EDC Bit Ratchets
Re: EDC Bit Ratchets
Reply #180 on: April 28, 2023, 02:57:22 AM
Ratchets reviewed so far
« Last Edit: December 25, 2025, 09:13:03 PM by ReamerPunch »
Reply #181 on: April 28, 2023, 02:58:38 AM
Like Facom Rotator Handle Ratchet 1/4'' but that doesnt have ability to put 1/4” bit straight without adapter. I would like to see one with ability to accept 1/4” bit without adapter
Only Tools Matters
I have not reviewed any ratchet like that yet. I hope to find one that is small.
Reply #182 on: April 28, 2023, 03:16:30 AM
What ratchet you recommend for edc purpose? I need one with low swing arc and ideally bit adapter on both end. I have Vic ratchet but it feels too high swing arc for tight places.
Low swing arc and driver on both ends. :salute:
Ares
I edc this. 72 teeth = 5° swing arc. Good size. Inexpensive. No problems with it.
Prestacycle
I like this one. 60 teeth = 6° swing arc. High quality. Comes in a nice, flat nylon wallet. You can put the extender through the head for T-handle.
Topeak
52 teeth = 7° swing arc. This is high quality and comes in a nice pouch with bits and an extender.
Rujoi
60 teeth = 6° swing arc. Flexhead. You can also have T-handle with this one. Many brands sell ratchets like this one.
Here is a size comparison. The Rujoi is a little longer than the PrestaCycle.
« Last Edit: December 26, 2024, 06:17:42 PM by ReamerPunch »
fr Offline m47mu74nt
Reply #183 on: April 28, 2023, 10:59:38 AM
I think I need the Rujoi : the handle is a little different than the Facom/usag, and it could be better at some point
Reply #184 on: April 28, 2023, 03:41:13 PM
Hmm seems like i need to try Rujoi and Ares, both seems like i migh like those
Only Tools Matters
Reply #185 on: May 03, 2023, 01:52:40 PM
I got this Tone (Toh-neh, not 'tone') ratchet this morning and I am impressed. A nice compact package, with extension, twenty bits, and a tiny Tone logo sticker, in a drill bit container. That extension is truly amazing. But no spoilers. :D
This is available in Amazon Japan. Fast DHL shipping, five days from order to my door. I am very pleased with it and recommend it for a nice, compact edc set. Full review will follow soon. :salute:
« Last Edit: May 03, 2023, 01:59:33 PM by ReamerPunch »
Reply #186 on: May 03, 2023, 07:13:16 PM
The form factor of the box looks truly amazing  :pok:
Reply #187 on: May 04, 2023, 03:00:28 AM
Yay  :mail:
EDIT: Um, maybe not yay.  :think:
« Last Edit: May 04, 2023, 03:13:24 AM by ReamerPunch »
Reply #188 on: May 04, 2023, 06:09:21 AM
Everything fits in do nicely. No wasted space.  Fits in a pocket like a dream. :like:
Reply #189 on: May 15, 2023, 05:24:02 AM
Only Tools Matters
They released a rotator bit ratchet!
https://www.youtube.com/watch?v=EBQKisiGjUU
Reply #190 on: May 15, 2023, 08:04:08 AM
That looks awesome, maybe need to but this instead others. Noticed that price bit salty for only ratchet but it has rotating handle and fairly low swing arc so i might forgive price for those.
Only Tools Matters
Offline Turing Complete
Reply #191 on: June 14, 2023, 04:07:56 PM
Thanks so much for all these reviews. I'm trying to figure out what to EDC, and this is great. I thought I might help out a bit.
I was at Harbor Freight and picked up the ICON set. You may notice some similarities to Facom.
Weight
Ratchet: 61g
Extension bar: 33g
Full case: 361g
Length
Ratchet: 110mm
Extension bar: 100mm
Bit retention: spring detent
In-line driver bit socket: yes
In-line driver socket bit retention: magnet
Bit material: S2 steel
Handle material: Chrome Vanadium steel
Price: 45$ with  32 bits, 1/4" square adapter, extension, and case
Bits: Torx bits: T6, T7, T8, T9, T10H, T15H, T20H, T25H, T27H, T30H, T40H, Slotted bits: SL4, SL5.5, Phillips bit: PH1, PH2, PH3, hex bits: H1.5, H2, H2.5, H3, H4, H5, H6, H7, H8, H1/8 in., H5/32 in., H3/16 in., H1/4 in., Pozidrive bits: PZ1, PZ2, PZ3
Flex-head positions: 15° increments
Reply #192 on: June 15, 2023, 05:25:46 PM
Looks very close to the FACOM/USAG one, even the box is "similar" but not "same" : it's shape might be even better ! (but the hinge, and the locking mechanism are identical for what I see)
Does it feature the "compact" socket adapter or the standard one?
Offline AndreaW
  • New User
Reply #193 on: August 04, 2023, 12:30:24 AM
Here is a mini ratchet from 711L (they make bicycle tools).
Link removed
« Last Edit: August 04, 2023, 10:21:29 AM by McStitchy »
Reply #194 on: August 07, 2023, 09:58:13 PM
That is pretty small !
 :pok:
Reply #195 on: August 11, 2023, 07:16:11 AM
Wow, that's cute. I'd clip that on my keys. Rather price though. $30 US with no bits. :think:
Reply #196 on: October 16, 2023, 07:28:42 AM
It's so tiny! Basically a Topeak head attached to the in-line driver. I still think this is overpriced. And it may be too small for some people. The Topeak set is only a couple dollars more, and has a wallet, twelve bits, ratchet, extension, and two tire pry bars.
I also got the SOG PowerPint. Finally a SOG worth getting. I quite like this one. And it has a can opener. :D
Offline refleks
Reply #197 on: January 17, 2024, 11:07:23 AM
Link removed
That is super cool! Unfortunately like most of these
1. There's no knurling
2. The end-bit holder is too shallow for double sided bits
Would be just about perfect for a little keychain EDC driver if it was just a little deeper like the leatherman bit extension, then you could use regular bits, leatherman bits or wiha like double ended bits like you can on the ratchet end. I'm going to order some of these stubby double sided bits from amazon and see if they're short enough to work with it...
Reply #198 on: January 17, 2024, 01:39:02 PM
I was looking for one yesterday, nearly pulled the trigger on the engineer stubby ratchet DR54
What's the id for the one on your picture?
fi Offline Blunt Object
Reply #199 on: January 17, 2024, 01:51:33 PM
What an awesome thread! I put together a miniature tool set, knifeless, fits in a non-elastic mag pouch, Vic Card scissors missing from the picture. Should be flight safe according to our national carrier which I use and who allows scissors up to 6cm. The ratchet is the smallest I've found. Wouldn't bet my life on it, but the extender works as a bitholder/driver on its own and Knipex can be used to turn it if force is needed.
Spydies and Vics and Leathermans, Oh My!
us Offline D-Eg
  • Dan
Reply #200 on: January 20, 2024, 04:52:30 AM
here is a pretty limited one - it is a kit for removing the doors from a Jeep. I guess I could drop in or replace bits with something more common. It has a belt loop on the back if I need to carry it
Reply #201 on: January 20, 2024, 03:52:14 PM
Very nice!
Reply #202 on: January 20, 2024, 03:53:09 PM
I did pull the trigger on the DR54, and on cheapos, will see
Offline refleks
Reply #203 on: January 20, 2024, 09:47:18 PM
Update: The Steinwhale bits fit perfectly, like it was made for it. Now it's easy to keep a flat head and phillips on the tool even while it's on your keychain.  Kinda wish they included security torx in the set, but I'll take what I can get!
From top to bottom: Steinwhale, Wiha, Klein, leatherman
Ironically, although the Wiha double ended bit is shorter than the Klein overall, the shortness is in the middle, not the ends, and is actually just a hair longer than the Klein on the ends.
This means sometimes a bit extension can use the Klein but not the Wiha despite the wiha being shorter.  For example, both ratchets can use any of these bits in the ratcheting portion, but the longer ratchet cannot grab the Wiha bit on the end (and barely grabs the klein, almost enough to not be usable in regular practice but would work in a pinch). The shorter ratchet cannot grab either the Wiha or the Klein.  Both can use the leatherman flat bits, but they wobble a lot.
An ideal 2nd Generation version of these ratchets would have knurling and a deeper well on the end, like the leatherman extension, with a combo of magnet and wire retention. This would provide redundancy in case one retention method fails, and can use all bits, even the Steinwhale (though you will need assistance removing it).
Reply #204 on: January 24, 2024, 11:50:12 PM
Great kit! :like:
Reply #205 on: January 24, 2024, 11:52:27 PM
Those bits are handy indeed.  :like:
It's a shame that the people who sell ratchets don't put that much thought into what would fit the best in their tools.
Reply #206 on: January 24, 2024, 11:57:19 PM
Just an FYI, I'm still around, but my laptop and phone started dying at the same time. I'm looking into solutions, but may end up just getting a new one.
I hope to start making reviews again soon. :cheers:
Reply #207 on: January 25, 2024, 07:19:58 AM
Cheapos were just some kind of stubby 1/4 hex and square drivers without anything fancy, might have a use for them I'll see.
Still waiting for the DR54 though
Reply #208 on: January 25, 2024, 08:24:16 AM
Don't worry, we'll wait for you  :drink:
hr Offline styx
Reply #209 on: January 31, 2024, 09:37:02 PM
Hopefully I'll soon be able to contribute with a review of the Bosh ratchet from the 2607017160 set
