Pretty much my line of thought as well
Great post and it echoes a lot of my own thoughts too I prefer the 4-6 territory too as they'll just cope with more things. One of my first good quality knives was a Cold Steel SRK in Carbon V. I learned a lot from that knife and I'm always a little shocked I haven't actually broken it, considering the utterly stupid things I'd attempted with it My first priority in any survival knife has to be reliability. It cannot fail, so I don't mind that it takes more effort to do feathersticks etc, due to a overly thick blade as it's worth it for the additional strength a thicker spine gives you. This is an area where I think tactical sharpened pry bars have there place If I had to write a specifcation for a compact survival knife, it would have these qualities...80-100mm blade with a minimum of 4mm thickness, preferably 6mm and full tang with exposed butt of at least 5mm.Drop or spearpoint with the spine running fullthickness almost to the tip for strength while batoning or prying. Man-made handles of robust material ie micarta.90 degree spine for shaving wood and striking a ferro rod. Blade material should be of a quality steel with good edge retention and inherent strength. If a carbon steel then it should have a good hardwearing coating.A kydex or zytel sheath with more than one method of carrying it on you and offers good knife retention and protection from the blade should you fall in it .Quite an ask really
Ohh the SRK, the knife I never had the guts to try out...When you really think about it there are people who can do more with an Old Hickory knife than most of us can do with all the McGizmo knives in the world. Speaking of thick knives, have you ever tried the British military survival knife?
The Magnum Lil Giant looks like it might be a good knife at a low cost: http://www.heinnie.com/magnum-lil-giant Depends if you like 440 steel, though I think Boker tend to do a good job with it.
Quote from: Gareth on May 12, 2015, 02:51:00 PMThe Magnum Lil Giant looks like it might be a good knife at a low cost: http://www.heinnie.com/magnum-lil-giant Depends if you like 440 steel, though I think Boker tend to do a good job with it.That is a lot of knife for the money U might even get one should I ever have disposable income again
Quote from: styx on May 12, 2015, 02:39:54 PMOhh the SRK, the knife I never had the guts to try out...When you really think about it there are people who can do more with an Old Hickory knife than most of us can do with all the McGizmo knives in the world. Speaking of thick knives, have you ever tried the British military survival knife?Yeah I had one for a while. A good knife, but wouldn't hold an edge for long. You'd never kill one though!
Quote from: Mike, Lord of the Spammers! on May 12, 2015, 02:10:46 PMGreat post and it echoes a lot of my own thoughts too I prefer the 4-6 territory too as they'll just cope with more things. One of my first good quality knives was a Cold Steel SRK in Carbon V. I learned a lot from that knife and I'm always a little shocked I haven't actually broken it, considering the utterly stupid things I'd attempted with it My first priority in any survival knife has to be reliability. It cannot fail, so I don't mind that it takes more effort to do feathersticks etc, due to a overly thick blade as it's worth it for the additional strength a thicker spine gives you. This is an area where I think tactical sharpened pry bars have there place If I had to write a specifcation for a compact survival knife, it would have these qualities...80-100mm blade with a minimum of 4mm thickness, preferably 6mm and full tang with exposed butt of at least 5mm.Drop or spearpoint with the spine running fullthickness almost to the tip for strength while batoning or prying. Man-made handles of robust material ie micarta.90 degree spine for shaving wood and striking a ferro rod. Blade material should be of a quality steel with good edge retention and inherent strength. If a carbon steel then it should have a good hardwearing coating.A kydex or zytel sheath with more than one method of carrying it on you and offers good knife retention and protection from the blade should you fall in it .Quite an ask really Another fan of the SRK here...indestructable!!!!!!!!!!
Quote from: Mike, Lord of the Spammers! on May 12, 2015, 05:19:17 PMQuote from: Gareth on May 12, 2015, 02:51:00 PMThe Magnum Lil Giant looks like it might be a good knife at a low cost: http://www.heinnie.com/magnum-lil-giant Depends if you like 440 steel, though I think Boker tend to do a good job with it.That is a lot of knife for the money U might even get one should I ever have disposable income again Quote from: Mike, Lord of the Spammers! on May 12, 2015, 05:17:13 PMQuote from: styx on May 12, 2015, 02:39:54 PMOhh the SRK, the knife I never had the guts to try out...When you really think about it there are people who can do more with an Old Hickory knife than most of us can do with all the McGizmo knives in the world. Speaking of thick knives, have you ever tried the British military survival knife?Yeah I had one for a while. A good knife, but wouldn't hold an edge for long. You'd never kill one though! Quote from: SAK Guy on May 12, 2015, 03:56:48 PMQuote from: Mike, Lord of the Spammers! on May 12, 2015, 02:10:46 PMGreat post and it echoes a lot of my own thoughts too I prefer the 4-6 territory too as they'll just cope with more things. One of my first good quality knives was a Cold Steel SRK in Carbon V. I learned a lot from that knife and I'm always a little shocked I haven't actually broken it, considering the utterly stupid things I'd attempted with it My first priority in any survival knife has to be reliability. It cannot fail, so I don't mind that it takes more effort to do feathersticks etc, due to a overly thick blade as it's worth it for the additional strength a thicker spine gives you. This is an area where I think tactical sharpened pry bars have there place If I had to write a specifcation for a compact survival knife, it would have these qualities...80-100mm blade with a minimum of 4mm thickness, preferably 6mm and full tang with exposed butt of at least 5mm.Drop or spearpoint with the spine running fullthickness almost to the tip for strength while batoning or prying. Man-made handles of robust material ie micarta.90 degree spine for shaving wood and striking a ferro rod. Blade material should be of a quality steel with good edge retention and inherent strength. If a carbon steel then it should have a good hardwearing coating.A kydex or zytel sheath with more than one method of carrying it on you and offers good knife retention and protection from the blade should you fall in it .Quite an ask really Another fan of the SRK here...indestructable!!!!!!!!!!I'm not sure how good the new ones are, but the old carbon V ones are bloody fantastic field knives
I always figured that if the smelly brown stuff hit the fan, that the SRK wouldn't be far from my side.It was on "loud noise in the middle of the night" duty for years
+100 on the Carbon V!!!! The #1 choice in my Trouble/Weather/Wildfire bags(Image removed from quote.)
I'm glad I'm not the only SRK fan then
