Day 7:More labels...(Image removed from quote.)Sent fra min FRD-L09 via Tapatalk
Powernoodle Day 7(Image removed from quote.)I buy almost everything on Amazon. But not the cat.(Image removed from quote.)(Image removed from quote.)
Mactire - MCC06First off, apologies to the mod who has removed the picture from my previous post. I should have been more considerate about the coffee.The MC saw a whole lot of action today. In the morning I had to open a box of eyePads. Not to be confused with iPads. We use these to cover patients eyes during examination.A great pre of the 58mm SAKs is that even the Large Blade does not scare the muggles.(Image removed from quote.)Then I made coffee and the puck got really stuck in the filterholder. I'm under the impression fresh coffee expands more when wet than pre-ground store bought coffee. Used the Ruler to loosen the grounds.(Image removed from quote.)Doggo is sick. He needs medication. But the pills they prescribed are for heavier dogs. So I used the Nailfile to reduce the weight of the pill and meet the apropriate dosage requirement.(Image removed from quote.)When it was time to go to bed I had to turn off the TV. The power button is broken so the Cuticle Pusher did a fine job pressing the switch inside the TV.(Image removed from quote.)
