Show off your Sak mod's!
us Offline Corso
Re: Show off your Sak mod's!
Reply #2580 on: February 21, 2013, 03:27:54 AM
Cool idea adding the compass to the lanyard. I love people thinning tool chests, it actually makes them usuable
It's just a tiny bit thinner than a Swisschamp now.
au Offline PTRSAK
Reply #2581 on: February 21, 2013, 09:22:42 AM
Finally got this one assembled..  Climber-Lite
Plus scales :pok:
"simple" plus... Pin but no pen.
Reply #2582 on: February 21, 2013, 10:10:18 AM
Wenger Tool Chest on a diet.  I removed the compass (re-used as a lanyard bead) and fish scaler.
Genius :2tu:
Reply #2583 on: February 21, 2013, 11:09:52 AM
Looks great. :salute: Wish I had some ebony to play with. :D
I’m keeping my eye on Ebay for a cheap piano to chop up  >:D
Reply #2584 on: February 21, 2013, 11:13:44 AM
us Offline oreogaborio
Reply #2585 on: February 21, 2013, 11:22:25 AM
I've only got two mods so far, but here are both finished products side by side so you can see how I arranged the tools a little differently even though they had nearly identical tool selections.
My first... a "Jettsetting Manicure USB" with limited edition Magnolia scales for the girlfriend.
I realized later that this tool arrangement prohibits the use of a split ring. She wouldn't be able to fully extend the cuticle tool because the split ring would stop it about 3/4 of the way from full open.
And my second... a USB Rambler for the roommate.
You can see how I arranged the tools differently this time, only opening from two corners of the tool (well, three if you include the USB) to allow the use of a split ring but with this config the blade can close on it if you're not careful.
During assembly of each I instincively put the USB in the middle... Suppose I just liked the symetry I got with it there. What I liked MOST about the arrangement of this one was that I had the cutting tools on one side, screwdrivers on the other.
I think if I didn't sandwich the USB between the two tool layers I could arrange it so I'd have the opening symmetry of the Magnolia (opening from all four corners), cutting tools on one side, screwdrivers on the other, still be able to use a split ring AND not worry about the blade snapping down on it...
USB layer on top (or bottom)...
Scissors/Bottle opener (double thick layer, so it would get the split ring further away from the third layer)...
Blade/File on bottom (or top)...
If I end up building another one I'll use that layer arrangement, orient the tools so they open on all four corners like the Magnolia and see how I like that.  It might just be the ultimate arrangement :)
« Last Edit: February 21, 2013, 11:55:53 AM by oreogaborio »
-Pete
Offline jrp316
Reply #2586 on: February 21, 2013, 02:05:51 PM
@oreogaborio - When I built my alox Mini Tech, I ran into the same problem with the keyring tab for the USB; in my case, the nail file opens right against the tab and doesn't permit a keyring to be placed there. Like you, I also put my USB key in the center of the knife. I think if I do another USB knife, I'm going to grind off the plastic keyring tab and substitute a keyring spring instead. Are you planning anything for your alox scales yet?
Reply #2587 on: February 21, 2013, 02:31:20 PM
Yup, I've got a Minichamp on the way that I got cheap off ebay.  Gonna dress her in orange alox....
... maybe orange & blue alox, I haven't decided.   >:D
Gonna miss the pen & tweezers, but I've got a regular Minichamp already so I figured I'd go form over function this time around :)
-Pete
Offline jrp316
Reply #2588 on: February 21, 2013, 02:49:05 PM
Ah, you'll find a use for the pen & tweezers. My Mini Tech was made from parts donated by a Mini Champ. I've got some leftover parts as a result and I'm going down the route of building a Vagabond from them  :climber:.
gb Offline Dr Gonzo
Reply #2589 on: February 21, 2013, 04:02:08 PM
I've had this Mini Champ about 20 years, one of the scales was cracked so I thought I'd re-scale it ;)
The wood came from an incense burner...not sure what it is, some kind of hard wood...smells amazing after all its years in use ;)
There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die.
us Offline WiSAKfan
Reply #2590 on: February 21, 2013, 06:30:34 PM
invasion of the 58mms!
nice work fellas
Reply #2591 on: February 21, 2013, 11:34:22 PM
Very nice too - maybe rosewood? :D
au Offline PTRSAK
Reply #2592 on: February 22, 2013, 02:34:30 AM
Yeoman Mechanic
Offline jrp316
Reply #2593 on: February 22, 2013, 03:56:03 AM
Fresh off the bench, a 58mm Vagabond with the pen scale on one side:
Stay tuned for a how-to thread...
us Offline stealth007s
Reply #2594 on: February 22, 2013, 06:09:34 AM
I love the thickness of the scales on that SAK. What is the thickness?
Terry
Reply #2595 on: February 22, 2013, 11:41:36 AM
Meh, I've already got another 8 blade minichamp with pen & tweezers that will be remaining stock :)
-Pete
gb Offline Dr Gonzo
Reply #2596 on: February 22, 2013, 05:22:35 PM
4mm...I could sand them down further but I like them this way, I have quite big hands and bigger scales means better grip ;)
us Offline rickinFL
Reply #2597 on: February 22, 2013, 08:24:16 PM
The first.  Rambler with memory.  Pen scales from minichamp.
Reply #2598 on: February 22, 2013, 10:33:53 PM
That's a great thickness for scales IMO. I was thinking the same about the grip. If I ever get to do my carbon fibre scale mod on my Champ, I'll look for a thicker slab. All I've found so far is 2.5mm
Terry
au Offline PTRSAK
Reply #2599 on: February 23, 2013, 01:33:23 AM
The great thing about composites Terry is that you can sand down one side of that 2.5mm slab, cut it in half and using the right glue (epoxy resin probably) laminate it into a 5mm thick slab. And it will be just as strong and the join practically invisible.
Reply #2600 on: February 23, 2013, 03:06:24 AM
That's something I wouldn't have even thought of. Thanks Peter :2tu:
Terry
us Offline Outback in Idaho
Reply #2601 on: February 24, 2013, 06:21:50 AM
Spartan outfitted with Cherrywood scales of my own manufacture.
  Late to this thread but those scales & Vic logo are quite handsome.  :tu:
  If was an incense burner, could be Sandalwood. That wood does have a nice sweet smell to it.
« Last Edit: February 24, 2013, 06:26:08 AM by Xelkos »
¬ Outback Idaho
my Offline invitus
Reply #2602 on: February 24, 2013, 04:10:35 PM
just nice...got more pic on this sir?..thank you
Just wanted to share my Alox trifecta. :angel:
eat...sleep...multitools
de Offline crackout
Reply #2603 on: February 24, 2013, 04:40:17 PM
Sure.
Say my name.
my Offline invitus
Reply #2604 on: February 24, 2013, 04:55:43 PM
now u killing me... :facepalm:
us Offline tattoosteve99
Reply #2605 on: February 25, 2013, 03:38:46 AM
Nice work Rick!
au Offline PTRSAK
Reply #2606 on: February 25, 2013, 08:31:47 AM
Temporary build of a Neo-Voyageur.  Pinned with salvaged center pins from 91mm teardowns.
Need to stop in and pick up a scissor spring tomorrow.
I wanted to build this up to get a feel for what it would be like. If I like carrying it I will continue on in my efforts to pick up a ribbed cadet.
de Offline crackout
Reply #2607 on: February 25, 2013, 11:34:33 AM
I also tried to use replacement springs from 91mm models on my vintage 84mm scissors and had no luck. The cureld up part is too big to fit into the hole and the overall spring is too long preventing the scissors from fully closing. I ended up writing Victorinox and they sent me 3 84mm springs. :D Not sure if these were remaining stock from the old days or springs for Executives. But they're definitely neither 58mm nor 91mm.
Here's a comparison shot:
58mm spring, 84(?)mm spring, 91mm spring
« Last Edit: February 25, 2013, 11:39:46 AM by crackout »
Say my name.
Reply #2608 on: February 25, 2013, 02:04:13 PM
I wouldn't kick that out of bed for eating biscuits! :D
Reply #2609 on: February 25, 2013, 03:03:15 PM
I... LIKE... THAT.   :gimme:
-Pete
