unexpectedly when i had to screw back a door's pommel that was quite wobbly and loose. Nobody asked for it, but it bothered me seeing it this way when I went to the bath...
My toys:
us Offline Gryffin
  • Multi-Talented
Reply #451 on: April 24, 2016, 05:38:41 PM
#2 IIRC. The most common, at least that I've seen.
Just in the last few years I've been seeing Robertson on screws that require high torque, probably as an easier-to-manufacture (hence, cheaper) alternative to Torx. They can take more torque than phillips, which tend to cam out; but they can't take as much torque as Torx, after driving a couple hundred putting down backing board for tile floors, I've got a small pile of rounded-off Robertson bits to prove it.
us Offline rdub934
Reply #452 on: April 24, 2016, 06:23:26 PM
Back at work. I have the mighty PowerLock and TAC-Auto watching my back on this rainy, spring day.
Reply #453 on: April 24, 2016, 11:51:17 PM
Looking good rdub!
That's us mobile
au Offline ljnoble
  • The Land DownUnder
Reply #454 on: April 24, 2016, 11:59:37 PM
Sog fielder for me
Sent from my XT1092 using Tapatalk
From The Land DownUnder
Reply #455 on: April 25, 2016, 01:18:28 AM
Nice looking folder.
That's us mobile
Reply #456 on: April 25, 2016, 12:48:45 PM
I could give it a good home if you ever swap it out.   :cheers:
Reply #457 on: April 25, 2016, 03:43:47 PM
That's us mobile
Reply #458 on: April 25, 2016, 06:11:40 PM
My toys:
gb Offline Weasel
Reply #460 on: April 27, 2016, 07:53:45 PM
that looks a nice well used hatchet you got there.👍🏻
I like to use my tools as much as I can, so I stick to durable stuff...
knives, saws, MTs...they must be up to the task
and the SOG sure feels built to last!
My toys:
Reply #461 on: April 28, 2016, 03:50:17 PM
That's us mobile
us Offline rdub934
Reply #462 on: April 28, 2016, 04:06:41 PM
Bam! Nice load-out, Nate :tu:
Reply #463 on: April 28, 2016, 04:14:11 PM
Thanks!
That's us mobile
Reply #464 on: April 29, 2016, 03:21:51 PM
That's us mobile
us Offline rdub934
Reply #465 on: April 30, 2016, 04:35:56 AM
Anybody want some pork burgers? With bacon, btw ;)
Reply #466 on: April 30, 2016, 12:09:01 PM
Yes please!   :gimme:
Reply #467 on: April 30, 2016, 12:09:23 PM
us Offline Wanimator
Reply #468 on: April 30, 2016, 08:26:43 PM
Is it true that the cutter and can opener snag on eachother?
Reply #469 on: April 30, 2016, 08:31:16 PM
Cutter? The seat beat cutter?
That's us mobile
us Offline rdub934
Reply #470 on: May 01, 2016, 02:29:59 AM
Yes. If you try to put them right up against each other, the small screwdriver tip snags on the rivet/blade on the V-cut. But, you can easily find another spot for them. For instance, the V-cut is supposed to be a left-side tool, but I have mine on the right (on my PowerLock) - I put a washer against the handle and then put the V-cut. It rubs the handle a little but it is flexible enough that it's no biggie.
Reply #471 on: May 01, 2016, 03:58:46 AM
Ah, or it could be traded out for a blade ie a plain edge or serrated blade.
us Offline rdub934
Reply #472 on: May 01, 2016, 04:34:57 AM
Of course it could :tu: that is the beauty of most of the SOG tools - just mix and match until you figure out what you want to do. However, I was looking to replace the blade on my PowerLock. I wanted it knifeless. You see, my PowerLock is my on-duty tool, and I always carry a dedicated folder while I am on-duty. I dislike redundancy. So why not run the V-cutter in its place? I like it a lot, it is very useful
Reply #473 on: May 03, 2016, 02:06:25 PM
My toys:
Reply #474 on: May 03, 2016, 02:19:33 PM
Nice!
That's us mobile
Reply #475 on: May 04, 2016, 05:40:20 AM
How are the SOG scissors?
Reply #476 on: May 04, 2016, 11:21:37 AM
They are not bad, but they are no where near as good as the ones on a Surge.
That's us mobile
Reply #477 on: May 04, 2016, 12:22:37 PM
My toys:
us Offline Gryffin
  • Multi-Talented
Reply #478 on: May 05, 2016, 06:19:57 AM
They vary. In general, they aren't as sharp or cut as well as Victorinox (ANY model) or Leatherman Wave/Charge scissors, and not *quite* as good as LM Juice or Wingman scissors, but both bigger and better than most Gerber "Fiskars" scissors. If you get lucky, they cut pretty well, but a bad set will drive you crazy.
Reply #479 on: May 05, 2016, 03:39:41 PM
My toys:
Total Receipts: $90.65
PayPal Fees: $5.47
Net Balance: $85.18
Below Goal: $214.82
28%
